New Topic
How to use HDMI audio?
27
Posted at 8/22/2016 09:52:02      View8974 | Replies12        Print      Only Author   [Copy Link] 1#
The analog audio is working fine, but no matter what I do, I cannot seem to get the HDMI audio to output to my sound system at all.
I used to have this problem with Raspberry Pi, but was able to change something in boot.txt to force it to always emit audio no matter if it can detect that it should or not.  Maybe I need a similar change here?
Can anyone help me to get HDMI audio output working with my firefly?
super moderator
Rank: 8Rank: 8
Posted at 8/22/2016 10:24:41        Only Author  2#
Hi
  Have you try PulseAudio Volume Control?
Posted at 8/23/2016 05:41:51        Only Author  3#
@isle yes, I have. It's exactly the same behaviour. My amp doesn't even show the audio LEDs, so I'm pretty confident that the audio mode of the HDMI output is not even being enabled. I need some way to get it to ignore the EDID or similar, I *think*, just like with my Raspberry Pi
Posted at 8/23/2016 05:49:34        Only Author  4#
How can I change the kernel command line issued by the bootloader? I think that may hold the answer.
Posted at 8/23/2016 06:25:33        Only Author  5#
Ok, I figured out how to change kernel command line with rkflashtool -- tried adding `hdmi.audio=1` as I had seen for sunxi, but no change, so apparently that is not the parameter name for rockchip (surprise, surprise).
Are there good docs on what arguments the rockchip kernel wants somewhere?
super moderator
Rank: 8Rank: 8
Posted at 8/23/2016 10:04:13        Only Author  6#
Hi
  which firmware did you use? or did you make it by yourself ?
Posted at 8/24/2016 05:06:45        Only Author  7#
@isle I'm using the latest dual-boot firmware image
Posted at 8/24/2016 06:23:34        Only Author  8#
When I play audio over the RKSPDIFCARD device the light on the optical port comes on, and it goes off again when the audio stops. So *something* is happening. But not hearing anything over HDMI and no lights on my amp to show that it's receiving any audio signal.
Posted at 8/24/2016 06:40:19        Only Author  9#
I just booted to the Android, just to try that. No matter what audio device I pick, sound comes out of the analog port and nothing over HDMI.
super moderator
Rank: 8Rank: 8
Posted at 8/24/2016 09:55:12        Only Author  10#
Hi
   did the system recognised the HDMI sound card when you insert your sound system?
  what did you get  from "cat /proc/asound/cards"?
Return to List
12
