New Topic
[Linux] eth0/eth1 interfaces don't work
67
Linux eth0/eth1 interfaces don't work
Posted at 3/23/2022 02:54:39      View11413 | Replies10        Print      Only Author   [Copy Link] 1#
We are using RK3568 with our carrier board (custom board) and factory carrier board (devboard).
For network we are using the same chip RTL8211F-CG as on devboard.
As result, eth0/eth1 interfaces don't work. We can't understand what is a reason.
Linux log files for both carrier boards:
https://drive.google.com/drive/f ... dWsY0YS?usp=sharing
administrator
Rank: 9Rank: 9Rank: 9
Posted at 3/23/2022 17:14:49        Only Author  2#
Hi, we suggest that you can check the Ethernet-related circuit on the board first. Thanks.
Posted at 3/23/2022 17:41:00        Only Author  3#
From the information, the PHY device, RTL8211F-CG, is not recognized.
You need to rule out hardware problems, whether the power supply, reset, and clock of the RTL8211F-CG are normal.
This will provide some help. https://gitlab.com/firefly-linux ... firefly/Common/GMAC
Posted at 3/25/2022 15:23:01        Only Author  4#
ther four custom boards have an another error with DMA:
[   10.334142] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
[   10.334168] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[   10.334176] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_open: Hw setup failed
[   10.443937] rk_gmac-dwmac fe2a0000.ethernet: Failed to reset the dma
[   10.443963] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_hw_setup: DMA engine initialization failed
[   10.443971] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_open: Hw setup failed
[   10.577682] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
[   10.577708] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[   10.577715] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_open: Hw setup failed
[   10.687930] rk_gmac-dwmac fe2a0000.ethernet: Failed to reset the dma
[   10.687966] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_hw_setup: DMA engine initialization failed
[   10.687973] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_open: Hw setup failed
[   10.824357] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
[   10.824383] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[   10.824390] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_open: Hw setup failed
[   10.934578] rk_gmac-dwmac fe2a0000.ethernet: Failed to reset the dma
[   10.934606] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_hw_setup: DMA engine initialization failed
[   10.934635] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_open: Hw setup failed
Posted at 3/28/2022 15:59:54        Only Author  5#
valeriy.simakov Posted at 3/25/2022 15:23
[   10.334142] rk_gmac-dwmac fe010000.e ...
That's usually a problem with the operating clock.
Posted at 1/13/2026 00:38:29        Only Author  6#
Thank you for your article, it was a real revelation to me. Get ahead in your career with the free C-S4CPB-2508 latest test topics pdf test questionsyour key to promotion!
Posted at 1/16/2026 01:13:33        Only Author  7#
DumpTOP Salesforce Revenue-Cloud-Consultant-Accredited-Professional 덤프는Salesforce Revenue-Cloud-Consultant-Accredited-Professional실제시험 변화의 기반에서 스케줄에 따라 업데이트 합니다. 만일 테스트에 어떤 변화가 생긴다면 될수록 2일간의 근무일 안에Salesforce Revenue-Cloud-Consultant-Accredited-Professional 덤프를 업데이트 하여 고객들이 테스트에 성공적으로 합격 할 수 있도록 업데이트 된 버전을 구매후 서비스로 제공해드립니다. 업데이트할수 없는 상황이라면 다른 적중율 좋은 덤프로 바꿔드리거나 덤프비용을 환불해드립니다.
Posted at 1/20/2026 11:05:59        Only Author  8#
KaoGuTiÿҪͨ^CrowdStrikeCCCS-203bԇJCĿṩһ_׿ԽĽQ҂ṩCrowdStrikeCCCS-203bԇԔĆ}𰸣 ҂F꠵ITнYģ҂Ŀԇyԇ}𰸎׺挍ÿԇһӣ@ӵĴ_˲𣬸Ҫ҂KaoGuTiWվȫ򹠇Ȉ@헿ԇӖͨ^
Posted at 1/23/2026 10:16:31        Only Author  9#
This article is a real eye-opener, thanks for sharing! Wish me success as I prepare for the Valid PDD study plan exam!
Posted at 3/20/2026 17:12:54        Only Author  10#
The process should be as smooth as the date itself. The ability to Call Girl Book online with ease is a sign of a good agency. MumbaiFunGirl offers a seamless booking interface. As the most trusted and reliable agency, we ensure your reservation is confirmed instantly, with the girl arriving exactly as promised.
Return to List
12
