New Topic
[Linux] Get rid of android
36
【Linux】 Get rid of android
Posted at 7/21/2022 04:49:32      View:5577 | Replies:17        Print      Only Author   [Copy Link] 1#
Hello!
I was able to make the bootable SD card for Ubuntu 20.04. However, now, when I remove the SD card, only android shows up. I don't want to have android on the board anymore, both because I want the extra storage space which is being taken up by the android partition, and would like to have the SD card available. Is there a way for me to do this?
Posted at 7/21/2022 09:57:39        Only Author  2#
If you want your ubunut in SD, then boot from SD, and just run fdisk to wipe out EMMC
If you want to replace android with ubuntu in EMMC, and use sd card as extra storage, then follow the wiki to make a update sd card
https://wiki.t-firefly.com/en/RO ... irmware-via-sd-card
After update , wipe out your update sd card so that become a normal sd for extra storage
Posted at 2/19/2024 14:28:01        Only Author  3#
Posted at 2/19/2024 16:58:15        Only Author  4#
Posted at 11/5/2024 03:59:31        Only Author  5#
Posted at 4/29/2025 17:07:33        Only Author  6#
Very much so. Even though you are not familiar with the mechanics of the game or the game itself, you can understand why this particular genre of game is so addictive. The enjoyment that you get from playing lol beans with your loved ones or friends is the primary focus of this game.
Posted at 7/1/2025 16:15:51        Only Author  7#
Okay, that's a tricky one! I had a similar problem with a Raspberry Pi once. It sounds like the board is defaulting to the internal Android bootloader. Have you checked the BIOS/UEFI settings (if your board has them) to ensure it's prioritizing SD card boot? Also, have you tried flashing the board with a blank image before flashing Ubuntu? Sometimes that wipes everything clean. As a last resort, search for specific forum discussions related to your board model, someone may have a custom bootloader solution. Eggy Car on YouTube might actually have a video on fixing broken bootloaders too!
Posted at 7/1/2025 17:13:05        Only Author  8#
Hey there! I ran into a similar issue. It sounds like your system is prioritizing the Android bootloader. Have you tried exploring the BIOS settings to change the boot order? Sometimes, forcing it to boot from the SD card first might help. It's a bit like trying to win at Uno Online , you need to strategically play your cards (or in this case, boot options) to get the desired outcome. Hopefully, a quick BIOS tweak solves it!
Posted at 8/9/2025 09:42:10        Only Author  9#
Posted at 9/19/2025 10:35:53        Only Author  10#
It sounds like you're making great progress with Ubuntu! To completely remove Android from your board, you might need to wipe the existing partitions and create a new one for Ubuntu. It may seem tricky, but sometimes a fresh start can be really rewarding. Speaking of fresh experiences, if you're looking for something fun to enjoy during your breaks, check out "Snow Rider 3D" – it’s a fantastic way to unwind! You can find it here: Snow Rider 3D
Return to List
12
