Get Success in the Upcoming Oracle 1z0-1077-25 Exam with Confidence
Posted at 2/20/2026 19:12:03
What's more, part of that DumpsValid 1z0-1077-25 dumps now are free: https://drive.google.com/open?id=15cjoXCa7XXpJ2c6R0FNOqPOpeC6ZXTgd
As is known to us, a suitable learning plan is very important for all people. For the sake of more competitive, it is very necessary for you to make a learning plan. We believe that our 1z0-1077-25 actual exam will help you make a good learning plan. You can have a model test in limited time by our 1z0-1077-25 Study Materials, if you finish the model test, our system will generate a report according to your performance. And in this way, you can have the best pass percentage on your 1z0-1077-25 exam.
Our DumpsValid will provide you with the most satisfying after sales service. We provide one-year free update service to you one year after you have purchased 1z0-1077-25 exam software., which can make you have a full understanding of the latest and complete 1z0-1077-25 Questions so that you can be confident to pass the exam. If you are unlucky to fail 1z0-1077-25 exam for the first time, we will give you a full refund of the cost you purchased our dump to make up your loss.
2026 New 1z0-1077-25 Exam Online | High-quality 100% Free Valid 1z0-1077-25 Study MaterialsFor candidates who are going to purchasing 1z0-1077-25 learning materials online, they may pay more attention to money safety. If you choose us, we can provide you with a clean and safe online shopping environment. We apply the international recognition third party for the payment of 1z0-1077-25 exam baindumps, and therefore your money and account safety can be guaranteed. Moreover, 1z0-1077-25 Exam Dumps are high-quality, and you can pass the exam successfully. We offer you free update for 365 days afterpurchasing, and the update version for 1z0-1077-25 learning materials will be sent to your email automatically.
Oracle Order Management Cloud Order to Cash 2025Implementation Professional Sample Questions (Q26-Q31):NEW QUESTION # 26
Your client is struggling with fulfilling multiple customer order-demands with the most cost effective source, including not only the item cost, but shipping and transfer associated costs as well.
Which Global Order Promising mode allows you to override the normally used source by considering the item cost in your organization, transfer-cost between internal organization, and inbound transit cost from a supplier?
- A. Supply-chain-search
- B. Bills-of-distribution
- C. Profitable-to-promise
- D. Capable-to-promise
Profitable-to-promise (PTP) is a Global Order Promising mode that allows you to override the normally used source by considering the item cost in your organization, transfer-cost between internal organization, and inbound transit cost from a supplier. PTP selects the most profitable fulfillment location that meets the customer's needs, by comparing the total cost and revenue of each potential source. PTP can also factor in the impact of discounts, taxes, and currency conversions on the profitability of each source.
Global Order Promising Data Sheet
Oracle Fusion Cloud Order Management Global Order Promising Solution Brief
4 Stages of Oracle Global Order Promising (GOP) in Make-to-Order Production Systems
NEW QUESTION # 27
Which statement is true about the definition of source systems in Functional Setup manager?
- A. All external order capture systems are defined as Spoke systems and the Fusion fulfillment system is defined as Fusion.
- B. The Oracle Fusion order capture and fulfillment system is defined as Fusion.
- C. All external order capture systems are defined as Spoke systems and external fulfillment systems are defined as purchased.
- D. All order capture and fulfillment systems are defined as Spoke systems.
You can specify whether the source system is a spoke system, such as a legacy system, or a purchased system, such as data from a third party provider. Type can be only 'Spoke' or 'Purchased'. There is no type called
'Fusion'.
NEW QUESTION # 28
You want to decrease the implementation time for Order Management by using the Quick Start feature. Select the accurate list of four areas that you can configure by using the Quick Start feature.
- A. Default general shipping parameters, objects in order management parameters, objects in advanced fulfillment, and orchestration process for shipping and returning an order
- B. Objects in receiving, objects in advanced fulfillment, default pick release attributes for the shipping parameters of inventory facilities, and orchestration process for shipping and returning an order
- C. Default general shipping parameters, objects in receiving, default pick release attributes for the shipping parameters of inventory facilities, and orchestration process for shipping and returning an order
- D. Objects in advanced fulfillment, default pick release attributes for the shipping parameters of inventory facilities, objects in receiving, objects in order management parameters
- E. Default general shipping parameters, objects in order management parameters, default pick release attributes for the shipping parameters of inventory facilities, and orchestration process for shipping and returning an order
NEW QUESTION # 29
How can split fulfillment lines in Order Management be managed independently?
- A. Split fulfillment lines can be managed independently because they have different attributes.
- B. Split fulfillment lines cannot be managed independently.
- C. Split fulfillment lines can be managed with an orchestration process instance that has been created for them.
- D. Split fulfillment lines can be managed independently because they are often being shipped from different warehouses.
NEW QUESTION # 30
You have scheduled a group of 60 sales order lines on a single order and have received promising results from Global Order Promising. Using the Sales Order Fulfillment View, you perform a Check Availability for all lines after 10 minutes and now get a revised promising result. You want to compare the two results to check which option was closer to your promising results.
Which option is NOT a built-in metric for comparisons?
- A. Substitute item usage
- B. Delay results
- C. On-time results (example: number of lines promised on time)
- D. Total fulfillment cost
- E. Total margin
Answer: E
Oracle Order Management Cloud Order to Cash provides several built-in metrics for comparing promising results, such as substitute item usage, total fulfillment cost, on-time results, and delay results1. However, total margin is not one of them. Total margin is a financial metric that measures the profitability of a sales order, but it is not directly related to the availability or fulfillment of the order.
