Bluetooth problem after programming flash
17
Posted at 11/2/2015 05:05:12      View:4753 | Replies:3        Print      Only Author   [Copy Link] 1#
Hi,
I'm trying to program the QN9021 (on the small firefly board which only has a QN9021) but after the programming, the device cannot be found as Bluetooth. I used UART programming through QBlue and also SWD programming through Keil, but it occurs in both cases. To find the Bluetooth device I used both android apps and Qtool of Qblue, but the moment I program a board it cannot be found anymore. Using NVDSConfigurator of QBlue I can assign a new Bluetooth name, and it would be saved to flash, but again the device would not be found anymore. I would appreciate any help, I'm new to developing boards with LTE bluetooth.
Thanks in advance
Posted at 11/3/2015 06:16:58        Only Author  2#
Nevermind, I found that I have to enable the advertising through the program during run.
Posted at 1/10/2026 23:48:11        Only Author  3#
日常生活の低生産性と低効率にまだ圧倒されていますか?答えが「はい」の場合、PRINCE2-Foundationガイド急流に注意してください。バランスのとれた一流のサービスを提供するため、夢のPRINCE2-Foundation証明書を取得し、希望の職業に就くことができます。当社の製品にはいくつかの主要な機能があり、PRINCE2-Foundationテストの質問に満足していただけると信じています。そして、PRINCE2-Foundation試験問題を一度試してみると、きっと気に入るはずです。
Posted at 1/22/2026 15:44:07        Only Author  4#
擁有IAPP AIGP認證考試證書可以幫助在IT領域找工作的人獲得更好的就業機會,也將會為成功的IT事業做好鋪墊。
