New Topic
firefly-rk3399: Boot from SDMMC not working
69
Posted at 8/29/2017 16:01:33      View8233 | Replies13        Print      Only Author   [Copy Link] 1#
Hi,
I've burned images into eMMC and it's booting fine. then I have burned on SDMMC card and inserted into TFCARD reader on board.
The bootlog still shows booting from eMMC and hang at bootloader level, here is the log[1] and firefly-rk3388 claims that it support SDMMC boot [2], if So Do I miss anything.
Please let me know how should I boot from SDMMC?
[1] https://paste.ubuntu.com/25423391/
[2] http://wiki.t-firefly.com/index.php/Firefly-RK3399/Boot_mode/en
super moderator
Rank: 8Rank: 8
Posted at 8/30/2017 09:37:01        Only Author  2#
the loader of the SDMMC is not as same as the one of EMMC
so, please use this one if you want boot on SD .
https://drive.google.com/file/d/ ... Tg/view?usp=sharing
Posted at 8/30/2017 16:15:53        Only Author  3#
Thanks.
Can you send the steps how to write this image on SD card?
Posted at 8/30/2017 18:43:35        Only Author  4#
Here are the steps I tried with upgrade_tool
Rockusb>cd
List of rockusb connected
DevNo=1        Vid=0x2207,Pid=0x330c,LocationID=101        Loader
Found 1 rockusb,Select input DevNo,Rescan press <R>,Quit press <Q>:1
Rockusb>sd
The  Device did not support this operation!
Rockusb>td
Test Device OK.
Rockusb>rid
Flash ID:45 4D 4D 43 20
Rockusb>rfi
Flash Info:
        Manufacturer: SAMSUNG,value=00
        Flash Size: 14910MB
        Block Size: 512KB
        Page Size: 2KB
        ECC Bits: 0
        Access Time: 40
        Flash CS: Flash<0>
Rockusb>rci
Chip Info: 43 30 33 33 0 0 0 0 0 0 0 0 30 30 31 56
Rockusb>uf Firefly-rk3399_xubuntu1604_SD_201705151725.img
Loading firmware...
Loading firmware failed!
Rockusb>ul Firefly-rk3399_xubuntu1604_SD_201705151725.img
Loading loader...
Loading loader failed!
Rockusb>db Firefly-rk3399_xubuntu1604_SD_201705151725.img
Rockusb>ef firmware Firefly-rk3399_xubuntu1604_SD_201705151725.img
Loading loader...
Rockusb>ef loader Firefly-rk3399_xubuntu1604_SD_201705151725.img
Loading loader...
Rockusb>
super moderator
Rank: 8Rank: 8
Posted at 8/31/2017 09:43:43        Only Author  5#
Posted at 8/31/2017 13:35:43        Only Author  6#
Yes, it's working.
Can you send steps for u-boot, I've build SPL(with ATF+Cortex-m0) and U-boot as two binaries, please send how to write it on SD and boot.
super moderator
Rank: 8Rank: 8
Posted at 9/1/2017 09:46:54        Only Author  7#
Posted at 1/10/2026 05:30:27        Only Author  8#
Broadcom인증 250-589덤프로Broadcom시험을 패스,하지 못하셨다구요? 최선을 다했는데도 실패하였다는 말은 영원히 하지마세요. Broadcom인증 250-589시험을 패스하는 방법은 많고도 많습니다. KoreaDumps의Broadcom인증 250-589덤프로 시험에 다시 도전해보세요. KoreaDumps의Broadcom인증 250-589덤프는 착한 가격에 100%에 달하는 적중율과 패스율을 보장해드립니다. 시험에서 불합격성적표를 받으시면 덤프구매시 지불한 덤프비용을 환불처리해드립니다. KoreaDumps의Broadcom인증 250-589덤프로 시험패스를 꿈꿔보세요.
restricted members
Posted at 1/18/2026 09:43:26        Only Author  9#
What an encouraging read, thank you for sharing this article! Thanks to the Valid JN0-650 test collection sheet, I achieved a promotion and salary boost. Now its free for all. Best wishes in reaching your career goals!
restricted members
Posted at 1/20/2026 15:18:17        Only Author  10#
Your article is truly inspiring, thank you for sharing such brilliance! Sharing CDPSE latest test guide materials questions for freeboost your career and salary with this key resource!
Return to List
12
