UiPath-ADPv1 Exam Preparation & UiPath-ADPv1 Free Pdf Guide
Posted at 1/28/2026 20:56:08      View:74 | Replies:2        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Real4Prep UiPath-ADPv1 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1h38dYiDgbCf8e6mq7GPXNlcGRkmL_PJx
First and foremost, in order to cater to the different needs of people from different countries in the international market, we have prepared three kinds of versions of our UiPath-ADPv1 learning questions in this website. Second, we can assure you that you will get the latest version of our training materials for free from our company in the whole year after payment on UiPath-ADPv1 practice materials. Last but not least, we will provide the most considerate after sale service for our customers in twenty four hours a day seven days a week.
UiPath UiPath-ADPv1 Exam Syllabus Topics:
  • UiPath Studio Fundamentals: In this section, the focus is given to the understanding of Robotic Process Automation (RPA) concepts; it covers UiPath Studio and its components, Working with the UiPath user interface, project creation, management, and version control.
  • UiPath Activities: In this section, the discussion is related to various UiPath activities for UI interaction, data manipulation, control flow, and more.
  • Debugging and Testing: This section is about utilizing logging and debugging tools and adopting unit testing and test automation strategies.
  • Design and Development: This section covers designing workflows using sequences, flowcharts, and state machines, building reusable components with libraries, exception handling and debugging techniques, etc.
UiPath UiPath-ADPv1 Free Pdf Guide - UiPath-ADPv1 Test PriceIf you are finding a study material in order to get away from your exam, you can spend little time to know about our UiPath-ADPv1 test torrent, it must suit for you. Therefore, for your convenience, more choices are provided for you, we are pleased to suggest you to choose our UiPath (ADPv1) Automation Developer Professional guide torrent for your exam. If you choice our product and take it seriously consideration, we can make sure it will be very suitable for you to help you pass your exam and get the UiPath-ADPv1 Certification successfully. You will find Our UiPath-ADPv1 guide torrent is the best choice for you
UiPath (ADPv1) Automation Developer Professional Sample Questions (Q171-Q176):NEW QUESTION # 171
When performing Remote Debugging using an Unattended Robot connection, Studio sends the list of project dependencies to the remote robot. From where does the remote robot download the required packages?
  • A. Orchestrator feeds and UiPath Official activity feed.
  • B. Activity feeds configured in Studio.
  • C. Orchestrator feeds and Robot activity feeds.
  • D. Studio local NuGet cache.
When performing remote debugging using an unattended robot connection, Studio must ensure that the necessary project dependencies (such as activities or libraries) are available to the robot. The unattended robot retrieves these dependencies from external sources. Specifically, the robot downloads the required packages from:
* Orchestrator feeds: These are package feeds configured in Orchestrator, such as internal libraries or activities deployed and managed via Orchestrator.
* UiPath Official activity feed: This feed includes all the official packages provided by UiPath and is a central repository for activities used in automation projects.
While Studio and its local NuGet cache (as in option A) may store packages locally for the developer, when the project is run remotely, the unattended robot does not access the developer's local cache. Instead, it relies on these external feeds (Orchestrator and UiPath Official activity feed) to ensure consistency and availability of the correct versions of dependencies. Option D is incorrect because the feeds configured in Studio do not directly affect where the robot downloads its dependencies.
References
* UiPath Official Documentation on Remote Debugging
* Orchestrator Feeds
* UiPath Official Activities Feed
NEW QUESTION # 172
An error occurs during the Initialization state within the 'FrameworkMnitAIISettings.xaml" file for a process using REFramework which is executed on Orchestrator. The project contains default values for the settings specified in "Config.xlsx".
What is the current state of the job in Orchestrator?
  • A. Successful
  • B. Faulted
  • C. Suspended
  • D. Stopped
The current state of the job in Orchestrator is Faulted, because an error occurred during the Initialization state of the process using REFramework. The REFramework is a template for creating robust and scalable automation projects that uses the State Machine workflow type1. The Initialization state is the first state in the REFramework, which is responsible for initializing the application, reading the configuration file, and setting the log level2. If an error occurs during the Initialization state, the process will go to the End Process state, which will perform the final actions and close the application2. The End Process state will also mark the job as Faulted in Orchestrator, if the value of the ShouldMarkJobAsFaulted argument is True2. The default value of this argument in the REFramework is True, unless it is changed in the Config.xlsx file or in the Orchestrator assets3.
