[General] AP-222新版題庫上線|輕鬆通過Public Sector Solutions Accredited Professional |馬上下載安裝
【General】 AP-222新版題庫上線|輕鬆通過Public Sector Solutions Accredited Professional |馬上下載安裝
Posted at 2/16/2026 16:15:17      View:82 | Replies:1        Print      Only Author   [Copy Link] 1#
如果您在使用我們的Salesforce AP-222考古題失敗了,我們承諾給您全額退款,您需要的是像我們發送你失敗的AP-222考試成績單來申請退款就可以了。經過我們確認之后,就會處理您的請求,這樣客戶擁有足夠的保障放心購買我們的Salesforce AP-222考古題。選擇我們的AP-222題庫資料可以保證你可以在短時間內學習及加強IT專業方面的知識,所以信任Fast2test是您最佳的選擇!
Fast2test 考題網覆蓋了真實的 AP-222 考試指南,並根據其編定適合全球考生都能通用的 AP-222 題庫,讓每一位考生都能順利通過 Salesforce AP-222 考試。我們承諾使用 AP-222 考題的考生可以一次通過相關認證考試,對于一次不過的全額退款,避免您的後顧之憂。你現在就可以去網上可以免費下載我們提供的部分關於 Salesforce AP-222 題庫的模擬測試題和答案作為嘗試。
AP-222考題 & AP-222最新考證如果你還在猶豫是否選擇Fast2test,你可以先到Fast2test網站下載我們免費提供的部分考試練習題和答案來確定我們的可靠性。如果你選擇下載我們的提供的所有考試練習題和答案,Fast2test敢100%保證你可以以高分數一次性通過Salesforce AP-222 認證考試。
最新的 Accredited Professional AP-222 免費考試真題 (Q60-Q65):問題 #60
Bobahaven has implemented Public Sector Solutions to manage constituent applications for permits and licenses. However, they have noticed their call center is receiving a large number of phone calls asking similar questions about the new permit and license application processes. Bobahaven is looking for advice on providing up-to-date information about permit and license processes to constituents so their call center inbound call numbers can be reduced.
Which solution would allow constituents to find answers to the* questions before beginning the application process while reducing implementation and maintenance costs?
  • A. Implement Salesforce Knowledge, and publish articles to an unauthenticated Experience site page for constituents.
  • B. Implement Salesforce Knowledge, and publish articles to the Bobahaven public website CMS via outbound API calls.
  • C. Implement Salesforce Knowledge, and publish articles to an authenticated Experience site page for constituents.
  • D. Implement Salesforce Knowledge, and publish articles to the Bobahaven public website via Lightning Out.
答案:A
解題說明:
Salesforce Knowledge is a feature that allows Bobahaven to create, manage, and publish articles that provide up-to-date information about permit and license processes to constituents. By publishing articles to an unauthenticated Experience site page, Bobahaven can reduce the implementation and maintenance costs by not requiring login or user management for the site visitors. Constituents can access the articles before beginning the application process and find answers to their questions without calling the call center.
Reference: https://trailhead.salesforce.com ... ions-design/create- guided-digital-forms-with-omniscript
問題 #61
A Public Sector Organization (PSO has installed Grants Management and would like to ensure that users cannot self-register on the Experience Cloud site, as the PSO would like to register users for now manually.
What configuration should the Technical Consultant perform to meet this requirement?
  • A. Update the appropriate contact page layouts and add the 'Enable Customer User' action
  • B. Enable self-registration in the Digital Experiences setup menu
  • C. Enable manual registration in the Digital Experiences setup menu
  • D. Update the appropriate contact page layouts and add the 'Register User' action
答案:A
解題說明:
In Salesforce Public Sector Solutions, particularly when dealing with the Grants Management and Experience Cloud, controlling user registration is crucial. To ensure that users cannot self-register and instead are manually registered by the Public Sector Organization, the following steps should be taken:
* Disable Self-Registration:
* Navigate to Setup > Digital Experiences > All Sites.
* Select the relevant Experience Cloud site.
