Bad performance about display YUV data via OpenGL ES
17
Posted at 8/31/2016 15:20:15      View5353 | Replies8        Print      Only Author   [Copy Link] 1#
When I use Android 5.1 and call the following OpenGL function, it took too much time.glTexImage2D(GL_TEXTURE_2D, 0, GL_LUMINANCE_ALPHA, 3840 / 2, 2160 / 2, 0, GL_LUMINANCE_ALPHA, GL_UNSIGNED_BYTE, uv_data);
It will take about 94ms to send data to GPU.
But when I use Android 4.4.2 (SD boot), it works fine!
I can update 25 frame per second.
What can I do to solve this problem on Android 5.1?
super moderator
Rank: 8Rank: 8
Posted at 9/2/2016 10:29:32        Only Author  2#
Hi
    there are some problems in the GPU(mali) driver.we will fixed and update it later.
Posted at 1/9/2026 11:01:42        Only Author  3#
The article is really inspiring; thank you for sharing! The Interactive DEP-2025 course test was a key factor in my professional growth, and now Im sharing it with you for free!
Posted at 1/15/2026 11:10:45        Only Author  4#
This article is fantastic, I really appreciate you sharing it. The New LEED-Green-Associate exam format exam is right around the corner. Wish me luck!
Posted at 1/20/2026 09:48:27        Only Author  5#
By reading this article, I have gained a deeper understanding of the topic. Thanks to the Mule-Dev-202 reliable exam dumps demo, I received a promotion and salary increase. Its free now for everyone. Wishing you all success in your careers!
Posted at 1/26/2026 18:46:47        Only Author  6#
Your article was truly remarkable, Im so grateful for it. CSCP valid practice questions sheet offers excellent resources for free.
Posted at 2/12/2026 00:14:58        Only Author  7#
The article was a real game-changer for me. The Question 300-220 explanations test that helped me earn a promotion and salary raise is free for you today. Best of luck reaching your career goals!
Posted at 3/6/2026 05:08:53        Only Author  8#
This article is absolutely extraordinary, thank you for your share! I hope the C-TS4FI-2023 reliable exam cram sheet materials are helpful to you, and theyre offered free of charge.
Posted at 3/10/2026 08:18:36        Only Author  9#
Die Fragenkataloge von It-Pruefung enthalten die Lernmaterialien und Simulationsfragen zur HP HPE7-A07 Zertifizierungsprfung. Noch wichtiger bieten wir die originalen HPE7-A07 Fragen und Antworten.
