Study 1z0-1060-25 Group | 1z0-1060-25 Best Study Material
95
Posted at 3/7/2026 08:52:12      View:133 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ExamDiscuss 1z0-1060-25 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1WOy5OB90I-ILns8zTDqN6u6QIONyXimD
Under the help of our 1z0-1060-25 training materials, the pass rate among our customers has reached as high as 98% to 100%. Our 1z0-1060-25 training materials have been honored as the panacea for the candidates for the exam since all of the contents in the 1z0-1060-25 guide materials are the essences of the exam. Consequently, with the help of our 1z0-1060-25 Study Materials, you can be confident that you will pass the 1z0-1060-25 exam and get the related certification as easy as rolling off a log. So what are you waiting for? Just take immediate actions!
You can trust top-notch Oracle Accounting Hub Cloud 2025Implementation Professional (1z0-1060-25) exam questions and start preparation with complete peace of mind and satisfaction. The 1z0-1060-25 exam questions are real, valid, and verified by Oracle 1z0-1060-25 certification exam trainers. They work together and put all their efforts to ensure the top standard and relevancy of 1z0-1060-25 Exam Dumps all the time. So we can say that with Oracle 1z0-1060-25 exam questions you will get everything that you need to make the 1z0-1060-25 exam preparation simple, smart, and successful.
1z0-1060-25 Best Study Material & 1z0-1060-25 Verified AnswersWe give customers the privileges to check the content of our 1z0-1060-25 real dumps before placing orders. Such high quality and low price traits of our 1z0-1060-25 guide materials make exam candidates reassured. The free demos of 1z0-1060-25 study quiz include a small part of the real questions and they exemplify the basic arrangement of our 1z0-1060-25 real test. They also convey an atmosphere of high quality and prudent attitude we make.
Oracle Accounting Hub Cloud 2025Implementation Professional Sample Questions (Q10-Q15):NEW QUESTION # 10
The Unified Migration option helps move functional setup data from one instance to another.
Which TWO statements are true about Unified Migration?
  • A. There is no need to import the migration set into a sandbox instance before it is applied to the target environment
  • B. You need to manually download the configuration set from the source and manually upload it into the target
  • C. The Unified Migration option requires registration of the target environment in the source environment
  • D. You can optionally migrate only the new changes if both environments are synchronized
NEW QUESTION # 11
You are implementing the Oracle Fusion Cloud Financial Accounting Hub (FAH) service for three legacy Receivables systems. As part of your FAH implementation project, the customer requests that general ledger journals be summarized to keep a thin general ledger as billing in the three source systems is per delivery.
Which two options can be used in FAH to create the requested general ledger journals?
  • A. Summarize by journal category
  • B. Summarize by journal source
  • C. Summarize by general ledger period
  • D. Summarize by general ledger date
  • E. Group by general ledger period
  • F. Group by general ledger date
NEW QUESTION # 12
You have recently created an analysis to review periodic revenue amounts using Smart View. Your customer wants to use the drill-through option to get more details about the balances appearing in the analysis.
Which two drill-through options are available for use?
  • A. Drill to Financial Reporting Center
  • B. Drill to Account Group
  • C. Drill to Account Inspector
  • D. Drill to Detail Balances
Answer: A,D
NEW QUESTION # 13
Your client has implemented the Oracle Cloud Accounting Hub solution and they are importing the transaction data from the source system on a daily basis. While importing the data from the source system, some transactions are not getting accounted properly. They want these invalid transactions purged and the corrected transactions imported again.
Which job would you submit to purge the invalid transactions?
  • A. Import Accounting Transactions Job with Purge Invalid Transaction parameter set to 'Yes'
  • B. Purge Invalid and Unaccounted Accounting Hub Transactions Job
  • C. Accounting Hub Maintenance Job with Mode set to Purge Invalid or Unaccounted Transactions
  • D. Purge Accounting Hub Transactions Job
NEW QUESTION # 14
While creating an accounting method, you are unable to select a journal entry rule set for a combination of event class and event type.
What could be the reason for this issue?
  • A. Description rules assigned to the journal entry rule set are not attached to the same chart of accounts to which the accounting method is attached
  • B. The accounting method is either not attached to any chart of accounts or is attached to another chart of accounts than the journal entry rule set
  • C. Journal line rules assigned to the journal entry rule set are not attached to the same chart of accounts to which the accounting method is attached
  • D. Supporting references assigned to the journal entry rule set are not attached to the same chart of accounts to which the accounting method is attached
NEW QUESTION # 15
Our brand has marched into the international market and many overseas clients purchase our 1z0-1060-25 exam dump online. As the saying goes, Rome is not build in a day. The achievements we get hinge on the constant improvement on the quality of our 1z0-1060-25 latest study question and the belief we hold that we should provide the best service for the clients. The great efforts we devote to the Oracle exam dump and the experiences we accumulate for decades are incalculable. All of these lead to our success of 1z0-1060-25 learning file and high prestige.
1z0-1060-25 Best Study Material: https://www.examdiscuss.com/Oracle/exam/1z0-1060-25/
Oracle Study 1z0-1060-25 Group We offer the following types of subscriptions: 6-Months Subscription - $119.00 one-time charge (you spend $19.83 per month) 1-Year Subscription - $189.00 one-time charge (you spend $15.75 per month) Q: OK, I have the active subscription, Oracle Study 1z0-1060-25 Group Here you will find best exam material to pass your certification exam in first attempt, It will have all the questions that you should cover for the 1z0-1060-25 1z0-1060-25 exam.
Appendix C: Foundation Classes, Avoid using numbers in your usernames Study 1z0-1060-25 Group as these IDs immediately grab Twitter's security attention, We offer the following types of subscriptions: 6-Months Subscription - $119.00 one-time charge (you spend $19.83 per 1z0-1060-25 month) 1-Year Subscription - $189.00 one-time charge (you spend $15.75 per month) Q: OK, I have the active subscription.
1z0-1060-25 Study Guide: Oracle Accounting Hub Cloud 2025Implementation Professional & 1z0-1060-25 Learning MaterialsHere you will find best exam material to pass your certification exam in first attempt, It will have all the questions that you should cover for the 1z0-1060-25 1z0-1060-25 exam.
Oracle Financials Cloud ensures that with Oracle Financials Cloud Oracle Financials Cloud 1z0-1060-25 real exam dumps and practice questions can help you pass 1z0-1060-25 exam at your first time, So if you practice our Oracle Accounting Hub Cloud 2025Implementation Professional 1z0-1060-25 Verified Answers valid dumps seriously and review Oracle Accounting Hub Cloud 2025Implementation Professional vce files, you can pass exam absolutely.
