Salesforce Plat-Con-201考試證照 - Plat-Con-201最新考證
Posted at 1/21/2026 21:44:14
我們承諾,使用我們PDFExamDumps Salesforce的Plat-Con-201的考試培訓資料,確保你在你的第一次嘗試中通過測試,如果你準備考試使用我們PDFExamDumps Salesforce的Plat-Con-201考試培訓資料,我們保證你通過,如果沒有通過測試,我們給你退還購買的全額退款,送你一個相同價值的免費產品。
PDFExamDumps題供了不同培訓工具和資源來準備Salesforce的Plat-Con-201考試,編制指南包括課程,實踐的檢驗,測試引擎和部分免費PDF下載,我們的考題及答案反應的問題問Salesforce的Plat-Con-201考試。
最新的Plat-Con-201考試證照,Salesforce Plat-Con-201最新考證PDFExamDumps是促使IT人士成功的最好的催化劑。很多人通過了IT相關認證考試的人就是使用了我們的PDFExamDumps的培訓工具。我們的PDFExamDumps的專家團隊利用自己的經驗為參加Salesforce Plat-Con-201 認證考試的很多人研究出了最新的有效的培訓工具,包括Salesforce Plat-Con-201 認證考試測試,考前試題,試題答案。我們的PDFExamDumps提供的試題及答案和真正的試題有95%的相似性。使用PDFExamDumps的培訓工具,您的Salesforce Plat-Con-201 認證考試是可以很輕鬆的通過的。
最新的 Salesforce Consultant Plat-Con-201 免費考試真題 (Q72-Q77):問題 #72
A consultant has a project with the following requirement: "Agents need to follow a standard customer greeti.... script in order to ensure brand consistency." Which OmniScript element should the consultant recommend to ensure the agents can see and follow these standard scripts?
- A. Text Area
- B. Step
- C. Headline
- D. Input Block
答案:C
解題說明:
The consultant should recommend using a Headline element to ensure the agents can see and follow these standard scripts. A Headline element can display a text message with an icon and a color, such as blue for information or yellow for warning. The consultant can use a Headline element to show the customer greeting script in the OmniScript, and instruct the agents to read it aloud
問題 #73
A company is creating a FlexCard for agents to respond to account inquiries. The company has decided to lim actions on the card to the three most frequent and important actions users typically take.
Based on the user analysis exhibit shown below, which three actions should appear on the card?
Choose 3 answers
- A. Request higher limit
- B. View credit score history
- C. Make a payment
- D. View statements
- E. Verify a transaction
答案:A,C,E
解題說明:
Based on the user analysis exhibit, the three actions that should appear on the card are: verify a transaction, request higher limit, and make a payment. These actions have the highest frequency and importance scores among the six actions listed. The other actions, such as view credit score history, view statements, and view rewards, have lower frequency and importance scores, and can be accessed through other means
問題 #74
A consultant is working with a client who wants to create guided interactions using data from their Salesforce org and external sources.
Which Omnistudio tool should the consultant recommend for creating these guided interactions?
- A. Data Mappers
- B. Flexcards
- C. Omniseripts
- D. Integration Procedures
答案:C
解題說明:
The requirement is to create "guided interactions" that utilize data from both a Salesforce org and external sources. In Salesforce OmniStudio, OmniScripts is the tool specifically designed for building interactive, guided processes that lead users through a series of steps, integrating and displaying data from multiple sources, including Salesforce and external systems.
Here's why C. OmniScripts is the correct answer:
* Purpose of OmniScripts: OmniScripts are a core OmniStudio component used to create structured, step- by-step user experiences (guided interactions) that can incorporate data from Salesforce objects and external systems. They enable consultants to design dynamic, interactive interfaces with elements like text inputs, picklists, and buttons, guiding users through processes such as filling out forms, updating records, or completing workflows. OmniScripts support integration with other OmniStudio tools (e.g., DataRaptors and Integration Procedures) to fetch and manipulate data, making them ideal for this scenario.
* Handling Data from Multiple Sources:
* Salesforce Data: OmniScripts can use DataRaptors to extract or update data from Salesforce objects (e.g., retrieving Account details or updating a Case).
* External Sources: OmniScripts can leverage Integration Procedures to call external APIs or systems (e.g., pulling customer data from an ERP system) and then display or process that data within the script.For example, an OmniScript could guide a user to input customer information, fetch related Salesforce records using a DataRaptor Extract, and retrieve payment history from an external API via an Integration Procedure-all within a single, cohesive interaction.
* Guided Interaction Features: OmniScripts offer a drag-and-drop designer with elements like Steps, Inputs, and Actions, allowing consultants to craft a logical flow. Features like conditional visibility, validation rules, and navigation controls ensure the interaction is guided and user-friendly, meeting the client's need for a structured experience.
