C-BW4H-2505 Passing Score Feedback & Real C-BW4H-2505 Questions
Posted at 10 hour before      View:21 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest RealValidExam C-BW4H-2505 PDF Dumps and C-BW4H-2505 Exam Engine Free Share: https://drive.google.com/open?id=1Drps9Qm_Qj_0eZAA8Qi62-6sl_wGSw1k
The SAP C-BW4H-2505 real questions are an advanced strategy to prepare you according to the test service. You can change the time and type of questions of the SAP C-BW4H-2505 exam dumps. C-BW4H-2505 practice questions improve your confidence and ability to complete the exam timely. We ensure success on the first attempt if you use our SAP C-BW4H-2505 Exam Dumps according to our instructions.
SAP C-BW4H-2505 Exam Syllabus Topics:
  • Data Acquisition into SAP BW
  • 4HANA: This section tests how Data Engineers manage data integration into SAP BW
  • 4HANA from multiple sources. It covers essential knowledge of tools and processes used for data extraction, transformation, and loading into the SAP environment.
  • Native SAP HANA Modeling:This section evaluates the ability of SAP Consultants to describe and apply native modeling options in SAP HANA. It emphasizes understanding how to build optimized data structures directly within the HANA platform.
  • Data Acquisition into SAP HANA: This section evaluates the capacity of SAP Consultants to integrate various data sources into SAP HANA. It assesses their ability to understand different ingestion techniques and ensure data accessibility for processing.
  • SAP BW
  • 4HANA Data Flow: This section of the exam measures the practical ability of SAP Consultants to load data within the SAP BW
  • 4HANA environment. It assesses familiarity with data movement and transformation processes across different layers of the system.
Topic 5
  • InfoObjects and InfoProviders:This section tests the knowledge of Data Engineers in working with InfoObjects and InfoProviders in SAP BW
  • 4HANA. It involves handling data structures used for organizing, storing, and accessing analytical data.
Real C-BW4H-2505 Questions | Exam C-BW4H-2505 OverviewPerhaps you worry about that you have difficulty in understanding our C-BW4H-2505 training questions. Frankly speaking, we have taken all your worries into account. Firstly, all knowledge of the C-BW4H-2505 exam materials have been simplified a lot. Also, we have tested many volunteers who are common people. The results show that our C-BW4H-2505 study braindumps are easy for them to understand. So you don't have to worry that at all and you will pass the exam for sure.
SAP Certified Associate - Data Engineer - SAP BW/4HANA Sample Questions (Q42-Q47):NEW QUESTION # 42
What are some of the variable types in a BW query that can use the processing type SAP HANA Exit? Note:
There are 2 correctanswers to this question.
  • A. Formula
  • B. Hierarchy node
  • C. Characteristic value
  • D. Text
NEW QUESTION # 43
Which are purposes of the Open Operational Data Store layer in the layered scalable architecture (LSA++) of SAP BW/4HANA? Note: There are 2 correctanswers to this question.
  • A. Initial staging of source system data
  • B. Real-time reporting on source system data without staging
  • C. Transformations of data based on business logic
  • D. Harmonization of data from several source systems
NEW QUESTION # 44
You are involved in an SAP BW/4HANA project focusing on General Ledger reporting want to use the SAP ERP stard DataSource OFI_GL_14 (New GL Items) which is not active in your SAP ERP system.
Which transactions can be used to activate this DataSource? Note: There are 2 correct answers to this question.
  • A. Transaction RSDS (DataSource Repository) in the SAP BW/4HANA system
  • B. Transaction RSA2 (DataSource Repository) in the SAP ERP system
  • C. Transaction RSORBCT (Data Warehousing Workbench: BI Content) in the SAP BW/4HANA system
  • D. Transaction RSA5 (Installation of DataSource from Business Content) in the SAP ERP system
To activate a standard DataSource like OFI_GL_14 (New GL Items) in an SAP ERP system, you need to use transactions that are specifically designed for managing and activating DataSources within the ERP system.
Below is a detailed explanation of the correct answers:
* Explanation: This transaction is used in the SAP BW/4HANA system to activate or install BI Content objects such as InfoProviders, Transformations, and DTPs. However, it does not activate DataSources in the source SAP ERP system. Activation of DataSources must occur in the ERP system itself.
* RSORBCT is part of the BW/4HANA environment and is unrelated to activating DataSources in the ERP system.
Option B: Transaction RSA5 (Installation of DataSource from Business Content) in the SAP ERP systemExplanation: RSA5 is used in the SAP ERP system to activate standard DataSources delivered by SAP. When you run this transaction, you can search for and activate specific DataSources, such as OFI_GL_14, from the Business Content. This ensures that the DataSource becomes available for extraction.
Reference: RSA5 is a key transaction for enabling standard DataSources in SAP ERP systems. It is essential for preparing the ERP system to deliver data to SAP BW/4HANA.
Option C: Transaction RSA2 (DataSource Repository) in the SAP ERP systemExplanation: RSA2 provides access to the DataSource repository in the SAP ERP system. While it does not directly activate DataSources, it allows you to view, maintain, and manage the status of DataSources. You can also trigger the activation of DataSources from this transaction.
