D-PE-FN-01㏊rg & D-PE-FN-01J^Y
Posted at 2/4/2026 03:47:33
View208
Replies2
P.S.ShikenPASSGoogle DriveǹФƤoϤ2026 EMC D-PE-FN-01ףhttps://drive.google.com/open?id=1Thdp9QY2-_D5eOvxLp56yXXhLN5cvGl-
⤦ȤEMCD-PE-FN-01JԇYꤷzߤޤ⤦ԇYΕrgʤΤˡޤԇY˺ϸŤ֤äƤʤǤɤ餤Ǥ礦ΤԇY˺ϸ륷`ȥåȤΤǤԇYοi߽KrgʤǤ・・・ޤΤ褦ʚݳ֤ޤƤ⽹ʤǤ衣ԇYĿǰ˿ؤƤ⡢ԇY˜ʂ䤹⤢ޤΤΥǤǤ礦ShikenPASSD-PE-FN-01}ǤτĤYϤǡʤ̕rgԇYʮ֤˜ʂ䤵뤳ȤǤޤΆ}εʤȤƤߤǤ顢}˳뤹٤ƤΆ}ȻشҙޤꡢD-PE-FN-01JԇY˺ϸ뤳ȤǤޤ
˽EMCṩD-PE-FN-01ȥȤϡՓȌg¤_k˻ŤUY֤ČTҤˤäƥѥ뤵Ƥ뤿ᡢdzˁޤ uƷُ뤹ǰˡޤuƷԇƤ ShikenPASSD-PE-FN-01ԇYκϸĤǤʤrgȥͥ륮`sǤ뤿ᡢD-PE-FN-01ԇYʂُ뤹ޤ ͘Μ㤬˽Υ`ӥĿĤǤD-PE-FN-01ȥȤgDell PowerEdge Foundations v2 Examُ뤷Ƥ
D-PE-FN-01J^YD-PE-FN-01ITIǃPƤयˤEMCD-PE-FN-01ԇYΜʂ䤬֪äƤޤҡShikenPASSD-PE-FN-01ԇYypʤȤԤԇYʂyp뤳ȤǤޤҡṩ놖}YƤ顢ʤEMCD-PE-FN-01ԇY˺ϸǤŤ֤äƤޤ
EMC D-PE-FN-01 JԇYγ}죺| ȥԥå | } | | ȥԥå 1 | - ƥʥΥǤϡǩ``gߤΥugĤʥ`Щ`ƥʥ혤W_ޤȒ`ɤȡQ늤⡢ϩ`ɥϺ``JRޤޤʥե`०åץǩ`ȷmäʤɤޤޤޤ䡢Һ䡢ҺȴʤɤȴgˤmФʥåȥӤηˤĤƤⴥޤ
| | ȥԥå 2 | - `Щ`ͥåȥ`ȽӾAΥǤϡǩ``gߤΥuPowerEdge`Щ`vBͥåȥ``ӥλA˽Ƥޤͥåȥ``֥ȽӾAReƘʥܩ`ɥͥåȥ`ץα^ʤɤޤޤ֪Rϡʥե饹ȥ饯hˤ륵`Щ`ӾAδ_ȾS֤˲ǷǤ
| | ȥԥå 3 | - `Щ`ΥǤϡ`Щ`ݩ`ȥ˥ΥuХɹȥȥ֥Хɹॵ`Щ`θQޤDell`ƥƥα^BIOSUEFIα^ƌrιˤĤƽhޤޤiDRACΥЩ`Dell OpenManage System Administrator SuiteOMSAΙCܤˤĤƤh˥PowerEdge`Щ`Ĥ˱Oҕ・Ǥ褦ˤޤ
| | ȥԥå 4 | - `Щ`TΥǤϡǩ``gߤΥuDell PowerEdge`Щ`Υ`Щ`ԤҪʥȥ`ݩ`ͥȤvAW_ޤ`Щ`Re`Щ`ƤνዡHDDSSDRAIDȥ``BOSSM.2ɥ饤֤ʤɤΥϩ`ɥҪؤ;ʤɤޤޤ`Щ`ڲΘȡ餬ѥե`ޥmԤ˼ܤ۸_⤹뤳ȤĿˤȤƤޤ
EMC Dell PowerEdge Foundations v2 Exam J D-PE-FN-01 ԇY} (Q49-Q54):| # 49
An IT manager is looking at the Dell PowerEdge R740xd model. What does the "xd" in the model's name indicate?
- A. Indicates extra drives
- B. Indicates high density
- C. Indicates modular design
- D. Indicates tower form factor
⣺A
h
Comprehensive and Detailed Explanation From Exact Extracts: The "xd" in the PowerEdge R740xd model name indicates extra drives, signifying a configuration with enhanced storage capacity, supporting more drives or larger storage options for data-intensive workloads. This distinguishes it from standard R740 models. Modular design and high density apply to other models, and "xd" does not denote a tower form factor (R-series are racks). This naming convention aids in selecting appropriate PowerEdge models. Exact extract:
"Explain how different PowerEdge server models (e.g., rack servers, tower servers, blade servers) are better suited for specific roles." Reference: Dell PowerEdge Foundations v2 Exam Description (D-PE-FN-01), Topic: Introduction to Servers (28%).
| # 50
A network administrator must size an IP subnet to address 60,000 clients Which subnet fulfills this requirement without using unnecessary IP addresses?
⣺C
| # 51
Which are the examples of artifacts that a TPM securely stores for server authentication?
