[Hardware] EMMC booting issues
15
Hardware EMMC booting issues
Posted at 5/31/2018 00:44:08      View6451 | Replies6        Print      Only Author   [Copy Link] 1#
Had the ROC now for about 2 months.. just got the emmc from libre.. using the flashing tool for windows using type A to type A usb cable.. I am able to see it as Maskrom.. and only Maskrom (wont change to anything else no matter how long I press that button).. installed the 05-14-2018 new Ubuntu image (btw was a real hassle to download, download connections droped a lot) and even older images.. Everyting installs ok..
Download Boot Start
Download Boot Success
Wait for Maskrom Start
Wait for Maskrom Success
Download Roc-RK33XXXXXXXXXXXXXX-20180514.IMG
Download image OK
When I go to boot from eMMC the thing just sits there.. Red and green light are on instead of (RED)..
When I boot with SD card it works perfectly.. and I can see the emmc partitions when I boot into Ubuntu..
I haven't had any luck booting just with the eMMC..
btw using all windows tools.. etcher for SD and Android tool for non android for emmc..
Anybody has any clues whats going on??
Posted at 8/30/2018 04:23:52        Only Author  2#
You could try this https://github.com/armbian/config. You can add it to your OS but, you will need the dependencies (you will need to find working ones or add ppas) If  that's too complicated. It's built into Armbian. You boot OS on SD. Then Run Armbianconfig. You can install to USB3 or EMMC. I'm using a HD dock/hub. It's fast but, the OS is still in development, as are all the OS's. Itried USB3 memory stick too (get one with heat synks and no case it gets hot!!!). Way faster than EMMC It uses the SD for the boot record then boots the OS.from where you moved it too.
It will be a while until you can get a supported OS. Donations to Firefly or your preferred OS could help speed things along. I'm just waiting patently like you. I have no connection to anyone. I just own the board lol
Posted at 1/9/2026 23:51:46        Only Author  3#
यˤICF-ACCԇYy˼äƤޤICF-ACCԇYο֤СԷ֤Ŭ˼ӤơäICF-ACCԇY˺ϸǤޤICF-ACCԇYοˤĤơäԔȤ֪ꤿϡICFΥ֥ȤL픤ޤ
Posted at 1/11/2026 06:54:46        Only Author  4#
Cant get enough of this content, definitely liking it. The Latest exam DCPLA questions answers was the key to my promotion and raise. Now its free to everyone. Wishing you all a successful career boost!
Posted at 1/12/2026 13:48:19        Only Author  5#
NSE7_SSE_AD-25ԇY˲μӤǰˡԇY֪ꤿϡιʽȤLǤޤơNSE7_SSE_AD-25ԇYɤΥǥ`ɤ뤳ȤϺgǡǤåҪǤᡢNSE7_SSE_AD-25YϤϤ٤NSE7_SSE_AD-25ԇYv뤳Ȥ狼ޤNSE7_SSE_AD-25YϤȫƤΥک`NSE7_SSE_AD-25ԇYvBƤޤNSE7_SSE_AD-25YϤ餷ΤǤ
Posted at 1/16/2026 09:17:08        Only Author  6#
Wenn Sie die ZertSoft Website klicken, wundern Sie sich vielleicht, dass viele Leute jedentag ZertSoft besuchen. Das ist ganz normal. Wir bieten den Kandidaten zahlreiche Schulungsunterlagen, mit denen sie die Fortinet FCSS_EFW_AD-7.6 Prfung bestehen können. Das heißt, dass die Schulungsunterlagen wirklich wirksam sind. Wenn Sie die Fortinet FCSS_EFW_AD-7.6 Fragenkatalog kaufen wollen, verpassen Sie ZertSoft nicht. Und Sie werden sicher mit unseren Produkten zufrieden.
Posted at 2/23/2026 02:54:59        Only Author  7#
Your article was so unique, thank you for sharing this fresh perspective. This Valid Databricks-Certified-Data-Engineer-Associate test collection sheet was instrumental in my promotion and pay raise. Its now free to everyone. Wishing you success in your promotions!