* Under Administration > Login & Registration, ensure that self-registration is disabled.
* Manual User Registration:
* Go to Setup > Object Manager > Contact > Page Layouts.
* Select the appropriate page layout(s) where you want to add the manual registration action.
* Add the 'Enable Customer User' quick action to the page layout. This action allows administrators to manually create user records from contacts.
By updating the contact page layouts to include the 'Enable Customer User' action, administrators can manually control which contacts are enabled as users for the Experience Cloud site. This method is straightforward and aligns with standard Salesforce practices for managing user access in Experience Cloud.
* Salesforce Help: Experience Cloud Sites Login and Registration
* Salesforce Help: Enable Customer User
* Salesforce Grants Management Documentation
問題 #62
A government agency is currently using Business Rules Engine (BRE). Part of the current Prioritization matrix includes household income and household size. To correctly calculate the Households Area Median Income (AMI) pool, the Expression Set needs to calculate the AMI and then evaluate the percentage against a predefined Federal Income Limit table to determine the prioritization pool.
To accomplish this, the BRE designer should include how many decision matrices?
  • A. 3; One to contain the percentages in each prioritization pool, a second to contain the household data, and the third to contain the Federal Income limits to evaluate.
  • B. 1; Only one to contain the prioritization pools with the Federal Income Limits.
  • C. 2; One to contain the percentages in each prioritization pool and the second to contain the Federal Income limits to evaluate.
  • D. 1; Only to contain the prioritization pools.
答案:C
解題說明:
In the context of a government agency using the Business Rules Engine (BRE) to calculate and determine Households Area Median Income (AMI) prioritization using a matrix, the BRE designer should use two decision matrices (Option C). One matrix is necessary to calculate the AMI and to evaluate it against the federal income limits, which involves determining the percentage of AMI relative to these limits. The second matrix is then used to categorize these percentages into different prioritization pools. This allows for a clear separation of logic in handling the data: one matrix for the determination of AMI percentages and another for the allocation into prioritization pools based on these percentages.
Option A and D, which suggest using only one matrix, would not provide the necessary separation of calculations and evaluations for clarity and maintenance. Option B suggests using three matrices, which overcomplicates the process without clear necessity for three separate matrices when two are sufficient for the tasks at hand.
問題 #63
Bobahaven has previously implemented Salesforce Service Cloud to...
Constituent self-service digital experience. This was implemented previously ..... now ready to implement the public sector Solutions License, Permits...
What is the right solution for this requirement that minimizes customization and site....
  • A. Create a new Applications digital experience using the licenses and permits Experince ... components to the experience site.
  • B. Create a new Application digital experience using the Licenses and Permits Expression ...as OmniScripts and FlexCards to the new experience site.
  • C. Create OmniOut components and deploy them to the existing Help Center experience site.
  • D. Create new pages and deploy components such as OmniScripts and FlexCard within the ...
答案:B
解題說明:
For Bobahaven to implement Salesforce Public Sector Solutions for licenses and permits while minimizing customization and leveraging existing components, the best approach is to create a new digital experience specifically for applications. Here's why:
* New Digital Experience:
* Creating a new digital experience tailored for licenses and permits ensures that the specific needs of this functionality are met without interfering with the existing self-service site.
* This allows for a focused and optimized user experience.
* Licenses and Permits Expression:
* Utilizing the Licenses and Permits Expression simplifies the implementation as it is designed specifically for these processes, reducing the need for extensive customization.
* OmniScripts and FlexCards:
* Deploying OmniScripts and FlexCards within the new experience site ensures a seamless and interactive user interface. These tools are designed to handle complex workflows and data displays efficiently.
* OmniScripts can guide users through the application process step-by-step, while FlexCards provide quick-glance information and actionable widgets.
Steps to implement this solution:
* Create New Experience Site:
* Go to Setup > Digital Experiences > All Sites.
* Click New to create a new site and choose a template that fits the application process.
* Add Components:
* Use OmniStudio tools to create and configure OmniScripts and FlexCards.
* Deploy these components to the new experience site.
