[General] 100% Pass 2026 Plat-Admn-301: Unparalleled Salesforce Certified Platform Adminis
126
【General】 100% Pass 2026 Plat-Admn-301: Unparalleled Salesforce Certified Platform Adminis
Posted at 2/16/2026 21:48:21      View:55 | Replies:1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of VCE4Plus Plat-Admn-301 dumps from Cloud Storage: https://drive.google.com/open?id=15M3FpXi6s_citXqgQnlwZzTsFwKDuIvU
If you're looking to accelerate your career in the field of information technology, don't hesitate to take advantage of our top-notch Salesforce Plat-Admn-301 practice material. What sets VCE4Plus apart is our commitment to providing updated and actual Plat-Admn-301 certification exam questions. Our dedicated team works hard to collect and update the Plat-Admn-301 Exam Questions based on the latest exam sections. We closely observe the real Salesforce Plat-Admn-301 content to ensure that our unique and error-free exam questions make your preparation successful.
Salesforce Plat-Admn-301 Exam Syllabus Topics:
  • Objects and Applications: This section of the exam measures the skills of a Salesforce Business Analyst and covers selecting appropriate object and application-level solutions to meet business needs. It focuses on identifying when to use master-detail relationships, lookups, junction objects, related lists, record types, Schema Builder, and Object Creator. The section also includes improving UI and user experience using App Manager, Lightning App Builder, Dynamic Forms, standard Lightning components, console apps, and tools like the Lightning page analyze button.
  • Environment Management and Deployment: This section of the exam measures skills of Salesforce Administrator and covers moving metadata between environments using tools such as sandboxes, change sets, and managed or unmanaged AppExchange packages. It explains the capabilities and best practices related to deploying changes through change sets to ensure smooth and controlled migrations.
  • Data and Analytics Management: This section of the exam measures skills of Salesforce Data Analyst and covers data quality assessment, data enrichment, and duplicate management. It explains how to choose appropriate reporting and analytics tools for advanced requirements, including custom report types, snapshots, formulas, joined reports, and dashboard configurations. It also covers methods for connecting external data sources using big objects, external objects, data warehouses, data lakes, and Salesforce Connect. Finally, it describes the suitable tools and methods for importing data, including Data Loader, Data Import Wizard, and external IDs.
Detailed Plat-Admn-301 Answers - Plat-Admn-301 Latest Study PlanThe most important thing for preparing the Plat-Admn-301 exam is reviewing the essential point. In order to service the candidates better, we have issued the Plat-Admn-301 test prep for you. Our company has accumulated so much experience about the test. So we can predict the real test precisely. Almost all questions and answers of the real exam occur on our Plat-Admn-301 Guide braindumps. That means if you study our study guide, your passing rate is much higher than other candidates. Preparing the exam has shortcut.
Salesforce Certified Platform Administrator II Sample Questions (Q141-Q146):NEW QUESTION # 141
Ursa Major Solar's administrator has configured multiple record-triggered flows to run before or after the record is saved on the Account object.
What should the administrator consider when a record-triggered flow executes first?
  • A. The flow with the shortest execution time will execute first.
  • B. Assign the highest priority to the record-triggered flow which should execute first.
  • C. The order in which those flows are executed is not guaranteed.
  • D. The flow with the longest execution time will execute first.
The order in which record-triggered flows are executed is not guaranteed. If there are multiple record- triggered flows on the same object and trigger type, Salesforce does not guarantee which one runs first.
Therefore, the administrator should consider this when designing record-triggered flows that depend on each other's outcomes. References: https://help.salesforce.com/s/ar ... epts_trigger_order.
htm&type=5
NEW QUESTION # 142
An administrator need a business process automated, but only for certain user and profiles. The administrator will need to frequently update which users and profiles will use the process. After evaluating the declarative options, it was determined that this functionality must be done via an Apex trigger.
What software requirement should the administrator request so that process execution can be declaratively controlled?
  • A. Use Apex Class Access to assign the Apex code to the user or profile.
  • B. Use a System permission that is assigned to the user or profile.
  • C. Use Process Automation Setting in Setup to the appropriate users or profiles.
