[Hardware] Plat-Admn-301 Trustworthy Exam Torrent | Plat-Admn-301 Customizable Exam Mode
96
【Hardware】 Plat-Admn-301 Trustworthy Exam Torrent | Plat-Admn-301 Customizable Exam Mode
Posted at 1/27/2026 18:21:28      View:114 | Replies:1        Print      Only Author   [Copy Link] 1#
What's more, part of that TestInsides Plat-Admn-301 dumps now are free: https://drive.google.com/open?id=1ud9xU-1liSBV87TPbpZqYPYugETqS-yW
Laziness will ruin your life one day. It is time to have a change now. Although we all love cozy life, we must work hard to create our own value. Then our Plat-Admn-301 training materials will help you overcome your laziness. Study is the best way to enrich your life. On one hand, you may learn the newest technologies in the field with our Plat-Admn-301 Study Guide to help you better adapt to your work, and on the other hand, you will pass the Plat-Admn-301 exam and achieve the certification which is the symbol of competence.
Salesforce Plat-Admn-301 Exam Syllabus Topics:
  • Process Automation: This section of the exam measures skills of Salesforce Consultant and covers choosing the right automation tools to solve complex business problems. It focuses on understanding the capabilities and limitations of declarative tools, identifying the right troubleshooting methods, and applying automation correctly within Salesforce’s order of execution. This section emphasizes designing efficient, scalable automation using workflow tools, flows, and other declarative features.
  • Objects and Applications: This section of the exam measures the skills of a Salesforce Business Analyst and covers selecting appropriate object and application-level solutions to meet business needs. It focuses on identifying when to use master-detail relationships, lookups, junction objects, related lists, record types, Schema Builder, and Object Creator. The section also includes improving UI and user experience using App Manager, Lightning App Builder, Dynamic Forms, standard Lightning components, console apps, and tools like the Lightning page analyze button.
  • Environment Management and Deployment: This section of the exam measures skills of Salesforce Administrator and covers moving metadata between environments using tools such as sandboxes, change sets, and managed or unmanaged AppExchange packages. It explains the capabilities and best practices related to deploying changes through change sets to ensure smooth and controlled migrations.
  • Auditing and Monitoring: This section of the exam measures skills of a Salesforce Support Specialist and covers the tools used to monitor system behavior and review user activity. It includes understanding debug logs, setup audit trail, and methods for ensuring sensitive data is handled correctly in both production and sandbox environments. It also explains how to review and troubleshoot security settings, including recognizing pending updates that might affect system access.
Salesforce Plat-Admn-301 Salesforce Certified Platform Administrator II Dumps - Easy To Prepare Exam [2026]You can easily download these formats of Salesforce Plat-Admn-301 actual dumps and use them to prepare for the Salesforce Plat-Admn-301 certification test. You don't need to enroll yourself in expensive Plat-Admn-301 Exam Training classes. With the Salesforce Plat-Admn-301 valid dumps, you can easily prepare well for the actual Salesforce Plat-Admn-301 exam at home.
Salesforce Certified Platform Administrator II Sample Questions (Q90-Q95):NEW QUESTION # 90
Ursa Major Solar customer records have a lot of fields and Lightning components to give users a variety of information and available functions. Recently,usrrs have noted that their pages take a long time to load and it's starting to negatively impact their experience.
What should the administrator do to help diagnose where improvements can be made?
  • A. Check the debug logs found in the Environment section of Setup.
  • B. Use the Apex debugger while loading a customer record.
  • C. Click Analyze from the Lightning App Builder toolbar.
  • D. Review the debug logs from the Developer Console.
The Analyze feature in the Lightning App Builder toolbar is a tool that helps you optimize the performance of your record pages by providing recommendations and insights on how to improve page load time and user experience. It can help you identify which fields and components are taking the most time to load and suggest ways to reduce their impact. You can also compare your page performance with other pages in your org or with Salesforce best practices. References: https://help.salesforce.com/s/articleView?id=sf.
lightning_page_optimize.htm&type=5
NEW QUESTION # 91
An administrator has created a flow that sends platform events whenever an opportunity is updated. An Apex developer has been tasked to write code that listens for these events. When reviewing the debug logs for a user, the developer can see that the flow ran, but the debug Information is missing.
What should the administrator recommend to assist with debugging?
  • A. Set a debug log on the Automated Process entity.
  • B. Search the AppExchange to And a tool that assists with debugging.
  • C. Select the Debug Enabled checkbox on platform events,
  • D. Platform events are unavailable for debugging.
