New Topic
MMC Error
31
MMC Error
Posted at 1/25/2017 03:07:21      View12461 | Replies13        Print      Only Author   [Copy Link] 1#
Hi
i am currently booting a new firefly board from an SDCard containing a Debian image and I keep getting these errors when i am logged in over minicom:
mmcblk0: error -110 sending status command, retrying
mmcblk0: error -115 sending stop command, original cmd response 0x900, card status 0x900
mmcblk0: error -84 transferring data, sector 1097784, nr 256, cmd response 0x900, card status 0x0
mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
mmcblk0: error -84 transferring data, sector 219840, nr 8, cmd response 0x900, card status 0xb00
While the board is operational I would like to understand if there is any issue.
On an older Firefly RK3288 board I do not see any issues with the same image.
Any ideas ?
Thanks
A
super moderator
Rank: 8Rank: 8
Posted at 2/5/2017 09:27:46        Only Author  2#
Hi
the older firefly RK3288 board , you mean  the public test development board (0809) ?
Posted at 2/7/2017 19:17:29        Only Author  3#
By older I mean a board we ordered about a year ago. The older board has a brown base board but the new one was ordered a couple of weeks ago and has a black base boards.
Thanks
A
super moderator
Rank: 8Rank: 8
Posted at 2/8/2017 09:43:09        Only Author  4#
hi   could you take a picture with the older and the newer board like this ?
Posted at 2/13/2017 18:35:51        Only Author  5#
Hi
Thanks for your reply. Hope the photos are okay.
The old board date read 2014.09.30
The new board date reads 2016.06.23
Thanks
A
super moderator
Rank: 8Rank: 8
Posted at 2/14/2017 15:22:05        Only Author  6#
Hi
these two boards have very little changes,so it shouldn't show different results with the same image,
Can you use the SDcard when the system is ready?(android or ubuntu )
please make sure the hardware is ok.
Posted at 2/14/2017 18:17:13        Only Author  7#
I can use the SD Card on Ubunut but not without seeing the error i described above consistently on the serial port.
I also see some Bus Errors when trying to do any file accesses.
Regards
A
super moderator
Rank: 8Rank: 8
Posted at 2/15/2017 14:21:48        Only Author  8#
Hi
I have tried boot a ubuntu image from SDCard with the hardware version "20160623" like yours, But I haven't get any error log of mmcblk0 like yours .
So,about your debian image, did you make it by yourself? which kernel did you use?
Posted at 2/17/2017 22:01:20        Only Author  9#
Kernel version is 4.1.0 and its the same used across both boards. Also trying it on a board with a date 2016-11-16 seems to work
The ones labeled 2016.06.23 seem to have an issue
A
super moderator
Rank: 8Rank: 8
Posted at 2/18/2017 09:25:22        Only Author  10#
Hi
how many boards labeled 2016.06.23 do you have?
All of them have the issue?
Return to List
12
