[General] Pass Juniper JN0-460 Exam with flying colors
118
【General】 Pass Juniper JN0-460 Exam with flying colors
Posted at 1/26/2026 09:40:53      View:92 | Replies:2        Print      Only Author   [Copy Link] 1#
2026 Latest PrepAwayETE JN0-460 PDF Dumps and JN0-460 Exam Engine Free Share: https://drive.google.com/open?id=1vwseXr1iWwcT0gL1hRE2bugeB8gRJpfx
The JN0-460 learning materials from our company are very convenient for all people, including the convenient buying process, the download way and the study process and so on. Upon completion of your payment on our JN0-460 exam questions, you will receive the email from us in several minutes, and then you will have the right to use the JN0-460 Test Guide from our company. In addition, there are three different versions for all people to choose: PDF, Soft and APP versions. According to your actual situation, you can choose the suitable version from our JN0-460 study question.
We provide you the free download and tryout of our JN0-460 study tool before your purchase our product and we provide the demo of the product to let the client know our product fully. After you visit the pages of our JN0-460 test torrent on the websites, you can know the version of the product, the updated time, the quantity of the questions and answers, the characteristics and merits of the Mist AI Wired, Specialist (JNCIS-MistAI-Wired) guide torrent, the price of the product and the discounts. In the pages of our product on the website, you can find the details and guarantee and the contact method, the evaluations of the client on our JN0-460 Test Torrent and other information about our product. So it is very convenient for you.
Exam JN0-460 Objectives - Reliable JN0-460 Test Pass4sureWith all these features, another plus is the easy availably of PrepAwayETE’s products. They are instantly downloadable and supported with our online customers service to answer your queries promptly. Your preparation for exam JN0-460 with PrepAwayETE will surely be worth-remembering experience for you!
Juniper Mist AI Wired, Specialist (JNCIS-MistAI-Wired) Sample Questions (Q60-Q65):NEW QUESTION # 60
Which EVPN route type is used for designated forwarder elections?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
NEW QUESTION # 61
When do you need to "adopt a switch"?
  • A. immediately upon arrival after it ships from distribution
  • B. in a greenfield environment
  • C. immediately upon arrival after it ships from the factory
  • D. in a brownfield environment
According to Juniper Mist documentation, the term "Adopting a Switch" specifically refers to the process of bringing an existing, already-configured switch-often termed a brownfield device-under the management of the Juniper Mist cloud. This is distinct from the "claiming" process, which is reserved for greenfield environments where new, factory-default switches are added using a QR code or activation code.
In a brownfield scenario, the switch is typically already in production or has a pre-existing local configuration that must be preserved or integrated into the Mist AI-driven dashboard. To adopt such a switch, the administrator must manually interact with the switch's Command Line Interface (CLI). The Mist portal provides a unique adoption command-a string of Junos OS configuration-that includes the specific URL for the Mist cloud and the organization's unique registration token. Once this command is pasted into the switch's CLI and committed, the switch initiates an outbound connection to the Mist cloud via TCP port 2200 or 443.
Upon successful connection, the switch's status changes from "Unassigned" to "Connected" in the Mist dashboard. This transition allows the Mist AI engine to begin collecting telemetry, monitoring Service Level Expectations (SLEs), and performing automated troubleshooting. While the adoption process allows for
"monitoring only" mode to avoid disrupting existing services, it is the fundamental first step for transitioning legacy Juniper infrastructure into a modern, cloud-managed Wired Assurance environment. This workflow is essential for organizations looking to leverage Marvis AI and automated operations without having to factory- reset their entire existing network.
NEW QUESTION # 62
You are planning to deploy a fabric in your large campus with 10,000+ users. You will have both Layer 2 and Layer 3 devices that connect to your access switches. In this scenario, which campus architecture should you use?
  • A. core-distribution with edge-routed bridging (ERB)
  • B. core-distribution with centrally-routed bridging (CRB)
  • C. EVPN multihoming
  • D. IP Clos
According to Juniper's Validated Designs (JVD) for campus fabrics, the Campus Fabric IP Clos (often referred to as a 5-stage Clos) is the architecture specifically engineered for high-scale environments supporting 10,000+ users. This design is characterized by extending the EVPN control plane and VXLAN data plane all the way to the access layer. By terminating VXLAN tunnels at the access switch-functioning as a Virtual Tunnel Endpoint (VTEP)-the network can seamlessly support both Layer 2 and Layer 3 devices directly at the edge of the fabric.