Option A is incorrect, because the job is not Successful, as an error occurred during the Initialization state.
Option C is incorrect, because the job is not Suspended, as the process did not pause or wait for any user input.
Option D is incorrect, because the job is not Stopped, as the process did not encounter any user intervention or manual termination.
References: 1: State Machine 2: The UiPath ReFramework 3: ShouldMarkJobAsFaulted Argument
NEW QUESTION # 173
Considering that the attached table is stored in a variable called "dt":
Which LINQ query can be used to return the maximum total Quantity?
  • A. dt.AsEnumerable. Max(Function(x) Convert.ToInt32(x("Quantity").ToString))
  • B. dt.AsEnumerable. OrderByDescending(Function(x) Convert.ToInt32(x("Quantity").ToString)).First.Item("Quantity")
  • C. dt.AsEnumerable. GroupBy(Function(x) x("Item").ToString). Max(Function(x) x.Sum(Function(y) Convert.ToInt32(y("Quantity").ToString)))
  • D. dt.AsEnumerable. Max(Function(x) Convert.ToInt32(x("Quantity").ToString))("Item")
The LINQ query that can be used to return the maximum total Quantity from the attached table is dt.AsEnumerable. GroupBy(Function(x) x("Item").ToString). Max(Function(x) x.Sum(Function(y) Convert.ToInt32(y("Quantity").ToString))). This query uses the LINQ methods AsEnumerable, GroupBy, Max, and Sum to manipulate the data in the dt variable. The dt variable is a DataTable that contains the following data:
No.
Item
Quantity
1
apple
10
2
orange
20
3
mango
50
4
kiwi
80
5
pear
1
6
apple
5
7
mango
15
The AsEnumerable method converts the DataTable into an Enumerable collection of DataRow objects. The GroupBy method groups the elements of the collection by the value of the Item column, creating a collection of groups. Each group has a key, which is the Item name, and a list of elements, which are the DataRows that have the same Item value. The Max method returns the maximum value of the collection, based on a selector function. The selector function is a lambda expression that calculates the sum of the Quantity column for each group. The Sum method returns the sum of the elements in a collection, based on a selector function. The selector function is a lambda expression that converts the value of the Quantity column into an integer.
Therefore, the query will group the DataRows by the Item name, calculate the total Quantity for each group, and return the maximum total Quantity among the groups. The maximum total Quantity is 80, which corresponds to the group with the key "kiwi". References: [DataTable.AsEnumerable Method],
[Enumerable.GroupBy Method], [Enumerable.Max Method], [Enumerable.Sum Method]
NEW QUESTION # 174
What can be verified in the InltAIISettlngsTestCase test case?
  • A. Verify If a certain application is open in the execution environment.
  • B. Verify the variable type for the 'Config' dictionary.
  • C. Verify the naming of a certain key present in the 'Config' dictionary.
  • D. Verify If a certain key is present in the 'Config' dictionary.
In the InitAllSettingsTestCase test case, one of the verifications that can be done is to check if a certain key is present in the 'Config' dictionary. This ensures that necessary configurations are available for the process.
NEW QUESTION # 175
Given the following workflow:
What will be the output of the Log Message activity?
  • A. apple pear orange, mango kiwi
  • B. "apple pear orange", "mango kiwi"
  • C. apple, pear, orange, mango, kiwi
  • D. apple, pear, orange
NEW QUESTION # 176
In order to serve you better, we have a complete system for UiPath-ADPv1 training materials. We offer you free demo to have a try before buying, so that you can have a better understanding of what you are going to buy. After payment, you can obtain the download link and password within ten minutes for UiPath-ADPv1 Training Materials. And we have a professional after-service team, they process the professional knowledge for the UiPath-ADPv1 exam dumps, and if you have any questions for the UiPath-ADPv1 exam dumps, you can contact with us by email, and we will give you reply as soon as possible.
UiPath-ADPv1 Free Pdf Guide: https://www.real4prep.com/UiPath-ADPv1-exam.html
Posted at 2/22/2026 08:56:18        Only Author  2#
I can’t express how much I appreciate your article, it was truly memorable. The Reliable N10-009 dumps exam papers are free for all! Best of luck to everyone!
Posted at before yesterday 19:16        Only Author  3#
This is such a brilliant article, thank you for providing it. N16599GC10 exam dump test papers shared for free—get them now to boost your career!