Now, let's examine why the other options are incorrect:
* A. FlexCards: FlexCards are designed to display data in a concise, card-based format (e.g., a summary of customer details or case status). While they can pull data from Salesforce and external sources (via DataRaptors or Integration Procedures), they are primarily read-only or lightly interactive displays, not tools for creating multi-step guided interactions. FlexCards are better suited for dashboards or quick views, not for guiding users through a process like data entry or decision-making.
* B. Integration Procedures: Integration Procedures are powerful tools in OmniStudio for orchestrating complex data operations, such as calling external REST APIs, transforming data, or chaining multiple actions. However, they are backend processes, not user-facing tools. They don't provide a UI or guided interaction framework-they support OmniScripts or FlexCards by supplying the data or logic needed.
Thus, they're a component of the solution, not the primary tool for guided interactions.
* D. Data Mappers: Data Mappers (likely a typo for "DataRaptors" in OmniStudio context) are used to extract, transform, load, or post data between Salesforce and OmniStudio components. For example, a DataRaptor Extract pulls Salesforce data, while a DataRaptor Turbo Extract maps it to JSON. However, DataRaptors are data-handling tools, not UI components. They can't create guided interactions on their own-they provide the data that OmniScripts or FlexCards use.
Why OmniScripts Stand Out:
OmniScripts are uniquely suited for this requirement because they combine a user interface with data integration capabilities. For instance, a consultant could design an OmniScript to:
* Display a welcome step with customer data fetched from Salesforce (via DataRaptor).
* Prompt the user to enter additional details, validated in real-time.
* Integrate external data (e.g., order status from a third-party system) using an Integration Procedure.
* Save all data back to Salesforce or the external system upon completion.This aligns perfectly with the need for "guided interactions" using data from multiple sources.
* Salesforce OmniStudio Documentation: OmniScripts Overview - Describes OmniScripts as the tool for building guided processes with integrated data.
* Salesforce OmniStudio Developer Guide: OmniScript Designer - Details how OmniScripts support Salesforce and external data sources.
* Salesforce Help: Comparing OmniStudio Tools - Clarifies FlexCards for display, Integration Procedures for backend logic, and DataRaptors for data mapping, versus OmniScripts for guided interactions.
問題 #75
Which two functions can be performed by DataRaptors?
Choose 2 answers
- A. Transform data
- B. Combine requests into a single response
- C. Read and write data to Salesforce
- D. Read and write data to external systems
答案:A,C
解題說明:
DataRaptors are OmniStudio data tools that can perform various functions on data, such as reading, writing, transforming, and validating. They can work with Salesforce data and external data sources. The two functions that can be performed by DataRaptors are:
* Transform data: DataRaptors can use transformation rules to manipulate data, such as changing the format, applying calculations, mapping values, etc.
* Read and write data to Salesforce: DataRaptors can use SOQL or SOSL queries to read data from Salesforce objects and fields, and use DML operations to insert, update, delete, or upsert data to Salesforce.
The functions that cannot be performed by DataRaptors are:
* Combine requests into a single response: DataRaptors cannot aggregate multiple requests from different sources into one response. This can be done using Integration Procedures, which can orchestrate multiple DataRaptors or REST calls into a single process.
* Read and write data to external systems: DataRaptors cannot directly access external systems or APIs.
They need to use Integration Procedures or REST elements to invoke external services and pass the data to or from DataRaptors.
問題 #76
What business problem does DataRaptor solve?
- A. It guides humans through a complex business process.
- B. It combines multiple steps and processes into a single server call.
- C. lt removes the need to code data mappings for data transformations.
- D. It allows developers to create complex API queries declaratively.
答案:C
解題說明:
The business problem that DataRaptor solves is that it removes the need to code data mappings for data transformations. DataRaptor allows the designer to declaratively define how data is read, transformed, and written between Salesforce and external systems. It does not allow developers to create complex API queries declaratively, as this is done by Integration Procedures. It does not combine multiple steps and processes into a single server call, as this is done by Calculation Procedures. It does not guide humans through a complex business process, as this is done by OmniScripts.
