Network PCIe Card not detected in rk3399
Posted at 4/16/2018 19:03:57
View8894
Replies15
Dear,
I am using the firefly RK-3399 board which has Mini PCIe connector on it.
A PCIe Network card is inserted into Mini PCIe slot using a "Mini PCI-E to PCI-E Express 1X Extension Cord Adapter Card with USB Riser Card"
For some reason the PCIe card is not detected in the firefly board when checked using "lspci" command. lspci command shows nothing.
Could you please throw some points which can help us to identify why the card is not detected?
Setup Details:
Extension Cord Adapter purchased from AMAZON: http://a.co/b5k9Oju
If you have ever came across issue with the Riser cards, please suggest us the suitable Mini PCIe to PCIe extension cord.
Waiting for your technical suggestion.
