Online Salesforce Integration-Architect Tests | Reliable Integration-Architect B
Posted at 1/17/2026 16:12:42
BTW, DOWNLOAD part of Actual4Cert Integration-Architect dumps from Cloud Storage: https://drive.google.com/open?id=1OxBdoAVeWX4B0qD5SgKyBlFolakWwcqW
All Actual4Cert Integration-Architect pdf questions and practice tests are ready for download. Just choose the right Actual4Cert Integration-Architect practice test questions format that fits your Salesforce Certified Integration Architect Integration-Architect exam preparation strategy and place the order. After placing Integration-Architect Exam Questions order you will get your product in your mailbox soon. Get it now and start this wonderful career booster journey.
To prepare for the Salesforce Integration-Architect exam, candidates should have a solid understanding of Salesforce platform fundamentals, as well as experience with integration technologies, such as REST, SOAP, and middleware platforms. They should also be familiar with enterprise architecture and integration patterns, such as ETL, ESB, and API-led connectivity. There are several resources available to help candidates prepare for the exam, including official Salesforce training courses, study guides, and practice exams. Passing the Salesforce Integration-Architect exam is a great achievement and can help professionals advance their careers in the field of Salesforce integration.
Salesforce Integration-Architect Certification is designed to test your knowledge and expertise in the field of Salesforce Integration. Salesforce Certified Integration Architect certification covers a broad range of topics, including integration architecture, data architecture, API management, data migration, web services, and more. Salesforce Certified Integration Architect certification is ideal for technical architects, solution architects, and developers who are looking to validate their expertise in Salesforce Integration.
2026 Reliable Online Integration-Architect Tests Help You Pass Integration-Architect EasilyJust like the saying goes, it is good to learn at another man’s cost. In the process of learning, it is more important for all people to have a good command of the method from other people. The Salesforce Certified Integration Architect exam questions from our company will help you find the good study method from other people. Using the Integration-Architect Test Guide from our company, you can not only pass your exam, but also you will have the chance to learn about the different and suitable study skills. We believe these skills will be very useful for you near life.
Salesforce Certified Integration Architect Sample Questions (Q10-Q15):NEW QUESTION # 10
Northern Trail Outfitters leverages Sales Cloud. When an opportunity has changed its status to "Closed/Won" and there are products attached, the details should be passed to the OMS for fulfillment operations. The callout from Salesforce to the OMS should be synchronous. What should an integration architect do to satisfy these requirements?
- A. Develop a batch Apex job that aggregates closed opportunities and makes a REST callout to the OMS hourly.
- B. Build a Lightning component that makes a synchronous Apex REST callout to the OMS when a button is clicked.
- C. Write a trigger that invokes an Apex proxy class to make a REST callout to the OMS.
A synchronous requirement in Salesforce implies a Request-Reply pattern where the user waits for a response. To implement this correctly while adhering to platform constraints, the architect must initiate the callout from the User Interface (UI) layer.3 Option C is the correct architectural choice. By using a Lightning component and a button (or a Quick Act4ion), the callout is initiated directly from the user's session. The component calls an Apex controller, which performs the synchronous REST callout to the OMS. This allows the user to receive immediate feedback-such as a "Success" message or an "Error" notification from the OMS-directly on the Opportunity page.
Option A is incorrect because Apex Triggers are prohibited from making synchronous callouts. If a trigger initiates a callout, it must be asynchronous (using @future or Queueable Apex), which violates the business requirement for synchronicity. Making a synchronous call from a trigger would block the database transaction and could lead to "Uncommitted Work Pending" errors or system timeouts. Option B (Batch Apex) is inherently asynchronous and delayed; an hourly job would not provide the real-time, synchronous feedback required during the "Closed/Won" transition. Therefore, moving the integration logic to a UI-driven button is the only way to satisfy the synchronous requirement while staying within Salesforce's execution and transaction limits.
NEW QUESTION # 11
A customer is migrating from an old legacy system to Salesforce. As part of the modernization effort, they would like to integrate al existing systems that currently work with their legacy application with Salesforce.
Which three constraints and pain-points should an integration architect consider when choosing the integration pattern/mechanism?
Choose 3 answers
- A. Error handling mechanisms
- B. System types - APIs, File systems, Email
- C. Multi-language and multi-currency requirement
- D. Reporting and usability requirements
- E. Data Volume and Processing volume
Answer: A,B,E
NEW QUESTION # 12
Universal Containers (UC) uses Salesforce to track the following customer data:
1. Leads,
2. Contacts
3. Accounts
4. Cases
Salesforce is considered to be the system of record for the customer. In addition to Salesforce, customer data exists in anEnterprise Resource Planning (ERP) system, ticketing system, and enterprise data lake. Each of these additional systems have their own unique identifier. UC plans on using middleware to integrate Salesforce with the external systems.
