[General] New MB-500 Exam Practice - MB-500 Latest Test Format
【General】 New MB-500 Exam Practice - MB-500 Latest Test Format
Posted at 2 hour before      View:14 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ValidTorrent MB-500 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=18uLGdwWjtstSBbd325hKK0x6Lq-Ya1b2
As a dumps provider, ValidTorrent have a good reputation in the field. We are equipped with a team of IT elites who do much study in the Microsoft test questions and training materials. We check the updating of MB-500 Dumps PDF everyday to make sure you pass MB-500 valid test easily. The pass rate will be 100%.
Microsoft Dynamics 365 Finance and Operations Apps Developer certification is ideal for professionals who want to specialize in Finance and Operations apps development. Microsoft Dynamics 365: Finance and Operations Apps Developer certification demonstrates the candidate's proficiency in developing and customizing the Finance and Operations modules of Dynamics 365. MB-500 Exam covers various topics such as designing and developing customizations, creating and modifying workflows, and integrating with other applications.
Skills measured
  • Design and develop AOT elements (20-25%)
  • Develop and test code (10-15%)
  • Apply developer tools (10-15%)
  • Plan architecture and solution design (10-15%)
  • Integrate and manage data solutions (10-15%)
  • Implement reporting (10-15%)
Microsoft MB-500 Latest Test Format & Valid MB-500 Study NotesOne of the major features provided by Microsoft is that it will provide you with free Microsoft MB-500 actual questions updates for 365 days after the purchase of our product. If you work hard with our Microsoft MB-500 Exam Practice material, nothing can stop you from cracking the test on the first endeavor.
Passing the Microsoft MB-500 Exam is a great way to demonstrate your skills and knowledge in Dynamics 365 Finance and Operations apps development. Microsoft Dynamics 365: Finance and Operations Apps Developer certification can help you stand out in a competitive job market and increase your earning potential. Microsoft Dynamics 365: Finance and Operations Apps Developer certification is also recognized by employers and customers as a sign of credibility and expertise in Dynamics 365.
Microsoft Dynamics 365: Finance and Operations Apps Developer Sample Questions (Q173-Q178):NEW QUESTION # 173
You need to set up a recurring integration to enable file exchanges between Dynamics 365 Finance and a third-party system.
In which order should you perform the actions? To answer, move all actions from the list of actions to the answer area and arrange them in the correct order.
1. Set up a data project -
2. Create recurring data job -
3. Link a new application ID to the data recurring job -
4. Specify whether you are using a file or a data package -
5. Set up the processing recurrence
https://docs.microsoft.com/en-us ... ntegrations#create-
NEW QUESTION # 174
A company has an extension that makes changes to a base form.
You need to identify all extension changes made to the base form.
What are two possible ways to achieve the goal? Each correct answer presents a complete solution.
  • A. In the search bar on the base form, enter the text e:.
  • B. In the search bar on the form extension element, enter the text c:
  • C. Right-click the base form and select view references
  • D. In the search bar on the base form, enter the text c:.
  • E. In search bar on the form extension element, enter the text e:
Answer: C,E
A: Customization and Extension
B: Example: Navigate to FMRental.Extension in the Tree Designer
1. In the Visual Studio, in Solution Explorer, in the FleetManagement Discounts project, expand User Interface > Form Extensions.
The FMRental.Extension element is an extension element that extends the functionality of the FMRental form by adding two new data sources and a new tab control.
2. In Solution Explorer, double-click FMRental.Extension to open the designer.
3. In the designer's search box, type 'e:' as shown in the image below. This filters the current designer to only show nodes that belong to the current extension.
https://docs.microsoft.com/en-us ... elements-extensions
NEW QUESTION # 175
A company has a Dynamics 365 Finance and Operations environment.
You need to implement indices for new tables.
Which types of indexes should you use? To answer, drag the appropriate types of indexes to the correct requirements. Each type of index may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
Box 1: Primary
Box 2: Clustered
A clustered index is a special type of index that reorders the way records in the table are physically stored.
Box 3: Non-clustered
https://docs.microsoft.com/en-us ... d-indexes-described
NEW QUESTION # 176
A company has a cloud-based installation of Dynamics 365 Finance. The company also has Dynamics 365 Sales and Customer Service systems.
The company implements an analytical reports solution.
You need to select the applicable storage feature for each requirement.
Which storage feature should you use to meet each requirement? To answer, drag the appropriate storage options to the correct requirements. Each storage option may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
NEW QUESTION # 177
A user reports slow response times in the application when accessing the production environment.
You need to diagnose the performance issue by using the Environment monitoring tool.
Which two features of the Customization analysis should you use? Each correct answer presents part of the solution.
  • A. SQL insights
  • B. Availability monitoring
  • C. Customization analysis
  • D. Health metrics
  • E. System diagnostics
Answer: A,D
NEW QUESTION # 178
MB-500 Latest Test Format: https://www.validtorrent.com/MB-500-valid-exam-torrent.html