How Order-to-Cash Works in Order Management
NEW QUESTION # 31
You can take advantage of several perks if you buy DumpsValid’s bundle package of Oracle 1z0-1077-25 dumps. The bundle package is cost-effective and includes all three formats of Oracle Order Management Cloud Order to Cash 2025Implementation Professional exam preparation material Oracle 1z0-1077-25 PDF Dumps Questions Answers, and Oracle 1z0-1077-25 Practice Test software (online and offline). Oracle 1z0-1077-25 Dumps are worth trying while preparing for the exam. You will be sure of what Oracle 1z0-1077-25 exam questions will be asked in the exam.
Valid 1z0-1077-25 Study Materials: https://www.dumpsvalid.com/1z0-1077-25-still-valid-exam.html
#1.Select Product, What's more, our Valid 1z0-1077-25 Study Materials - Oracle Order Management Cloud Order to Cash 2025Implementation Professionalstudy material carries out a series of discounts so as to feedback our customers, This is enough to demonstrate that your choice for 1z0-1077-25 torrent VCE is absolutely correct, If you use the PDF version you can print our Valid 1z0-1077-25 Study Materials - Oracle Order Management Cloud Order to Cash 2025Implementation Professional test torrent on the papers and it is convenient for you to take notes, Revision of your 1z0-1077-25 exam learning is as essential as the preparation.
Find realistic answers to your most crucial questions.get from the trenches" insights 1z0-1077-25 that save you money.learn to drive more value faster, Items that do count against your free storage include photos and videos in the Camera Roll;
Pass Guaranteed Latest Oracle - New 1z0-1077-25 Exam Online#1.Select Product, What's more, our Oracle Order Management Cloud Order to Cash 2025Implementation Professionalstudy material carries out a series of discounts so as to feedback our customers, This is enough to demonstrate that your choice for 1z0-1077-25 Torrent VCE is absolutely correct.
If you use the PDF version you can print our Oracle Order Management Cloud Order to Cash 2025Implementation Professional test torrent on the papers and it is convenient for you to take notes, Revision of your 1z0-1077-25 exam learning is as essential as the preparation.
- Free PDF Quiz Oracle - 1z0-1077-25 –Valid New Exam Online 🍡 Simply search for ☀ 1z0-1077-25 ️☀️ for free download on ➤ [url]www.pdfdumps.com ⮘ 👒Valid 1z0-1077-25 Exam Dumps[/url]
- 1z0-1077-25 Prep Exam - 1z0-1077-25 Latest Torrent - 1z0-1077-25 Training Guide 🎷 Search for ➥ 1z0-1077-25 🡄 and download it for free on ➽ [url]www.pdfvce.com 🢪 website 🌷New 1z0-1077-25 Dumps Ppt[/url]
- Quiz 2026 First-grade Oracle 1z0-1077-25: New Oracle Order Management Cloud Order to Cash 2025Implementation Professional Exam Online 🥾 Search for ➥ 1z0-1077-25 🡄 and download it for free immediately on ( [url]www.prepawaypdf.com ) 🤵1z0-1077-25 Reliable Exam Prep[/url]
- High Hit Rate New 1z0-1077-25 Exam Online, Valid 1z0-1077-25 Study Materials 🤑 Search on 《 [url]www.pdfvce.com 》 for { 1z0-1077-25 } to obtain exam materials for free download 🐀Exam Vce 1z0-1077-25 Free[/url]
- Free PDF Quiz Oracle - 1z0-1077-25 –Valid New Exam Online 🌾 Enter ➡ [url]www.testkingpass.com ️⬅️ and search for ➠ 1z0-1077-25 🠰 to download for free ⏬Free 1z0-1077-25 Braindumps[/url]
- Exam Vce 1z0-1077-25 Free 🎠 1z0-1077-25 Exam Experience 🐄 1z0-1077-25 Latest Test Experience ⏭ Search for ( 1z0-1077-25 ) and easily obtain a free download on 【 [url]www.pdfvce.com 】 🔘Valid 1z0-1077-25 Exam Review[/url]
- Quiz 2026 First-grade Oracle 1z0-1077-25: New Oracle Order Management Cloud Order to Cash 2025Implementation Professional Exam Online 🌂 Search for 「 1z0-1077-25 」 on ➽ [url]www.torrentvce.com 🢪 immediately to obtain a free download 💝1z0-1077-25 Reliable Test Braindumps[/url]
- Vce 1z0-1077-25 Download 🕥 New 1z0-1077-25 Exam Testking 📮 1z0-1077-25 Reliable Test Braindumps 📃 Easily obtain ▷ 1z0-1077-25 ◁ for free download through ➡ [url]www.pdfvce.com ️⬅️ 🥝1z0-1077-25 Latest Test Experience[/url]
- 1z0-1077-25 Exam Experience ♥ Free 1z0-1077-25 Braindumps 🐘 1z0-1077-25 Latest Test Experience 🦽 Search for ➤ 1z0-1077-25 ⮘ and download exam materials for free through ✔ [url]www.practicevce.com ️✔️ 📶Vce 1z0-1077-25 Download[/url]
- Free PDF Quiz Oracle - 1z0-1077-25 –Valid New Exam Online 🎺 Open website ⏩ [url]www.pdfvce.com ⏪ and search for ⮆ 1z0-1077-25 ⮄ for free download 🏟Exam 1z0-1077-25 Collection[/url]
- Valid 1z0-1077-25 Exam Dumps 🗺 Exam 1z0-1077-25 PDF 😣 New 1z0-1077-25 Exam Testking 🏳 Download [ 1z0-1077-25 ] for free by simply entering ➠ [url]www.prepawaypdf.com 🠰 website ↘New 1z0-1077-25 Dumps Ppt[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, how2courses.org, elearno.net, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, Disposable vapes