UC has a requirementto update the proper external system with record changes in Salesforce and vice versa.
Which two solutions should an Integration Architect recommend to handle this requirement?
Choose 2answers
- A. Locally cache external ID'S at the middleware layer and design business logic to map updates between systems.
- B. Design an MDM solution that maps external ID's to the Salesforce record ID.
- C. Store unique identifiers in an External ID field in Salesforce and use this to update the proper records across systems.
- D. Use Change Data Capture to update downstream systems accordingly when a recordchanges.
Using Change Data Capture (CDC) to update downstream systems accordingly when a record changes is a solution that can handle this requirement by capturingdata changes in Salesforce and sending them to external systems via a publish-subscribe model. This way, the external systems can receive near real-time updates from Salesforce and synchronize their data accordingly. Designing an MDM solution that maps external ID's to the Salesforce record ID is a solution that can handle this requirement by creating a master data hub that stores and manages the unique identifiers of each system and their relationships. This way, the MDM solution can ensuredata quality,consistency, and accuracy across systems. Locally caching external ID's at the middleware layer and designing business logic to map updates between systems is not a good solution because it can introduce performance and scalability issues, as well as increase the complexity and maintenance cost of the middleware layer. Storing unique identifiers in an External ID field in Salesforce and using this to update the proper records across systems is not enough to handle this requirement, as it does not address how to update Salesforce with record changes from external systems. Reference: Salesforce Integration Architecture Designer Resource Guide, page 27-28
NEW QUESTION # 13
Northern Trail Outfitters (NTO) uses a custom mobile app to interact with its customers. One of the features of the app is Salesforce Chatter Feeds. NTO wants to automatically post a Chatter item to Twitter whenever the post includes the #thanksNTO hashtag.
Which API should an integration architect use to meet this requirement?
- A. Connect REST API
- B. Streaming API to generate PushTopic
- C. REST API
When designing integrations that specifically involve Chatter, social collaboration, or Experience Cloud sites, the Connect REST API (formerly known as the Chatter REST API) is the architecturally recommended choice. While the standard REST API is optimized for CRUD operations on data records, the Connect REST API is specifically designed to handle the complex, nested structures of social feeds, including posts, comments, hashtags, and mentions.
The Connect REST API provides a specialized resource for feed elements that simplifies the process of identifying specific social markers like hashtags. In this use case, the mobile app or a middleware service can subscribe to or query the feed. The Connect REST API returns structured data where hashtags are identified as distinct message segments, making it trivial for an application logic to detect the #thanksNTO tag and trigger a subsequent call to the Twitter API.
From an architectural standpoint, using the Connect REST API offers several advantages over the standard REST API or Streaming API for this requirement:
* Efficiency: Connect REST API responses are structured specifically for presentation in mobile applications, providing only the relevant social metadata and localized content needed for the feed.
* Feature Richness: It provides native support for social actions such as liking, sharing, and following, which are often required alongside feed monitoring.
* Scalability: It is designed to handle the high-volume, real-time nature of social interactions within Experience Cloud and mobile ecosystems.
While the Streaming API (Option B) can notify an application of record changes, it does not provide the rich, formatted social context that the Connect REST API delivers. The standard REST API (Option A) could technically access FeedItem records, but it would require significant custom parsing logic to identify hashtags within the raw body text, whereas the Connect REST API handles this segmenting natively. Therefore, for building custom mobile experiences that interact with Chatter data, the Connect REST API is the superior solution.
NEW QUESTION # 14
The Sales Operations team at Northern Trail Outfitters imports new leads each day. An integrated legacy territory management system assigns territories to leads before Sales team members can work on them. The current integration often experiences latency issues.
Which two recommendations should an Architect make to improve the integration performance?
Choose 2 answers
- A. Legacy system should submit in serial mode.
- B. Legacy system should submit in parallel mode.
- C. Reduce batch size of asynchronous BULK API.
- D. Reduce batch size of synchronous BULK API.
NEW QUESTION # 15
Once you have practiced and experienced the quality of our Integration-Architect exam preparation, you will remember the serviceability and usefulness of them. For the excellent quality of our Integration-Architect training questions explains why our Integration-Architect practice materials helped over 98 percent of exam candidates get the certificate you dream of successfully. Believe me with our Integration-Architect Guide quiz, you will be more confident to pass the exam in the shortest time with ease.
