Which partitioning to keep only linux stuffs
638
Posted at 1/8/2016 05:35:24      View5695 | Replies6        Print      Only Author   [Copy Link] 1#
Hello,
My project is an embedded application that will run on Linux only. To make room in the eMMC I want to remove partitions which are not needed for a single Linux boot. Is it possible - I mean safe - to do this? And how ?
Thanks
Posted at 1/14/2016 09:55:37        Only Author  2#
If I understand you correctly, you mean how to cut partitions from a multiboot system to a single Linux system?
I recommend not to do it that way. You can start with the single Linux firmware, or build your own firmware.
Posted at 1/20/2016 20:34:07        Only Author  3#
busybee Posted at 1/14/2016 09:55
If I understand you correctly, you mean how to cut partitions from a multiboot system to a single Li ...
Thank you for your answer.
I've one more question
Just to be sure. There's an image named "Ubuntu" at this location on the Firefly wiki:
http://en.t-firefly.com/en/firenow/firefly_rk3288/download/
If I use this image while following this tutorial:
http://wiki.t-firefly.com/index. ... en#Flash_update.img
Will I end up with a single Linux with an Ubuntu rfs?
And what about the recovery mode?
Thank you
Posted at 1/28/2016 14:10:31        Only Author  4#
Yes, you are right.
What kind of recovery mode would you expect?
Posted at 2/1/2016 20:00:24        Only Author  5#
FesterBester38 Posted at 1/20/2016 20:34
Well, i don't have a clear idea about the recovery mode. I'm thinking to a mean to boot the processor into a mode that would enable me - for instance - to reload a working kernel version if for some reason the last one isn't working well. There's a possibility to force the Firefly board to boot in a "loader mode" as explained here:
http://wiki.t-firefly.com/index.php/Firefly-RK3288/Boot_mode/en
This loader mode is entered when the RECOVERY switch is pressed at some point during the boot process. When this "loader/recovery" mode is entered, the loader is waiting for commands.
Will this switch still have an effect after the flashing of the single linux firmware?
On other platforms (e.g. Mac OS X) you can boot from a recovery partition and you end up running a lite version of MacOS. Same I think on a Windows machine. Is it possible to get such a "recovery" mode on a Firefly board? In essence, this would be sort of dual boot between a full scale Linux OS+ rfs on one hand and a reduced Linux OS+rfs on the other hand.
restricted members
Posted at 1/10/2026 05:05:08        Only Author  6#
˽JuniperJN0-105ѧ̲ĤκϸʤϷdz˸ߤs99Ǥ JN0-105Ά}ȥȤΟoϥ`ɤԇäṩJN0-105ԇYȥȤl˸¤ơʮ֤ʥƥȥХ󥯤ȡäՓȌg΃A׷EǤ褦ˤޤxkǤ3ĤΥЩ`⤵Ƥ뤿ᡢѧxkǤޤ JN0-105¤|ϡUYNʌTҤˤäƾɤˤޤȤƤޤäơuƷُ뤹뤳ȤϷdz˱ǤꡢयΥåȤޤ
Posted at 1/14/2026 21:25:12        Only Author  7#
Your article was incredibly insightful, and Im truly thankful for it. I used the Reliable new IIA-CIA-Part3 exam format to get promoted and raise my salary. Its free for everyone now. Wishing you quick career growth!