To debug platform events in Apex code, you need to set a debug log on the Automated Process entity. This entity represents an automated process user that runs flows and processes in your org. By setting a debug log on this entity, you can capture the events that are published and consumed by your flow and Apex code, as well as any errors or exceptions that occur during the execution. References: https://developer.salesforce.com
/docs/atlas.en-us.platform_events.meta/platform_events/platform_events_debug.htm https://help.salesforce.
com/s/articleView?id=sf.code_add_users_debug_log.htm&type=5
NEW QUESTION # 92
The sales department has asked to limit access to the Amount field on the Opportunity to only tnose users. In the sales department and on the executtve team, Northern Trail Outfitters uses six custom profiles including Sales User. Marketing user, call Center user. Executive User Sales Manager user, ana call Center Manager user. Field level access is removed from three or the profiles In the sandbox.
What action should an administrator take to make sure this change is in production?
  • A. Manually restrict access to this field for each profile via Setup Just like the sandbox.
  • B. Create a sandbox template and push it to production to reflect the update.
  • C. Deploy a change set from tht sandbox to prodUGBOffl including the Amount field with all the custom profiles.
  • D. Process a change set with the profiles that should no longer have access to the field.
A change set is a tool that allows you to send customizations from one Salesforce org to another. A change set can contain components such as objects, fields, profiles, permission sets, workflows, and more. You can use change sets to migrate changes from a sandbox org to a production org or between two sandbox orgs that are affiliated with the same production org. In this case, you can deploy a change set from the sandbox to production that includes the Amount field and all the custom profiles that need access to it. This way, you can update the field-level security settings for the field on each profile in one deployment. References: https://help.
salesforce.com/s/articleView?id=sf.changesets.htm&type=5 https://help.salesforce.com/s/articleView?id=sf.
changesets_components_field.htm&type=5
NEW QUESTION # 93
What are three options available to the administrator to help with this issue? Choose 3 answers
  • A. Move some page components behind a tab.
  • B. Reduce the number of related lists displayed.
  • C. Deactivate unnecessary validation rules.
  • D. Convert all Process builders to flows.
  • E. Remove some of the fields displayed.
Answer: A,B,E
Move some page components behind a tab, remove some of the fields displayed, and reduce the number of related lists displayed are three options available to the administrator to help with this issue. Moving some page components behind a tab can help reduce the loading time of a record page by hiding some components until they are needed by the user. Removing some of the fields displayed can help reduce the loading time of a record page by minimizing the number of queries and calculations that need to be performed when rendering the page. Reducing the number of related lists displayed can help reduce the loading time of a record page by limiting the amount of data that needs to be retrieved and displayed on the page
NEW QUESTION # 94
The administrator at AW Computing has been asked to review whether any users are making configuration changes directly in production.
Which item should the administrator review to find these details?
  • A. Setup Audit Trail
  • B. Organization-Wide Defaults
  • C. Login History
  • D. Field History Tracking
The Setup Audit Trail is a tool that allows you to view and download a log of changes made in your org's Setup area. The log shows up to 20 fields of information for each change, such as who made it, when it was made, what type of change it was, and what values were changed. You can use the Setup Audit Trail to track configuration changes directly in production and identify any unauthorized or problematic changes.
References: https://help.salesforce.com/s/ar ... etup.htm&type=5
NEW QUESTION # 95
The Salesforce Plat-Admn-301 certification provides is beneficial to accelerate your career in the tech sector. Today, the Salesforce certification is a fantastic choice to get high-paying jobs and promotions, and to achieve it, you must crack the challenging Plat-Admn-301 Exam. It is critical to prepare with actual Salesforce Certified Platform Administrator II (Plat-Admn-301) exam questions if you have less time and want to clear the test in a short time.
Plat-Admn-301 Customizable Exam Mode: https://www.testinsides.top/Plat-Admn-301-dumps-review.html
2026 Latest TestInsides Plat-Admn-301 PDF Dumps and Plat-Admn-301 Exam Engine Free Share: https://drive.google.com/open?id=1ud9xU-1liSBV87TPbpZqYPYugETqS-yW
Posted at 1/28/2026 23:05:05        Only Author  2#
The content is top-notch, definitely deserving of a like. I owe my promotion and raise to the Latest NCP-AIO exam cram questions, and today I’m sharing them for free with all of you!
Posted at 3/8/2026 09:25:24        Only Author  3#
This is a truly impressive article, thank you for your sharing. The Book SOA-C02 Free exam that helped me achieve a promotion and pay raise is free today for you to use. Best of luck on your professional journey!