Reliable Integration-Architect Braindumps Ebook: https://www.actual4cert.com/Integration-Architect-real-questions.html
- Try Desktop Salesforce Integration-Architect Practice Test Software For Self-Assessment 🏘 Search for ( Integration-Architect ) and download it for free immediately on ⇛ [url]www.prepawayete.com ⇚ 🆖Integration-Architect Certification Exam Infor[/url]
- Free PDF Quiz Integration-Architect - Salesforce Certified Integration Architect –Professional Online Tests 🐙 The page for free download of ➽ Integration-Architect 🢪 on ( [url]www.pdfvce.com ) will open immediately ⛄Valid Integration-Architect Exam Materials[/url]
- Integration-Architect Materials 😳 Integration-Architect Materials 🍝 Free Integration-Architect Updates 🔡 Search for 《 Integration-Architect 》 and download it for free immediately on ⮆ [url]www.easy4engine.com ⮄ 📣Integration-Architect Vce Torrent[/url]
- Integration-Architect Braindump Free 🛢 Integration-Architect Braindump Free 🐇 Integration-Architect Certification Exam Infor 🗨 Open website ▶ [url]www.pdfvce.com ◀ and search for ➥ Integration-Architect 🡄 for free download 🕝Integration-Architect Latest Exam Camp[/url]
- Certification Integration-Architect Exam 🎍 Integration-Architect Free Practice 🍳 Latest Integration-Architect Test Preparation ❇ Open ✔ [url]www.examdiscuss.com ️✔️ enter ( Integration-Architect ) and obtain a free download 📀Integration-Architect Training Solutions[/url]
- Reliable Integration-Architect Real Test 🏅 Certification Integration-Architect Exam 🍬 Integration-Architect Reliable Test Price 🏗 Open ➽ [url]www.pdfvce.com 🢪 enter ➥ Integration-Architect 🡄 and obtain a free download 🚃Integration-Architect Training Solutions[/url]
- Exam Integration-Architect Reference 🐯 Integration-Architect Certification Exam Infor 😱 Online Integration-Architect Lab Simulation 👿 Open ⮆ [url]www.examdiscuss.com ⮄ and search for ➽ Integration-Architect 🢪 to download exam materials for free 🚕Integration-Architect Free Practice[/url]
- Integration-Architect Free Practice 🗼 Reliable Integration-Architect Real Test 🗣 Integration-Architect Valid Exam Tips 👗 Open website ⇛ [url]www.pdfvce.com ⇚ and search for ▶ Integration-Architect ◀ for free download 🍕Integration-Architect Test Objectives Pdf[/url]
- Salesforce - Integration-Architect - Pass-Sure Online Salesforce Certified Integration Architect Tests 🏹 Enter ✔ [url]www.dumpsmaterials.com ️✔️ and search for ➥ Integration-Architect 🡄 to download for free 🚼Integration-Architect Valid Test Questions[/url]
- [url=https://djondemand.net/?s=Pass%20Guaranteed%20Salesforce%20-%20Unparalleled%20Integration-Architect%20-%20Online%20Salesforce%20Certified%20Integration%20Architect%20Tests%20%f0%9f%93%9e%20Go%20to%20website%20%e2%9e%a4%20www.pdfvce.com%20%e2%ae%98%20open%20and%20search%20for%20[%20Integration-Architect%20]%20to%20download%20for%20free%20%f0%9f%8d%90Integration-Architect%20Latest%20Exam%20Camp]Pass Guaranteed Salesforce - Unparalleled Integration-Architect - Online Salesforce Certified Integration Architect Tests 📞 Go to website ➤ www.pdfvce.com ⮘ open and search for [ Integration-Architect ] to download for free 🍐Integration-Architect Latest Exam Camp[/url]
- New Online Integration-Architect Tests 100% Pass | Professional Reliable Integration-Architect Braindumps Ebook: Salesforce Certified Integration Architect 🍓 Enter ⏩ [url]www.vce4dumps.com ⏪ and search for ➤ Integration-Architect ⮘ to download for free 🧧Integration-Architect Braindump Free[/url]
- kishorgroup.com, pct.edu.pk, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, learnith.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BONUS!!! Download part of Actual4Cert Integration-Architect dumps for free: https://drive.google.com/open?id=1OxBdoAVeWX4B0qD5SgKyBlFolakWwcqW
