2026 300-620–100% Free Exam Collection | Authoritative Exam 300-620 Dumps
28
Posted at 5/16/2026 20:50:00      View:42 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ActualTestsQuiz 300-620 dumps for free: https://drive.google.com/open?id=1kbi1XnV2nJM4DaY6JrIRoYYrja4-u4f4
All smart devices are suitable to use Implementing Cisco Application Centric Infrastructure pdf dumps of ActualTestsQuiz. Therefore, you can open this Implementing Cisco Application Centric Infrastructure real dumps document and study for the Cisco 300-620 test at any time from your comfort zone. These Cisco 300-620 are updated, and ActualTestsQuiz regularly amends the content as per new changes in the Cisco 300-620 real certification test.
Cisco 300-620 Exam is a certification exam that focuses on the implementation of Cisco Application Centric Infrastructure (ACI). 300-620 exam is designed for IT professionals who are interested in developing their knowledge and skills in building, managing, and deploying ACI solutions. Implementing Cisco Application Centric Infrastructure certification is highly valued in the IT industry as it demonstrates a professional's proficiency in ACI implementation.
Exam Cisco 300-620 Dumps & Exam 300-620 Objectives PdfThe format name of Cisco 300-620 practice test questions is Cisco PDF Questions file, desktop practice test software, and web-based practice test software. Choose the nay type of Implementing Cisco Application Centric Infrastructure 300-620 Practice Exam Questions that fit your 300-620 exam preparation requirement and budget and start preparation without wasting further time.
Cisco 300-620 (Implementing Cisco Application Centric Infrastructure) Certification Exam is designed to validate the skills and knowledge required to implement and manage Cisco's Application Centric Infrastructure (ACI) solutions. ACI is a comprehensive software-defined networking (SDN) architecture that provides centralized automation and policy-driven application profiles, making it easier to manage complex data center environments. 300-620 Exam is targeted towards network engineers, architects, and administrators who want to prove their expertise in deploying and maintaining ACI-based solutions.
Cisco Implementing Cisco Application Centric Infrastructure Sample Questions (Q249-Q254):NEW QUESTION # 249
How is broadcast forwarded in Cisco ACI Multi-Pod after ARP flooding is enabled?
  • A. Within a pod, the ingress leaf switch floods the broadcast frame on all fabric ports.
  • B. For the specific bridge domain, all spines forward the broadcast frames to IPN routers.
  • C. Broadcast frames are forwarded inside the pod and across the IPN using the multicast address that is associated to the bridge domain.
  • D. Ingress replication is used on the spines to forward broadcast frames in the IPN infrastructure.
NEW QUESTION # 250
Refer to the exhibit. The default route is not present in the routing tables of the Cisco ACI leaf switches. All static and direct routes are currently being redistributed and advertised. Which jn must be taken to advertise a default route on the eBGP L30ut?
  • A. Enable a BGP peer prefix policy set to Always.
  • B. Implement an export route map matching 0.0.0.0/0.
  • C. Configure a static default route on the ACI node profiles with next-hop null.
  • D. Create a Default Route Leak Policy on the L3Qut.
For external connections to the fabric that only require a default route, there is support for originating a default route for OSPF, EIGRP, and BGP L3Out connections. If a default route is received from an external peer, this route can be redistributed out to another peer following the transit export route control as described earlier in this article. A default route can also be advertised out using a Default Route Leak policy. This policy supports advertising a default route if it is present in the routing table or it always supports advertising a default route. The Default Route Leak policy is configured in the L3Out connection. https://www.cisco.com/c/en/us/td ... chapter_010100.html
NEW QUESTION # 251
Which action should be taken to ensure authentication if the RADIUS servers are unavailable?
  • A. Set the default login realm to LDAP
  • B. Adjust the priority of server 10.1.1.1 to 1.
  • C. Set the fallback login to local.
  • D. Assign the user to the default role.
Changing the server priority is not logical answer.
The command "aaa user default-role no-login" means that remote users who do not have a user role cannot login. This means that assigning the user to default role will not be able to login.
The "aaa authentication login default" and "aaa authentication login fallback" has identical configuration. The fallback uses RADIUS server. We should change is to local.
NEW QUESTION # 252
An engineer must limit management access to me Cisco ACI fabric that originates from a single subnet where the NOC operates. Access should be limited to SSH and HTTPS only. Where should the policy be configured on the Cisco APIC to meet the requirements?
  • A. policy In the management tenant
  • B. policy on the management VLAN
  • C. ACL on the console interface
  • D. ACL on the management interface of the APIC
https://www.cisco.com/c/en/us/td ... I_chapter_0111.html
NEW QUESTION # 253
An engineer must allow multiple external networks to communicate with internal ACI subnets. Which action should the engineer take to assign the prefix to the class ID of the external Endpoint Group?
  • A. Configure subnets with the External Subnets for External EPG flag enabled.
  • B. Configure subnets with the Import Route Control Subnet flag enabled.
  • C. Enable the Export Route Control Subnet for the External Endpoint Group flag.
  • D. Enable an L30ut with Shared Route Control Subnet.
https://www.cisco.com/c/en/us/td ... _chapter_01001.html
NEW QUESTION # 254
Exam 300-620 Dumps: https://www.actualtestsquiz.com/300-620-test-torrent.html
2026 Latest ActualTestsQuiz 300-620 PDF Dumps and 300-620 Exam Engine Free Share: https://drive.google.com/open?id=1kbi1XnV2nJM4DaY6JrIRoYYrja4-u4f4