The primary driver for choosing IP Clos in large-scale deployments is its superior scalability. In this model, the core switches are shielded from the massive table sizes required to learn thousands of individual endpoint MAC and IP addresses. Instead, core devices only need to maintain reachability to the loopback addresses of the access layer switches. This reduction in the "flood and learn" pressure on the core is critical as the number of endpoints grows, ensuring that the core can scale far into the future with predictable growth.
Additionally, the IP Clos architecture provides the most flexible environment for microsegmentation using Group-Based Policies (GBP) and macrosegmentation using Virtual Routing and Forwarding (VRF) instances. Since routing occurs at the access device, "east-west" traffic between local endpoints remains efficient and does not need to traverse the distribution or core tiers. While EVPN Multihoming and Core- Distribution (CRB/ERB) models are effective for smaller sites or brownfield environments where access switches are legacy Layer 2-only devices, only the IP Clos architecture provides the end-to-end VXLAN capability required for high-density, future-proof campus fabrics.
NEW QUESTION # 63
What are the benefits of utilizing site variables in the deployment of wired assurance?
  • A. Reducing the need for manual intervention during setup
  • B. Allowing for dynamic adjustments to network policies
  • C. Enhancing network security by isolating network segments
  • D. Customizing configurations based on local requirements
Answer: A,B,D
NEW QUESTION # 64
Deploying Campus Fabric Architectures often requires:
  • A. A disregard for best practices
  • B. A comprehensive understanding of network design principles
  • C. Sole reliance on outdated technologies
  • D. Guesswork and improvisation
NEW QUESTION # 65
If you start to prapare for the JN0-460 exam from books, then you will find that the content is too broad for you to cope with the exam questions. So, we just pick out the most important knowledge to learn. Through large numbers of practices, you will soon master the core knowledge of the JN0-460 Exam. It is important to review the questions you always choose mistakenly. You should concentrate on finishing all exercises once you are determined to pass the JN0-460 exam. And you will pass for sure as long as you study with our JN0-460 study guide carefully.
Exam JN0-460 Objectives: https://www.prepawayete.com/Juniper/JN0-460-practice-exam-dumps.html
Juniper JN0-460 Dumps Free Download Success & money back guarantee, Juniper JN0-460 Dumps Free Download As we enter into such a competitive world, the hardest part of standing out from the crowd is that your skills are recognized then you will fit into the large and diverse workforce, Our JN0-460 exam guide is not simply a patchwork of exam questions, but has its own system and levels of hierarchy, which can make users improve effectively, Now, I will tell you, our update system is very intelligent, which can send the updated Exam JN0-460 Objectives - Mist AI Wired, Specialist (JNCIS-MistAI-Wired) exam preparatory to your payment email as soon as possible.
Generic makefile for building the sample, Everyone on JN0-460 the team benefits from usability test plans, Success & money back guarantee, As we enter into such a competitive world, the hardest part of standing out from Exam JN0-460 Objectives the crowd is that your skills are recognized then you will fit into the large and diverse workforce.
Mist AI Wired, Specialist (JNCIS-MistAI-Wired) Exam Questions Can Help You Gain Massive Knowledge of JN0-460 CertificationOur JN0-460 Exam Guide is not simply a patchwork of exam questions, but has its own system and levels of hierarchy, which can make users improve effectively, Now, I will tell you, our update system is very intelligent, Exam JN0-460 Objectives which can send the updated Mist AI Wired, Specialist (JNCIS-MistAI-Wired) exam preparatory to your payment email as soon as possible.
And as long as you click on the website, JN0-460 Dumps Free Download you will get quick information about what you want to know.
P.S. Free 2026 Juniper JN0-460 dumps are available on Google Drive shared by PrepAwayETE: https://drive.google.com/open?id=1vwseXr1iWwcT0gL1hRE2bugeB8gRJpfx
Posted at 1/31/2026 03:41:27        Only Author  2#
I’m so grateful for the inspiration in this article, thank you! Free Cuttin g-edge C_BCFIN_2502 resources materials available for all—good luck!
Posted at 4 hour before        Only Author  3#
I’m truly thankful for your article, it was so refreshing. Unlock the door to promotions and salary raises with the free New OGEA-102 associate level exam questions!
