[General] New 4A0-D01 Test Questions & Online 4A0-D01 Tests
94
General New 4A0-D01 Test Questions & Online 4A0-D01 Tests
Posted at 1/25/2026 21:17:02      View267 | Replies3        Print      Only Author   [Copy Link] 1#
P.S. Free & New 4A0-D01 dumps are available on Google Drive shared by TestValid: https://drive.google.com/open?id=17GaUgiBG2zzUQ5jCy_DtsrdcgdMRvIZq
Our company is a professional certification exam materials provider, we have occupied in the field more than ten years, and we have rich experiences. 4A0-D01 training materials have gained popularity in the international market for high quality. In addition, 4A0-D01 exam, dumps contain both questions and answers, and you can have a quick check after practicing. 4A0-D01 Training Materials cover most of knowledge points for the exam, and they will help you pass the exam. We offer you free update for 365 days after purchasing 4A0-D01 exam materials, and the update version will be sent to your email automatically.
According to various predispositions of exam candidates, we made three versions of our 4A0-D01 study materials for your reference: the PDF, Software and APP online. And the content of them is the same though the displays are different. Untenable materials may waste your time and energy during preparation process. But our 4A0-D01 Practice Braindumps are the leader in the market for ten years. As long as you try our 4A0-D01 exam questions, we believe you will fall in love with it.
How Does Nokia 4A0-D01 Certification help To Make Your Professional Career Better?With three versions of products, our 4A0-D01 learning questions can satisfy different taste and preference of customers with different use: PDF & Software & APP versions. Without ambiguous points of questions make you confused, our 4A0-D01 practice materials can convey the essence of the content suitable for your exam. With our 4A0-D01 exam guide, you will achieve what you are expecting with ease.
Nokia 4A0-D01 Exam Syllabus Topics:
  • SR Linux Logging, Monitoring, and Filtering: This section of the exam measures skills of a Data Center Network Engineer and addresses how to implement logging, monitoring, and traffic filtering in SR Linux. It explains log file usage, ACL types, CPM filtering, and packet capture filters. Configuration tasks involve applying ACLs and monitoring network activity using capture tools.
  • SR Linux User and System Management: This section of the exam measures skills of a Network Automation Specialist and includes managing user roles, TLS configurations for secure communication, and automation features like Zero-Touch Provisioning (ZTP). It covers ZTP setup, configuration processes, and common issues that may arise during deployment.
  • This section of the exam measures skills of a Network Automation Specialist and introduces the principles of Event Driven Automation in SR Linux environments. It covers integration with Kubernetes and explores core use cases such as intent-based automation for fabrics and services, as well as enhanced network observability.
  • Module 5 C EDA (Event Driven Automation) Introduction
Topic 5
  • Nokia DC Fabric Solution: This section of the exam measures skills of a Data Center Network Engineer and covers the architecture and benefits of modern Layer 3 data center networks. It includes an overview of BGP-based routing, VXLAN and EVPN overlays for multi-tenant environments, and key features of the SR Linux operating system. The section also explains how APIs are used for external configuration and introduces the Fabric Services System's management capabilities.
Nokia Data Center Fabric Fundamentals Exam Sample Questions (Q27-Q32):NEW QUESTION # 27
Which of the following Nokia's SR Linux ACLs is instantiated on all line cards to copy incoming packets to the CPM?
  • A. Egress ACL
  • B. CPM-filter ACL
  • C. Ingress ACL
  • D. Capture-filter ACL
The CPM-filter ACL is instantiated on all line cards in Nokia's SR Linux to copy incoming packets to the Control Plane Manager (CPM) for processing.
NEW QUESTION # 28
Which of the following statements about resilient ECMP load balancing is TRUE?
  • A. The hash value used to distribute traffic is calculated as a modulo function on specific fields of the packet header.
  • B. Hash buckets are used to ensure that flows egressing the same interface on one router use different egress interfaces on downstream routers.
  • C. When one of the next-hops fail, only flows currently egressing to that next-hop are impacted.
  • D. A different hash seed is used on downstream routers to ensure that flows are randomly distributed across all eligible router interfaces.
In resilient ECMP load balancing, when a next-hop fails, only the flows that were using that specific next-hop are affected and need to be redistributed, minimizing disruption to other flows.
NEW QUESTION # 29
Which of the following statements about the YANG model used in Nokia's SR Linux is FALSE?
  • A. All configuration and state information is defined as a YANG model.
  • B. The YANG model provides a standardized way for applications to retrieve SR Linux configuration and state information.
  • C. The YANG model uses a tree structure with "leafs" as the branches and "containers" as the data components.
  • D. The YANG model can be converted into other formats such as JSON or XML.
In YANG models, "leafs" are the data nodes (not branches), and "containers" group related data nodes. The statement incorrectly reverses their roles by calling leafs branches and containers data components.
NEW QUESTION # 30
Based on the exhibit output, what CLI command can be used to display the contents of "bgp-log" in Nokia's SR Linux?
  • A. info system logging buffer bgp-log
  • B. show system logging buffer bgp-log
  • C. info system logging file bgp-log
  • D. show system logging file bgp-log
The "bgp-log" is defined as a log file in the configuration, so the correct command to display its contents is show system logging file bgp-log.
NEW QUESTION # 31
Which of the following statements about the VXLAN tunneling in data centers is FALSE?
  • A. VLXAN tunneling is used to provide Layer 2 connectivity between workloads over a common underlay network.
  • B. EVPN routes are exchanged between VXLAN tunnel endpoints.
  • C. Each VXLAN tunnel endpoint is automatically assigned with a unique VNI value.
  • D. VXLAN tunnel endpoints can be on hypervisors, leaf routers, or datacenter gateways.
VXLAN tunnel endpoints (VTEPs) are configured with VNI (VXLAN Network Identifier) values, but these VNIs are not automatically assigned; they must be explicitly configured to define Layer 2 segments.
NEW QUESTION # 32
So we are looking forward to establishing a win-win relation with you by our 4A0-D01 training engine. In our trade with merchants of various countries, we always adhere to the principles of mutual benefits rather than focusing solely on our interests on the 4A0-D01 Exam Questions. So our aim is to help our customers to pass the 4A0-D01 exam as easy as possible. We have invested a lot on the compiling the content of the 4A0-D01 study materials and want to be the best.
Online 4A0-D01 Tests: https://www.testvalid.com/4A0-D01-exam-collection.html
BONUS!!! Download part of TestValid 4A0-D01 dumps for free: https://drive.google.com/open?id=17GaUgiBG2zzUQ5jCy_DtsrdcgdMRvIZq
Posted at 2/5/2026 19:18:08        Only Author  2#
Im amazed by this article, thank you for sharing it. Thanks to the Key H31-311_V2.5 concepts exam, I got promoted and earned a higher salary. Now, Im giving it away for free today!
Posted at 2/24/2026 15:59:46        Only Author  3#
I was blown away by how much I learned from it. Wish me all the best for the Reliable CDFOM exam test exam coming up!
Posted at 3/9/2026 09:43:30        Only Author  4#
This article is simply exceptional, I appreciate you sharing it. Upgrade your IT skills with free COF-C02 latest braindumps ppt. Best wishes for your success!
