[Android] Android boot error on ROC-RK3328-CC
31
【Android】 Android boot error on ROC-RK3328-CC
Posted at 6/21/2018 07:17:36      View:5405 | Replies:2        Print      Only Author   [Copy Link] 1#
Hi,
I downloaded android 7.1 sdk and compiled them.
Then I create update.img using mkupdate.sh  script and burned it micro sd card.
However, Android did not launched correctly. And below messages are displayed.
( I used some micro sd cards, but the result is same)
failed to mount /cache (Block device required)
format_volume: make ext4 failed on /dev/block/rknand_cache with
fauled to moutn /metadaba
format_volume: make ext4 failed on /dev/block/rknand_metadaba with
failed to mount /metadata
I did not understand the cause. Does anyone know the cause?
Posted at 1/30/2026 23:14:03        Only Author  2#
What an outstanding article, thank you for this insightful share. With free access to Top CPRE-FL_Syll_3.0 dumps, you can explore its rich content to help you succeed.
Posted at 2/21/2026 15:53:10        Only Author  3#
The article is really inspiring; thank you for sharing! Get free Valid 200-301 exam testking to level up your IT knowledge. Wishing you success!
