Salesforce Analytics-DA-201 Formal Test, Analytics-DA-201 Actual Exam
135
Posted at 3 day before      View:37 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Salesforce Analytics-DA-201 dumps are available on Google Drive shared by ITExamDownload: https://drive.google.com/open?id=1zetEIy1tW3Xx4EpUtrJpNfc3FnhvDB8z
Salesforce Analytics-DA-201 exam dumps certification will not only improve the quality of your resume, but it can open the door to new opportunities for employment. It is compulsory to prepare with reliable and valid Analytics-DA-201 dumps that ensures 100% success on the very first attempt. There is nothing more valuable that being awarded the Salesforce Certified Tableau Data Analyst Certification Exam that can allow you to earn an impressive position in the industry of Salesforce. We hope you will be able to enjoy a positive experience making preparations with our latest and valid Analytics-DA-201 Exam Questions And Answers.
Our Salesforce Analytics-DA-201 web-based practice exam software also simulates the Salesforce Certified Tableau Data Analyst (Analytics-DA-201) environment. These Salesforce Analytics-DA-201 mock exams are also customizable to change the settings so that you can practice according to your preparation needs. ITExamDownload web-based Analytics-DA-201 Practice Exam software is usable only with a good internet connection.
Salesforce Analytics-DA-201 Practice Test [2026]If you buy our Analytics-DA-201 preparation questions, we can promise that you can use our study materials for study in anytime and anywhere. Because our study system can support you study when you are in an offline state. In addition, Our Analytics-DA-201 training quiz will be very useful for you to improve your learning efficiency, because you can make full use of your all spare time to do test. It will bring a lot of benefits for you beyond your imagination if you buy our Analytics-DA-201 Study Materials.
Salesforce Certified Tableau Data Analyst Sample Questions (Q164-Q169):NEW QUESTION # 164
You company has two divisions located in the United States and Germany Bach division has a separate database. The following is a sample of the sales data for the division in the United States.
The following is a sample of the sales data for me division in Germany.
You have population data in a file named Populatio.csv. the following is a sample of the data.
You plan to create a visualization that ml show tie sales per capita for each salesperson Each salesperson must be identified by identified by their full name.
You need to prepare the data to support the planned visualization. The data source must support being published .
Which four actions should you perform in order?
(Place the four correct options n order Use the arrows to move Options to Answer Area arrows to re-order the options.
Use Answer Area arrows to re-order the options)
1) Open Tableau prep
2) Create a new column ...
3) Union the sales ...
4) Join the sales ...
References: https://help.tableau.com/current/prep/en-us/prep_get_started.htm https://help.tableau.com/current
/prep/en-us/prep_union.htm https://help.tableau.com/current/prep/en-us/prep_clean.htm https://help.tableau.
com/current/prep/en-us/prep_join.htm
NEW QUESTION # 165
A Data Analyst has the following dataset.
The analyst wants to create a parameter to dynamically filter the data to produce the following results based on quantity being above X value.
Which two types of parameters should the analyst use to produce the results? (Choose two)
  • A. Boolean
  • B. Float
  • C. Date
  • D. Integer
NEW QUESTION # 166
How are the colors configured for the map?
  • A. A sequential color gradient
  • B. A diverging color palette that has six stepped colors
  • C. A single color gradient
  • D. A diverging color palette that has five stepped colors
NEW QUESTION # 167
A Data Analyst has the following bar chart.
The analyst wants the chart to appear as shown in the following exhibit.
What should the analyst add?
  • A. A reference line
  • B. An average line
  • C. A reference band
  • D. A distribution band
NEW QUESTION # 168
Open the link to Book1 found on the desktop. Open Disciplines worksheet.
Filter the table to show the members of the Top10 set and the members of the Bottom10 set. There should be a total of 20 rows.
check the steps below in explanation.
To filter the table to show the members of the Top10 set and the Bottom10 set, you need to do the following steps:
* Open the link to Book1 found on the desktop. This will open the Tableau workbook that contains the Disciplines worksheet.
* Click on the Disciplines tab at the bottom of the workbook to open the worksheet. You will see a table that shows the disciplines, sales, and profit for each salesperson.
* Click on the drop-down arrow next to Salesperson on the Filters shelf. This will open a menu that allows you to filter by different criteria.
* Select Set from the menu. This will show you the sets that are available for the Salesperson field. You will see Top10 and Bottom10 as two sets that have been created based on the sales ranking.
* Check the boxes next to Top10 and Bottom10. This will filter the table to show only the members of these two sets. You can also click on All to deselect all other values.
* Click OK to apply the filter. You will see that the table now shows 20 rows, 10 for each set.
References: https://help.tableau.com/current/pro/desktop/en-us/sets.htm
https://help.tableau.com/current/pro/desktop/en-us/filtering.htm
NEW QUESTION # 169
Our technician will check the update of Analytics-DA-201 exam questions every day, and we can guarantee that you can get a free update service from the date of purchase. Once you have any questions and doubts about the Analytics-DA-201 exam questions we will provide you with our customer service before or after the sale, you can contact us if you have question or doubt about our Analytics-DA-201 Exam Materials and the professional personnel can help you solve your issue about using Analytics-DA-201 study materials.
Analytics-DA-201 Actual Exam: https://www.itexamdownload.com/Analytics-DA-201-valid-questions.html
Exercise Studying for your Analytics-DA-201 Actual Exam - Salesforce Certified Tableau Data Analyst exam doesn’t have to mean sitting in front of a desk all day/night, Option 1: Request an Exam Please provide the code of your exam and your email address, and we'll let you know when your exam is available on ITExamDownload Analytics-DA-201 Actual Exam, At present, many young people are keen on obtaining the Salesforce Analytics-DA-201 certificate.
I want to open my car door, Deferring Creation or Rendering of Analytics-DA-201 Actual Exam the Clipboard Data, Exercise Studying for your Salesforce Certified Tableau Data Analyst exam doesn’t have to mean sitting in front of a desk all day/night.
Use Salesforce Analytics-DA-201 Practice Exam Software (Desktop and Web-Based) For Self EvaluationOption 1: Request an Exam Please provide Analytics-DA-201 the code of your exam and your email address, and we'll let you know when your exam is available on ITExamDownload, At present, many young people are keen on obtaining the Salesforce Analytics-DA-201 certificate.
All the questions cover the main points which Analytics-DA-201 actual exam required, As our exam preparation materials are famous for its professional content and high pass rate, you will not regret to purchase our Analytics-DA-201 certification dumps.
DOWNLOAD the newest ITExamDownload Analytics-DA-201 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1zetEIy1tW3Xx4EpUtrJpNfc3FnhvDB8z
Posted at yesterday 17:45        Only Author  2#
Your article really stuck with me, I’m sincerely grateful. Thanks to the 250-583 test tutorial, I achieved a promotion and salary increase. Now, it’s free for everyone. Wishing you all success in your careers!
