[General] Latest 1Z0-1109-25 Test Answers - Reliable 1Z0-1109-25 Test Experience
123
【General】 Latest 1Z0-1109-25 Test Answers - Reliable 1Z0-1109-25 Test Experience
Posted at 1/14/2026 11:41:21      View:135 | Replies:2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Free4Torrent 1Z0-1109-25 dumps from Cloud Storage: https://drive.google.com/open?id=12C1rzje46vTb1dFn2eUF8t1w51UXpNFn
The learning material is available in three different easy-to-use formats. The first one is a 1Z0-1109-25 PDF dumps form and it is a printable and portable form. Users can save the notes by taking out prints of Oracle 1Z0-1109-25 PDF questions or can access them via their smartphones, tablets, and laptops. The Oracle 1Z0-1109-25 Pdf Dumps form can be used anywhere anytime and is essential for students who like to learn from their smart devices.
Oracle 1Z0-1109-25 Exam Syllabus Topics:
  • Understand DevOps Principles and Effectively Work with Containerization Services: This section of the exam measures the skills of DevOps Engineers and Cloud Architects in applying DevOps methodologies and containerization practices. It covers implementing a microservices architecture, creating Docker containers, and managing Oracle Cloud Infrastructure Registry (OCIR) and Container Instances to streamline application deployment and scalability.
  • Enabling DevSecOps: This domain measures the skills of Security Engineers and DevSecOps Practitioners in integrating security into DevOps workflows. It includes managing encryption keys with OCI Vault, securing CI
  • CD pipelines, and ensuring container image security to align with DevSecOps best practices.
  • Configuring and Managing Continuous Integration and Continuous Delivery (CI
  • CD): This section tests the knowledge of CI
  • CD Engineers and Automation Specialists in automating the software lifecycle using OCI DevOps Service. It includes managing source code repositories, configuring build
  • deployment pipelines, and creating artifacts for automated deployments across environments.
  • Using Code and Templates for Provisioning and Configuring Infrastructure: This domain evaluates the expertise of DevOps Engineers and Infrastructure Architects in deploying infrastructure using Infrastructure as Code (IaC) tools like Terraform. It focuses on automating resource provisioning with OCI Resource Manager to ensure consistent and efficient infrastructure setups.
Oracle Latest 1Z0-1109-25 Test Answers & Free4Torrent - Leading Provider in Certification Exams MaterialsMany job-hunters want to gain the competition advantages in the labor market and become the hottest people which the companies rush to get. But if they want to realize that they must boost some valuable 1Z0-1109-25 certificate to raise their values and positions in the labor market. our 1Z0-1109-25 Study Guide is becoming increasingly obvious degree of helping the exam candidates with passing rate up to 98 to 100 percent. All details of the 1Z0-1109-25 exam questions are developed to aim squarely at improving your chance of success.
Oracle Cloud Infrastructure 2025 DevOps Professional Sample Questions (Q30-Q35):NEW QUESTION # 30
What are the two items required to create a rule for the Oracle Cloud Infrastructure Events Service? (Choose two.)
  • A. Service Connector
  • B. Actions
  • C. Rule Conditions
  • D. Management Agent Cloud Service
  • E. Auth Token
Oracle Cloud Infrastructure (OCI) Events Service allows you to create rules to automatically respond to changes in your OCI environment. To create a rule, you need the following items:
Rule Conditions: Conditions define the events that will trigger the rule. This specifies what event (e.g., instance creation, object storage bucket modification) will trigger an action.
Actions: Actions define what should happen when a condition is met. For example, the action might be to trigger an OCI Function or send a notification.
NEW QUESTION # 31
What is the correct approach to upgrade an Oracle Container Engine for Kubernetes (OKE) Cluster to a newer version of Kubernetes?
  • A. Upgrade the node pools one at a time, then once all node pools are upgraded, upgrade the control plane.
  • B. Initiate the automated upgrade process using the OCI Console, CLI, or API.