問題 #77
在你還在猶豫選擇我們PDFExamDumps之前,你可以先嘗試在我們PDFExamDumps免費下載我們為你提供的關於Salesforce Plat-Con-201認證考試的部分考題及答案。這樣,你就可以知道我們PDFExamDumps的可靠性。我們PDFExamDumps也會是你通過Salesforce Plat-Con-201認證考試最好的選擇,我們PDFExamDumps是你通過Salesforce Plat-Con-201認證考試最好的保證。你選擇了我們PDFExamDumps,就等於選擇了成功。
Plat-Con-201最新考證: https://www.pdfexamdumps.com/Plat-Con-201_valid-braindumps.html
Salesforce Plat-Con-201 認證考試已經成為了IT行業中很熱門的一個考試,但是為了通過考試需要花很多時間和精力掌握好相關專業知識,或者你也是IT人士,卻沒收穫那樣的成果,不要擔心,我們PDFExamDumps Salesforce的Plat-Con-201考試認證資料能幫助你得到你想要的,選擇了我們等於選擇了成功,您也可以在PDFExamDumps免費下載部分關於Salesforce Plat-Con-201考試的考題和答案,Salesforce Plat-Con-201最新考證的考試怎麼樣呢,現在Examkiller Salesforce Plat-Con-201最新考證-Plat-Con-201最新考證學習指南來幫助妳解決這個問題,唉,還好用了PDFExamDumps Plat-Con-201最新考證的題庫,終於過了。
請柳姑娘和本官去城外壹趟,正是江南六大惡之壹的那個鄧寒,Salesforce Plat-Con-201 認證考試已經成為了IT行業中很熱門的一個考試,但是為了通過考試需要花很多時間和精力掌握好相關專業知識,或者你也是IT人士,卻沒收穫那樣的成果,不要擔心,我們PDFExamDumps Salesforce的Plat-Con-201考試認證資料能幫助你得到你想要的,選擇了我們等於選擇了成功。
最好的Plat-Con-201考試證照和資格考試中的領先材料提供者和值得信賴的Plat-Con-201最新考證您也可以在PDFExamDumps免費下載部分關於Salesforce Plat-Con-201考試的考題和答案,Salesforce的考試怎麼樣呢,現在Examkiller Salesforce-Salesforce Consultant學習指南來幫助妳解決這個問題。
- Plat-Con-201考試重點 ⌛ Plat-Con-201考題 🏢 Plat-Con-201最新題庫 🧍 免費下載[ Plat-Con-201 ]只需在{ [url]www.pdfexamdumps.com }上搜索Plat-Con-201考試資訊[/url]
- 100%通過的Plat-Con-201考試證照,最好的考試資料幫助妳壹次性通過Plat-Con-201考試 🍸 來自網站「 [url]www.newdumpspdf.com 」打開並搜索➡ Plat-Con-201 ️⬅️免費下載Plat-Con-201通過考試[/url]
- Plat-Con-201考試證照:Salesforce Certified Omnistudio Consultant|Salesforce Plat-Con-201最佳途徑 🕍 打開網站⇛ [url]www.pdfexamdumps.com ⇚搜索➤ Plat-Con-201 ⮘免費下載Plat-Con-201通過考試[/url]
- 100%通過的Plat-Con-201考試證照,最好的考試資料幫助妳壹次性通過Plat-Con-201考試 🍓 “ [url]www.newdumpspdf.com ”網站搜索( Plat-Con-201 )並免費下載Plat-Con-201認證指南[/url]
- Plat-Con-201證照信息 🛫 Plat-Con-201考試資訊 🐤 Plat-Con-201考題 🍔 在➠ [url]www.kaoguti.com 🠰上搜索➽ Plat-Con-201 🢪並獲取免費下載Plat-Con-201通過考試[/url]
- 熱門的Plat-Con-201考試證照,Salesforce Salesforce Consultant認證Plat-Con-201考試題庫提供免費下載 🌸 透過➡ [url]www.newdumpspdf.com ️⬅️搜索➥ Plat-Con-201 🡄免費下載考試資料Plat-Con-201考古題[/url]
- 熱門的Plat-Con-201考試證照,Salesforce Salesforce Consultant認證Plat-Con-201考試題庫提供免費下載 🔒 ➽ tw.fast2test.com 🢪網站搜索⮆ Plat-Con-201 ⮄並免費下載Plat-Con-201證照考試
- Plat-Con-201題庫 🅰 Plat-Con-201最新題庫資源 🅰 Plat-Con-201考題 ⭕ 立即在▷ [url]www.newdumpspdf.com ◁上搜尋➡ Plat-Con-201 ️⬅️並免費下載Plat-Con-201證照信息[/url]
- 熱門的Plat-Con-201考試證照&頂尖的 Salesforce認證培訓 - 有用的Salesforce Salesforce Certified Omnistudio Consultant 😬 在⮆ [url]www.kaoguti.com ⮄網站下載免費[ Plat-Con-201 ]題庫收集Plat-Con-201考題[/url]
- 最新的Plat-Con-201認證考試資料 🍚 立即打開( [url]www.newdumpspdf.com )並搜索➽ Plat-Con-201 🢪以獲取免費下載Plat-Con-201認證考試[/url]
- 100%通過的Plat-Con-201考試證照,最好的考試資料幫助妳壹次性通過Plat-Con-201考試 🗻 在⮆ [url]www.pdfexamdumps.com ⮄上搜索➥ Plat-Con-201 🡄並獲取免費下載Plat-Con-201證照信息[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.mixcloud.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
