OV13850 AF algorithm
21
Posted at 4/16/2017 21:59:08      View:4961 | Replies:5        Print      Only Author   [Copy Link] 1#
Hi Folks,
I wanted to change the speed of AF algorith in OV13850 camera. The current speed (when streaming 1080p-video) is 67 ms between each consective steps by the VCM (8 steps in total form 10 cm to inifinite postion of the VCM). Though, the streaming is 30 fps at this resolution, but the AF fps are half of that (15 fps, 67 ms), which means that there is frame skipping when implementing AF.
I belive to the change the AF speed I have to have access to the code of (libisp_silicomimageisp_api.so) in the following directoryfirefly-rk3288\hardware\rk29\camera\Config.
Could any one help me to confrim the source code of the .so file is avaialbe? or where can I change such AF speed for OV13850, which file I should make the changes?
Your prompt response is highly appreciated.
super moderator
Rank: 8Rank: 8
Posted at 4/20/2017 09:33:59        Only Author  2#
try to change the fps in the "OV13850.xml" file.
Posted at 9/26/2017 00:12:43        Only Author  3#
Hi Sheba, Isle,
I also would like to modify the autofocus algorithm.
I’d like to experiment the assistance of a distance sensor to optimize autofocus.
How can we get the libisp_silicomimageisp_api.so source code ?
Posted at 3 day before        Only Author  4#
This article is truly outstanding, thank you for sharing. Free VMA latest exam name study resources available for all—good luck!
Posted at 3 day before        Only Author  5#
I feel so inspired after reading this article, thank you for the share! New B2C-Commerce-Architect learning materials offers valuable insights, and it’s all free.
Posted at yesterday 08:12        Only Author  6#
What an extraordinary article, I’m truly thankful for your share! Grab your free Valid examcollection AZ-500 test questions—promotion and salary increases await!
