Release of Dual OS Firmware for FirePrime Mass Produced Board with Touch Screen
403
Posted at 7/20/2015 17:40:41      View3949 | Replies4        Print      Only Author   [Copy Link] 1#
Hi folks,
A new dual OS firmware for FirePrime mass produced board has been released. It comes with touch screen support!
You can download it at Google Drive:
   https://drive.google.com/file/d/ ... 2M/view?usp=sharing
Here're the snapshots:
Posted at 7/20/2015 17:48:08        Only Author  2#
1 Add touch screen support to FirePrime Linux
1.1 Introduction
  X11 window system uses evdev input driver to handle touch screen
  events. There're mainly two steps to add touch screen support:
  1. Add X11 configuration file to use evdev driver for touch screen.
  2. Make evdev support touch screen (also emulate right mouse button).
1.2 Configuration
  Create file `/etc/X11/xorg.conf.d/10-evdev-gslX680.conf' with
  following contents:
  | Section "InputClass"
  |         Identifier "gslX680 evdev touchscreen"
  |         MatchProduct    "gslX680"
  |         MatchDevicePath "/dev/input/event*"
  |         Option "EmulateThirdButton" "true"
  |         Option "EmulateThirdButtonTimeout" "500"
  |         Option "EmulateThirdButtonMoveThreshold" "50"
  |         Driver "evdev"
  | EndSection
1.3 Make evdev support touch screen
  The original evdev driver does not support Android input touch driver
  well. It needs some patches.
  Here're the main steps to patch and recompile a new one.
1.3.1 Install build environment and dependencies
  | sudo apt-get install build-essentials
  | sudo apt-get build-dep xserver-xorg-input-evdev
1.3.2 Fetch, patch, and compile the source code
  | sudo apt-get source xserver-xorg-input-evdev
  | cd xserver-xorg-input-evdev-2.9.0/src
  | GITHUB=https://github.com/TeeFirefly/xf86-input-evdev/tree/ba37709e2aab50354c9925ca1e975779a16c67dc
  | wget $GITHUB/src/emuThird.c
  | wget $GITHUB/src/evdev.c
  | wget $GITHUB/src/evdev.h
  | cd ..
  | make -j4
1.3.3 Install the newly built module
  | mv /usr/lib/xorg/modules/input/evdev_drv.so /usr/lib/xorg/modules/input/evdev_drv.so.orig
  | cp src/.libs/evdev_drv.so /usr/lib/xorg/modules/input/evdev_drv.so
  Restart system to take effect
Posted at 1/15/2026 02:19:59        Only Author  3#
Your article was truly insightful, Im sincerely thankful. Free Training 010-160 Solutions available to improve your IT skills. Best of luck!
Posted at 1/15/2026 21:36:57        Only Author  4#
This article is exceptional, I truly appreciate you sharing it! Free Reliable practice C_TFG61_2405 test online resourcesgood luck with your exam!
Posted at 2/15/2026 09:32:56        Only Author  5#
This article is a real treasure, thank you for sharing it with us. The DOP-C02 reliable exam registration exam that helped me get promoted and earn a salary raise is available for you today at no charge. Hope you reach your career targets soon!
