[Linux] E: Unable to locate package issue
86
【Linux】 E: Unable to locate package issue
Posted at 8/23/2022 09:02:28      View:3057 | Replies:7        Print      Only Author   [Copy Link] 1#
I'm trying to install the 'stressapptest' pkg.
but the error occurred like as below.
firefly@firefly:~$ sudo apt-get install stressapptest
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package stressapptest
So, I tried something as below cmd but the result was same.
firefly@firefly:~/proj$ sudo apt update
firefly@firefly:~/proj$ sudo add-apt-repository universe
firefly@firefly:~/proj$ sudo add-apt-repository multiverse
How can I solve this problem ?
Posted at 8/23/2022 09:45:30        Only Author  2#
It is not a problem. Just because Ubuntu have no stressapptest for arm64, so you can't find it
check the link:
https://packages.ubuntu.com/sear ... &searchon=names
Ubuntu only provides amd64 version
So you have to build stressapptest from source, but i seem to remember firefly firmware already come with the stressapptest
Posted at 8/23/2022 11:03:17        Only Author  3#
You mean that 'stressapptest' is already installed on the firefly Ubuntu ?
Posted at 8/23/2022 11:30:22        Only Author  4#
OK Thanks a lot.
I have checked it works well.
Posted at 1/10/2026 17:41:27        Only Author  5#
This article has provided me with many valuable insights. I’m sharing the Latest AANP-FNP exam vce free test that got me my promotion and pay raise. It’s available to you for free today—best of luck with your career ambitions!
Posted at 1/23/2026 03:10:22        Only Author  6#
1Y0-342問題集の品質を確かめ、この問題集はあなたに合うかどうかを確認することができるように、Topexamは1Y0-342問題集の一部のダウンロードを無料で提供します。二つのバージョンのどちらでもダウンロードできますから、Topexamのサイトで検索してダウンロードすることができます。体験してから購入するかどうかを決めてください。そうすると、1Y0-342問題集の品質を知らないままに問題集を購入してから後悔になることを避けることができます。
Posted at 2/21/2026 04:29:48        Only Author  7#
Thank you for your article, it really broadened my horizons! Wishing you success! Here are the free 1Y0-342 relevant answers resources for you!
Posted at 3/5/2026 08:42:14        Only Author  8#
Wenn man an sich glaubt, kann man wirklich was erreichen. Der Grund, warum Fast2test jedem IT-Fachmann helfen kann, liegt in seiner Fähigkeit. Die Prüfungsmaterialien zur UiPath UiAAAv1 Zertifizierung von Fast2test können Ihnen zum Erfolg verhelfen. Jede Beschränkung fängt im Herzen an. Wenn Sie die UiPath UiAAAv1 Prüfung bestehen wollen, werden Sie Fast2test wählen. Eigentlich ist die Distanz zwischen Erfolg und Niederlage nicht weit. Fast2test führt Sie zum Erfolg.