  • D. Use a custom permission set that is assigned to the user.
Use a custom permission set that is assigned to the user because custom permissions are a way to grant access to custom processes or functionality based on user profiles or permission sets. Custom permissions can be referenced by Apex code, validation rules, flows, or other logic to control whether a process should run for a user or not. Custom permissions can be used to declaratively control process execution by assigning them to users or profiles.
NEW QUESTION # 143
A user at Ursa Major Solar is experiencing a flow error while trying to process a record to the next status. The users with the same access can process records without any errors.
What should the administrator do to troubleshoot the issue?
  • A. Change the flow to run as System Context Without Sharing - Access All Data.
  • B. Use the flow debug option and set the selection to Run as another user.
  • C. Grant the user the Modify All permission to ensure they have full system access.
  • D. Grant the user more data access by moving them higher in the role hierarchy.
The flow debug option is a tool that allows you to test and troubleshoot your flow by running it in debug mode and inspecting the values of variables and resources at each step. You can also set the debug mode to run as another user and see how the flow behaves for different users with different permissions and settings.
In this case, using the flow debug option and setting the selection to run as another user can help identify why one user is experiencing a flow error while others are not. References: https://help.salesforce.com/s
/articleView?id=sf.flow_debug.htm&type=5
NEW QUESTION # 144
Cloud Kicks (CK) has an email parsing tool. CK wants to ensure that when certain field are updated, the Case Owner is notified by email.
What should the administrator use to email the Case Owner?
  • A. After Save Flow
  • B. Before Save Flow
  • C. Outbound Message
  • D. Email-to-Case
An after save flow is a type of flow that runs in the background after a record is saved and performs actions based on the record data or changes. An after save flow does not require user input or interaction and can be triggered by a record-triggered flow element or by an Apex trigger. In this case, you can create an after save flow that runs when a case record is updated and delivers status update email to customers based on certain criteria or conditions. References: https://help.salesforce.com/s/ar ... flow_trigger_types.
htm&type=5 https://help.salesforce.com/s/ar ... gger.htm&type=5
NEW QUESTION # 145
Ursa Major Solar customer records have a lot of fields and Lightning components to give users a variety of information and available functions. Recently,usrrs have noted that their pages take a long time to load and it's starting to negatively impact their experience.
What should the administrator do to help diagnose where improvements can be made?
  • A. Click Analyze from the Lightning App Builder toolbar.
  • B. Use the Apex debugger while loading a customer record.
  • C. Review the debug logs from the Developer Console.
  • D. Check the debug logs found in the Environment section of Setup.
The Analyze feature in the Lightning App Builder toolbar is a tool that helps you optimize the performance of your record pages by providing recommendations and insights on how to improve page load time and user experience. It can help you identify which fields and components are taking the most time to load and suggest ways to reduce their impact. You can also compare your page performance with other pages in your org or with Salesforce best practices. References: https://help.salesforce.com/s/articleView?id=sf.
lightning_page_optimize.htm&type=5
NEW QUESTION # 146
Our VCE4Plus devote themselves for years to develop the Plat-Admn-301 exam software to help more people who want to have a better development in IT field to pass Plat-Admn-301 exam. Although there are so many exam materials about Plat-Admn-301 exam, the Plat-Admn-301 exam software developed by our VCE4Plus professionals is the most reliable software. Practice has proved that almost all those who have used the software we provide have successfully passed the Plat-Admn-301 Exam. Many of them just use spare time preparing for Plat-Admn-301 Salesforce exam, and they are surprised to pass the certificated exam.
Detailed Plat-Admn-301 Answers: https://www.vce4plus.com/Salesforce/Plat-Admn-301-valid-vce-dumps.html
P.S. Free 2026 Salesforce Plat-Admn-301 dumps are available on Google Drive shared by VCE4Plus: https://drive.google.com/open?id=15M3FpXi6s_citXqgQnlwZzTsFwKDuIvU
Posted at 3 hour before        Only Author  2#
Your article has really expanded my perspective, thank you. The PCEP-30-02 formal test test was vital in advancing my career and income—today, it’s yours for free!