- A. System logs, event records, performance metrics
- B. Firmware updates. BIOS settings, certificates
- C. Passwords, certificates, or encryption keys
- D. Operating system files, application data, user profiles
⣺C
| # 52
A film studio needs high-performance servers for video rendering tasks that demand significant computational power and efficiency per rack space. Which type of specialized module server would be most appropriate for maximizing rendering capabilities within a data center?
- A. GPU-optimized modules for enhanced graphics processing and VDI
- B. Edge-optimized modules for remote deployment and minimum footprint
- C. Mainstream optimized modules balancing performance and cost for general use
- D. Specialized modules with high compute performance and core density per rack
⣺A
h
GPU-optimized modules in PowerEdge servers are designed for workloads like video rendering, which require significant computational power and graphical processing capabilities. These modules leverage GPUs to accelerate parallel tasks, maximizing rendering efficiency within limited rack space, ideal for a film studio' s data center. Edge-optimized modules prioritize minimal footprint for remote deployment, mainstream modules balance general use, and high compute modules focus on core density, not graphics. GPU optimization directly supports rendering tasks. Exact extract: "Describe and position PowerEdge server solutions for File Sharing, High-Performance Computing (HPC), and Generative AI workloads... Explain how different PowerEdge server models are better suited for specific roles." Reference: Dell PowerEdge Foundations v2 Exam Description (D-PE-FN-01), Topic: Server Architecture and Roles (22%).
| # 53
What is a key advantage of differential backups compared to full backups?
- A. Faster restore times
- B. Better RPO
- C. Lower storage requirements
- D. Only one copy to restore
⣺A
| # 54
D-PE-FN-01JԇY^ȥ}οҪȤǤ礦¤æǤ顢ԇYΜʂrgʤǤ礦Ǥ顢ʤԇYD-PE-FN-01οҪǤ褯ԇYΜʂ褦ˡԷ֤ꤷĩ`xkΤһ¤ʤȤǤԇY˺ϸǤ뤫ɤvBФʆ}ǤǤ顢ShikenPASSD-PE-FN-01}xkƤ
D-PE-FN-01J^Y: https://www.shikenpass.com/D-PE-FN-01-shiken.html
- D-PE-FN-01ձZЌ 🐃 D-PE-FN-01}o 🧿 D-PE-FN-01}o ⤵ ⇛ [url]www.mogiexam.com ⇚{ D-PE-FN-01 }}`D-PE-FN-01ԇYʂ[/url]
- yD-PE-FN-01mĤD-PE-FN-01㏊rgԇYԇYΜʂ䷽Dell PowerEdge Foundations v2 ExamJ^Y 🦐 ☀ [url]www.goshiken.com ️☀️ϡ D-PE-FN-01 oϤǥ`ɤΤmʥȤǤD-PE-FN-01}o[/url]
- yD-PE-FN-01mĤD-PE-FN-01㏊rgԇYԇYΜʂ䷽Dell PowerEdge Foundations v2 ExamJ^Y 🎣 ⮆ D-PE-FN-01 ⮄oϤǥ`☀ [url]www.passtest.jp ️☀️֥ȤD-PE-FN-01ԇYʂ[/url]
- yD-PE-FN-01mĤD-PE-FN-01㏊rgԇYԇYΜʂ䷽Dell PowerEdge Foundations v2 ExamJ^Y 🥵 ▷ [url]www.goshiken.com ◁[ D-PE-FN-01 ]ơoϤǥ`ɤƤD-PE-FN-01}o[/url]
- 赤D-PE-FN-01㏊rgԇY-ԇYΜʂ䷽-ЄĤD-PE-FN-01J^Y 🤭 ➤ [url]www.jptestking.com ⮘⇛ D-PE-FN-01 ⇚ơoϤǥ`ɤƤD-PE-FN-01ձZָ[/url]
- D-PE-FN-01ϸ 🍮 D-PE-FN-01ϸY 🤥 D-PE-FN-01Yȡv 🐀 [url]www.goshiken.com ˤϟoϤ✔ D-PE-FN-01 ️✔️}ޤD-PE-FN-01ձZָ[/url]
- D-PE-FN-01ձZָ 😶 D-PE-FN-01ԇY 🏺 D-PE-FN-01Y 🙎 { [url]www.jpexam.com }⏩ D-PE-FN-01 ⏪oϤǥ`D-PE-FN-01vBYο[/url]
- D-PE-FN-01ѧvB} ☕ D-PE-FN-01ձZ憖}h 🥕 D-PE-FN-01ձZЌ 🕍 ⇛ [url]www.goshiken.com ⇚Ȥ⏩ D-PE-FN-01 ⏪}ʹD-PE-FN-01Y[/url]
- D-PE-FN-01ԇYʂYϡD-PE-FN-01ԇY}AD-PE-FN-01ԇY} 😜 [url]www.passtest.jp ǡ D-PE-FN-01 ơoϤǥ`ɤƤD-PE-FN-01ձZЌ[/url]
- D-PE-FN-01ԇYΜʂ䷽gĤD-PE-FN-01㏊rgԇYؔDell PowerEdge Foundations v2 ExamJ^Y 🎹 { D-PE-FN-01 }}ե⇛ [url]www.goshiken.com ⇚ˤƗD-PE-FN-01ϸY[/url]
- D-PE-FN-01Y 🥢 D-PE-FN-01J^Y 🤠 D-PE-FN-01ձZ 🧑 rgoϤʹ⇛ D-PE-FN-01 ⇚ԇY}➠ [url]www.mogiexam.com 🠰ȤǗD-PE-FN-01ձZ[/url]