Reference: RSA2 is often used alongside RSA5 to verify the status of DataSources and ensure they are correctly configured for extraction.
Option D: Transaction RSDS (DataSource Repository) in the SAP BW/4HANA systemExplanation:
RSDS is used in the SAP BW/4HANA system to view and manage DataSources that have been replicated from the source system. However, it cannot activate DataSources in the SAP ERP system. Activation must occur in the ERP system using transactions like RSA5 or RSA2.
Reference: RSDS is limited to managing DataSources within the BW/4HANA environment and does not interact with the ERP system's DataSource activation process.
SummaryTo activate the OFI_GL_14 DataSource in the SAP ERP system:
RSA5: Activates standard DataSources from Business Content.
RSA2: Provides access to the DataSource repository and supports maintenance tasks.
These transactions ensure that the DataSource is properly enabled in the ERP system, allowing it to deliver data to SAP BW/4HANA.
NEW QUESTION # 45
Which SAP solutions can leverage the Write Interface for DataStore objects (advanced) to push data into the inbound table of DataStore objects (advanced)? Note: There are 2 correct answers to this question.
  • A. SAP Process Integration
  • B. SAP Lscape Transformation Replication Server
  • C. SAP Datasphere
  • D. SAP Data Services
TheWrite Interface for DataStore objects (advanced)in SAP BW/4HANA enables external systems to push data directly into theinbound tableof a DataStore object (DSO). This interface is particularly useful for integrating data from various SAP solutions and third-party systems. Below is an explanation of the correct answers and why they are valid.
* A. SAP Process Integration
* SAP Process Integration (PI), now known asSAP Cloud Integration (CI), is a middleware solution that facilitates seamless integration between different systems. It can leverage the Write Interface to push data into the inbound table of a DataStore object (advanced).
* SAP PI/CI supports various protocols and formats (e.g., IDoc, SOAP, REST) to transfer data, making it a versatile tool for integrating SAP BW/4HANA with other systems.
* SAP PI/CI is widely used in enterprise landscapes to connect SAP BW/4HANA with external systems, including pushing data via the Write Interface.
D). SAP Datasphere
SAP Datasphere(formerly known as SAP Data Warehouse Cloud) is a cloud-based data management solution that integrates seamlessly with SAP BW/4HANA. It can use the Write Interface to push data into the inbound table of a DataStore object (advanced).
SAP Datasphere is designed for hybrid and cloud-first architectures, enabling organizations to consolidate and harmonize data across on-premise and cloud environments.
Reference: SAP Datasphere leverages the Write Interface to enable real-time or near-real-time data integration with SAP BW/4HANA, supporting modern data warehousing requirements.
Incorrect Options:B. SAP Lscape Transformation Replication Server
SAP Landscape Transformation Replication Server (SLT)is primarily used for real-time replication of data from SAP ERP systems to SAP HANA or other target systems. While SLT is a powerful tool for data replication, it does not directly use the Write Interface for DataStore objects (advanced).
Instead, SLT replicates data at the database level, bypassing the need for the Write Interface.
Reference: SLT operates independently of the Write Interface and is not listed as a supported solution for pushing data into DSOs.
C). SAP Data Services
SAP Data Servicesis an ETL (Extract, Transform, Load) tool used for data integration and transformation.
While it can load data into SAP BW/4HANA, it does not use the Write Interface for DataStore objects (advanced).
Instead, SAP Data Services typically loads data into staging areas or directly into target objects using standard ETL processes.
Reference: SAP Data Services is not designed to interact with the Write Interface, as it relies on its own mechanisms for data loading.
Conclusion:The correct answers areA. SAP Process IntegrationandD. SAP Datasphere, as these solutions are explicitly designed to leverage the Write Interface for DataStore objects (advanced) in SAP BW/4HANA.
They enable seamless integration and data transfer between external systems and SAP BW/4HANA.
NEW QUESTION # 46
Which data deletion options are offered for a Standard DataStore Object (advanced)?Note: There are 3 correctanswers to this question.
  • A. Selective deletion of data
  • B. Selective deletion including data of subsequent targets
  • C. Deletion of data from all tables
  • D. Deletion of all data from active table only
  • E. Request-based data deletion
Answer: A,C,D
NEW QUESTION # 47
You should make progress to get what you want and move fast if you are a man with ambition. At the same time you will find that a wonderful aid will shorten your time greatly. To get the C-BW4H-2505 certification is considered as the most direct-viewing way to make big change in your professional profile, and we are the exact C-BW4H-2505 Exam Braindumps vendor. If you have a try on our free demos of our C-BW4H-2505 study guide, you will choose us!
Real C-BW4H-2505 Questions: https://www.realvalidexam.com/C-BW4H-2505-real-exam-dumps.html
P.S. Free & New C-BW4H-2505 dumps are available on Google Drive shared by RealValidExam: https://drive.google.com/open?id=1Drps9Qm_Qj_0eZAA8Qi62-6sl_wGSw1k