  • C. Upgrade the control plane, then upgrade the node pools.
  • D. Initiate the control plane and node pool upgrades simultaneously.
The correct approach to upgrade an Oracle Container Engine for Kubernetes (OKE) cluster involves first upgrading the Kubernetes control plane, followed by upgrading the node pools. The control plane must be upgraded first to ensure compatibility with newer versions of Kubernetes, as node pools rely on the control plane for orchestration and management.
After upgrading the control plane, each node pool is upgraded to match the new Kubernetes version. This phased approach ensures the cluster remains in a stable state during the upgrade.
NEW QUESTION # 32
How can you scale a deployment named nodejs-deployment to have two replicas?
  • A. kubectl set replicas deployment nodejs-deployment --replicas=2
  • B. kubectl adjust deployment nodejs-deployment --replicas=2
  • C. kubectl resize deployment nodejs-deployment --replicas=2
  • D. kubectl scale deployment nodejs-deployment --replicas=2
The kubectl scale command is used to scale the number of replicas in a deployment. By specifying the --replicas flag, you define the desired number of replicas for the deployment.
(kubectl set replicas) is not the correct syntax for scaling a deployment.
(kubectl resize) is not a valid command for scaling a deployment.
(kubectl adjust) is also not a valid Kubernetes command.
NEW QUESTION # 33
You're using Oracle Cloud Infrastructure (OCI) DevOps to automate your application deployment for frequent releases. In one of your automation steps, you'll create a deployment pipeline.
What does this deployment pipeline do in OCI DevOps?
  • A. It is used to store, manage, develop source code with OCI DevOps Code Repositories.
  • B. It is a set of stages for your build process for building, testing and compiling software artifacts.
  • C. It takes a commit ID from your source code repositories and uses that source code to run your build instructions.
  • D. It is a sequence of steps for delivering and deploying your artifacts to a target environment.
A deployment pipeline in OCI DevOps is used to automate the deployment of application artifacts to a target environment. It is a sequence of stages that includes steps such as approvals, traffic shifts, manual interventions, and the actual deployment of the artifacts to environments like Kubernetes clusters or compute instances.
NEW QUESTION # 34
You are a DevOps engineer working on a project that requires you to push and pull Docker images to and from Oracle Cloud Infrastructure Registry (Container Registry) using Docker CLI. You have been given access to Container Registry and have installed Docker CLI on your local machine.
Which should you create and use to securely authenticate and store your Docker image in a private Docker registry in OCI?
  • A. JSON Web Token
  • B. Master Encryption Key in OCI Vault
  • C. Auth Token
  • D. SSH Key Pair
To authenticate with the Oracle Cloud Infrastructure Registry (Container Registry) when using the Docker CLI, you need to use an Auth Token. The Auth Token is created in the OCI console and acts as a password for the Docker login command, providing secure access to the container registry.
NEW QUESTION # 35
As is known to all, 1Z0-1109-25 practice guide simulation plays an important part in the success of exams. By simulation, you can get the hang of the situation of the real exam with the help of our free demo. Simulation of our 1Z0-1109-25 training materials make it possible to have a clear understanding of what your strong points and weak points are and at the same time, you can learn comprehensively about the 1Z0-1109-25 Exam. By combining the two aspects, you are more likely to achieve high grades.
Reliable 1Z0-1109-25 Test Experience: https://www.free4torrent.com/1Z0-1109-25-braindumps-torrent.html
What's more, part of that Free4Torrent 1Z0-1109-25 dumps now are free: https://drive.google.com/open?id=12C1rzje46vTb1dFn2eUF8t1w51UXpNFn
Posted at 2/16/2026 03:35:58        Only Author  2#
Your article is a work of art, thank you for sharing it with us! Free PAP-001 valid test guide study resources available for all—good luck!
Posted at yesterday 21:26        Only Author  3#
The content is excellent, so I’m liking it now. I hope the PSE-Prisma-Pro-24 valid study questions files content helps you, and it's totally free.