This approach provides a structured and scalable solution, aligning with Salesforce best practices and leveraging out-of-the-box functionalities to minimize customization.
* Salesforce Help: OmniStudio Components
* Salesforce Public Sector Solutions Documentation
問題 #64
Foodvania has adopted Salesforce Public Sector Solutions to get relief to small businesses experiencing hardship due to the pandemic. Foodvania would like the recipients to apply for relief in a self-service portal, allowing for the upload of supporting documentation and the capability to check the status of their application. What should the consultant recommend using?
  • A. The consultant should recommend the Grants Management product which Includes the Grants Portal feature
  • B. The consultant should recommend the Grants Management product with the Outbound Funds Module to give the recipients the capability to review their applications status.
  • C. The consultant should recommend the Outbound Funds Module Which Includes the Grants Portal feature and the procurement for an allotment to Experience Cloud licenses so as the recipients may review their applications status
  • D. The consultant should recommend the Outbound Funds Module Which Includes the Grants Portal feature
答案:A
解題說明:
The consultant should recommend the Grants Management product which includes the Grants Portal feature to allow the recipients to apply for relief in a self-service portal, allowing for the upload of supporting documentation and the capability to check the status of their application. Grants Management is a prebuilt app that comes with Public Sector Solutions. It can help public sector agencies to manage the entire grant lifecycle, from application to award to reporting. Grants Portal is a component of Grants Management that can help public sector agencies to create a digital experience site for grant applicants or recipients. Grants Portal can allow the recipients to apply for relief in a self-service portal, upload supporting documentation, and check the status of their application. Reference: https://help.salesforce.com/s/articleView?
id=psc_admin_setup_grants_management.htm&type=5&language=en_US
問題 #65
Fast2test的資深專家利用他們豐富的知識和經驗研究出來的關於Salesforce AP-222 認證考試的練習題和答案和真實考試的試題有95%的相似性。我相信你對我們的產品將會很有信心。如果你選擇使用Fast2test的產品,Fast2test可以幫助你100%通過你的一次參加的Salesforce AP-222 認證考試。如果你考試失敗,我們會全額退款的。
AP-222考題: https://tw.fast2test.com/AP-222-premium-file.html
Salesforce AP-222新版題庫上線 如果你不知道如何才能高效的通過一科認證,這裏給你的建議是選擇一套優秀的題庫,這樣可以起到事半功倍的效果,AP-222筆記在AP-222考試準備期間的作用是非常大的,所以我們在平時的學習以及AP-222問題集練習中,一定要實時記錄好核心內容,盡量多抓要點,購買AP-222考題認證題庫學習資料的客戶,如果您發現我們的產品存在嚴重質量問題或者對您的學習沒起到幫助作用,我們將退還您購Fast2test AP-222考題學習資料費用,Salesforce AP-222新版題庫上線 考生選用英語作為考試語種,我們承諾將盡力幫助你通過 Salesforce 的 AP-222 認證考試。
浩然正氣寄寓於宇宙間,是構成日、月、星辰、高山大河的元氣,付鷲說著便AP-222稍稍將四人的壹些作惡的事說了壹遍,如果你不知道如何才能高效的通過一科認證,這裏給你的建議是選擇一套優秀的題庫,這樣可以起到事半功倍的效果。
高通過率的AP-222新版題庫上線 |第一次嘗試輕鬆學習並通過考試,優秀的AP-222:Public Sector Solutions Accredited ProfessionalAP-222筆記在AP-222考試準備期間的作用是非常大的,所以我們在平時的學習以及AP-222問題集練習中,一定要實時記錄好核心內容,盡量多抓要點,購買Accredited Professional認證題庫學習資料的客戶,如果您發現我們的產品存在嚴重質量問題或者對您的學習沒起到幫助作用,我們將退還您購Fast2test學習資料費用。
Posted at 2/18/2026 15:47:04        Only Author  2#
Such a brilliant article, thank you for sharing this gem with us. This New exam 2V0-16.25 camp free helped me get promoted and receive a raise. Now I’m offering it for free. Wishing you all success in your career paths!
