FirePrime Linux--FirePrime Linux- How to add input support for touch-screen
1661
administrator
Rank: 9Rank: 9Rank: 9
Posted at 10/12/2015 15:44:14      View3134 | Replies2        Print      Only Author   [Copy Link] 1#
FirePrime Linux--FirePrime Linux- How to add input support for touch-screenBy Busybee
1.1Brief
X11 Window system uses evdevto handle the touch even. How to add the support for the touch screen? It requires the following two steps:
1Add  X11 config file,specify evdev driver for touch screen devices.
2Improve evdev driver supports itself for touch screen,  adding support for simulate right mouse button.
1.2 Configuration
Create a new file /etc/X11/xorg.conf.d/10-evdev-gslX680.confadd the following
  1. Section "InputClass"
  2.         Identifier "gslX680 evdev touchscreen"
  3.         MatchProduct    "gslX680"
  4.         MatchDevicePath "/dev/input/event*"
  5.         Option "EmulateThirdButton" "true"
  6.         Option "EmulateThirdButtonTimeout" "500"
  7.         Option "EmulateThirdButtonMoveThreshold" "50"
  8.         Driver "evdev"
  9. EndSection
Copy the code
1.3 Improve the touch screen support of evdev driver
The system evdev driver can not support the android touch screen input driver very well.Need to path and recompile, the following describes the detail steps:
1.3.1 Install compiling tools environment and relevant dependent libraries
  1. sudo apt-get install build-essentials
  2. sudo apt-get build-dep xserver-xorg-input-evdev
Copy the code
1.3.2 Extract the source code,patch and compile
  1. sudo apt-get source xserver-xorg-input-evdev
  2. cd xserver-xorg-input-evdev-2.9.0/src
  3. GITHUB=https://github.com/TeeFirefly/xf86-input-evdev/tree/ba37709e2aab50354c9925ca1e975779a16c67dc
  4. wget $GITHUB/src/emuThird.c
  5. wget $GITHUB/src/evdev.c
  6. wget $GITHUB/src/evdev.h
  7. cd ..
  8. make -j4
Copy the code
1.3.3 Install the compiled module
  1. mv /usr/lib/xorg/modules/input/evdev_drv.so /usr/lib/xorg/modules/input/evdev_drv.so.orig
  2. cp src/.libs/evdev_drv.so /usr/lib/xorg/modules/input/evdev_drv.so
Copy the code
Reboot the system to take effect.
Posted at 1/9/2026 18:13:00        Only Author  2#
Your article has truly stayed with me, thank you for sharing. Latest test C_HRHPC_2505 simulations has outstanding resources that are free of charge.
Posted at 2/16/2026 04:52:56        Only Author  3#
Thank you for the brilliant share, it really left me in awe! Valid CISSP exam questions vce provides quality resources, and they're free for you to use.
