[General] 100% Pass Quiz 2026 Juniper Accurate JN0-224: Automation and DevOps, Associate (
73
General 100% Pass Quiz 2026 Juniper Accurate JN0-224: Automation and DevOps, Associate (
Posted at 2/12/2026 23:11:53      View171 | Replies1        Print      Only Author   [Copy Link] 1#
As the leader in this career, we always adhere to the principle of mutual development and benefit, and we believe our JN0-224 practice materials can give you a timely and effective helping hand whenever you need in the process of learning. With our JN0-224 exam questions for 20 to 30 hours, you will find that you can pass the exam with confidence. Tens of thousands of our customers have tested that our pass rate of the JN0-224 study braindumps is high as 98% to 100%, which is unmatched on the market!
Juniper JN0-224 Exam Syllabus Topics:
  • Junos Automation Stack and DevOps Concepts: This domain covers fundamental automation tools, frameworks, APIs, and DevOps culture applicable to Junos platform operations and network management.
  • Rest API: This domain covers Junos REST API implementation, REST API Explorer tool, and cURL usage for HTTP-based device management and configuration.
  • Data Serialization: This domain addresses YAML and JSON formats used for structured data representation and exchange in network automation workflows.
  • NETCONF
  • XML API: This domain focuses on XML syntax, XPath expressions, NETCONF protocol, and XML API functionality for programmatic device configuration and communication.
Topic 5
  • Python
  • PyEZ: This domain examines Python programming with PyEZ library for Junos automation, including JSNAPy, Jinja2 templates, RPC calls, exception handling, and device configuration management.
Quiz JN0-224 - Automation and DevOps, Associate (JNCIA-DevOps) Fantastic Exam PrepMost of the experts in our company have been studying in the professional field for many years and have accumulated much experience in our JN0-224 practice questions. Our company is considerably cautious in the selection of talent and always hires employees with store of specialized knowledge and skills. All the members of our experts and working staff maintain a high sense of responsibility, which is why there are so many people choose our JN0-224 Exam Materials and to be our long-term partner.
Juniper Automation and DevOps, Associate (JNCIA-DevOps) Sample Questions (Q28-Q33):NEW QUESTION # 28
Which two statements about XML schema definition (XSD) files are correct? (Choose two.)
  • A. XSD files ensure that everyone working with the XML document uses a common set of tags.
  • B. XSD files define all the elements in an XML document and the document XML hierarchy.
  • C. Every XML document must have an XSD file defined for it.
  • D. An XSD file is not an XML document.
XML Schema Definition (XSD) files are used to define the structure and data types of an XML document. They ensure that the XML document adheres to a specific structure by defining the allowed elements, attributes, and their data types, thereby enforcing a consistent format.
Option A is correct because XSD files define the elements, attributes, and structure (hierarchy) of an XML document.
Option D is correct because XSD files provide a standardized format, ensuring that all parties working with the XML document use the same set of tags and structure.
Option B (Every XML document must have an XSD file defined for it) is incorrect; not every XML document requires an XSD file, although it's beneficial for validation.
Option C (An XSD file is not an XML document) is incorrect because XSD files themselves are written in XML.
Supporting Reference:
W3C XML Schema Definition (XSD) Documentation: Explains the purpose and structure of XSD files, including their role in defining XML document schemas.
NEW QUESTION # 29
Which statement is correct about Ansible playbooks?
  • A. A playbook is a specific Python module that is executed on a host
  • B. A playbook can contain multiple tasks and execute multiple Python modules
  • C. A playbook is a configuration file that defines the Ansible related parameters
  • D. A playbook contains one or more tasks written in XML
NEW QUESTION # 30
Junos supports which two APIs for on-box scripting? (Choose two.)
  • A. XML
  • B. Puppet
  • C. Chef
  • D. JET
Answer: A,D
Juniper Networks' Junos operating system supports several APIs for on-box scripting, two of which are:
JET (Juniper Extension Toolkit): JET is a modern API framework that provides a programmable interface for interacting with Junos. It allows developers to create custom applications that run directly on Junos devices, enabling the automation of network operations. JET provides both a gRPC and a REST API interface, allowing for flexible integration with external systems.
XML API: The Junos XML API allows direct interaction with the Junos OS through XML-based requests. This API can be used to retrieve information, configure devices, and execute commands on Junos devices. The XML API is crucial for automation tasks as it provides a structured and consistent way to interact with the device's configuration and operational data.
Detailed Explanation:
JET (A) provides high-performance access to Junos routing, switching, and service elements via programmable interfaces. It is highly used for creating custom applications that require tight integration with the Junos OS.
XML (C), on the other hand, is a well-established method for interacting with Junos, especially for legacy systems or when working within environments where XML is the standard data format.
Other options like Puppet (B) and Chef (D) are not APIs provided by Junos for on-box scripting but are configuration management tools used externally to manage Junos devices.
Juniper Networks JET Documentation: Provides details on how to leverage JET APIs for automation.
Junos XML Management Protocol Guide: Describes how to use XML for scripting and automating tasks in Junos.
These APIs are key components of Juniper's automation strategy, allowing for scalable, flexible, and efficient network operations.
NEW QUESTION # 31
Junos PyEZ tables are formatted using which file type?
  • A. SON
  • B. txt
  • C. IXML
  • D. YAML
Junos PyEZ uses YAML (YAML Ain't Markup Language) files to define the format for tables and views when working with operational and configuration data. YAML is a human-readable data format that is commonly used for configuration files, making it suitable for defining data structures in PyEZ.
Option B (YAML) is correct because PyEZ tables are defined using YAML files.
Options A (JSON), C (txt), and D (IXML) are incorrect in this context, as YAML is the standard format used.
Junos PyEZ Tables Documentation: Explains the use of YAML files for formatting tables and views in Junos PyEZ.
NEW QUESTION # 32
Which development model is the classic approach to software development?
  • A. Kanban
  • B. Lean
  • C. Scrum
  • D. Waterfall
NEW QUESTION # 33
We understand you not only consider the quality of our Automation and DevOps, Associate (JNCIA-DevOps) prepare torrents, but price and after-sales services and support, and other factors as well. So our Automation and DevOps, Associate (JNCIA-DevOps) prepare torrents contain not only the high quality and high accuracy JN0-224 Test Braindumps but comprehensive services as well. By the free trial services you can get close realization with our JN0-224 quiz guides, and know how to choose the perfect versions before your purchase.
JN0-224 Practice Exam Questions: https://www.examcost.com/JN0-224-practice-exam.html
Posted at 4/19/2026 18:42:50        Only Author  2#
This article is truly an outstanding work, and Ive benefited greatly from it. Latest SOA-C03 test pattern offers valuable resources, made available to you free of charge.
