Hardware
FCP_GCS_AD-7.6C & FCP_GCS_AD-7.6yԇ
Posted at 1/23/2026 03:06:05
View204
Replies4
⣬@ЩPDFExamDumps FCP_GCS_AD-7.6ԇ}IJփݬFMģhttps://drive.google.com/open?id=1aWeVxFrnk9ZnZ4orVn6oGwzEW4UDzTEu
ЩWվڻWϞṩƷ|µFortinetFCP_GCS_AD-7.6ԇWYϣ]κPĿɿC@YҪf@PDFExamDumpsһкărֵĆ}FortinetFCP_GCS_AD-7.6ԇǷdzҪģڂYӍٰlչĕrPDFExamDumpsֻһʲNxPDFExamDumpsPDFExamDumpsṩĿ}Yһͨ^yԇʲNأṩY϶µģ@ҲǴͨ^`C˵ġ
҂Fortinet FCP_GCS_AD-7.6}YǶܵģײݡͨ^ʹ҂}YώɸƷ|FCP_GCS_AD-7.6JCoՓʲôO䣬҂}Y϶ְ֧bʹáµFCP_GCS_AD-7.6}YϲHITܣ߀ܱC棬ṩoõķգPDFExamDumpsɞһֵهĻ顣һ֮ȣ߀и}ęͿԵõ°Fortinet FCP_GCS_AD-7.6ԇ}
ɿFCP_GCS_AD-7.6C |ͨ^ʵĿԇ|ֵهFCP_GCS_AD-7.6FCP - Google Cloud Security 7.6 Administrator҂֪ITИIǂͮaIǎӽlչ朗l֮һĵλҲepزɺҕġITJCITИIYֶ֮һͨ^JCĸ挢õܺõҪͨ^K£ԽhһӖߣҪxͨ^@JCӖYԴPDFExamDumps FortinetFCP_GCS_AD-7.6ԇӖYϮʲijɹʸ_100%܉Cͨ^ԇ
µ Public Cloud Security FCP_GCS_AD-7.6 Mԇ} (Q30-Q35):} #30
An organization has decided to deploy an active-active high-availability cluster in Google Cloud.
Which three load balancing features are critical to the successful deployment of the cluster? (Choose three.)
- A. The health check used by the internal and the external passthrough network load balancer
- B. The session termination of the external passthrough network load balancer
- C. The L3_DEFAULT protocol in the forwarding rule of the internal passthrough network load balancer
- D. The forwarding rule for the internal passthrough network load balancer as the next hot for custom routes
- E. The symmetric hashing of the internal passthrough network load balancer
𰸣A,D,E
}f
Health checks ensure load balancers route traffic only to healthy cluster members.
Forwarding rules act as next hops in routing, directing traffic appropriately within the HA cluster.
Symmetric hashing ensures consistent and balanced traffic distribution across cluster members, critical for active-active deployments.
} #31
Google Cloud network services offer vast functionality and inter-connectivity between the cloud and on- premises networks.
Which three additional functions does FortiGate offer when deployed in Google Cloud to complement the native services offered by Google Cloud? (Choose three.)
- A. Secure SD-WAN with application visibility
- B. SSL VPN
- C. Web filtering
- D. SSL inspection
- E. OSPF over IPSec
𰸣A,B,D
}f
FortiGate provides SSL VPN capabilities for secure remote access.
It offers SSL inspection to decrypt and inspect encrypted traffic for threats.
FortiGate supports Secure SD-WAN with deep application visibility and control, enhancing network performance and security beyond native Google Cloud services.
} #32
Your organization is deciding between deploying FortiGate active-passive high-availability (HA) in Google Cloud using either the software-defined network (SDN) connector or load balancers.
What two reasons should your organization choose the SDN connector over the load balancer deployment?
(Choose two.)
- A. There isess administrative overhead.
- B. Cost is lower.
- C. The SDN connector supports multizone failover.
- D. Failovers are faster because of to API calls.
𰸣A,B
}f
Using the SDN connector avoids additional load balancer costs, making it more cost-effective.
The SDN connector enables multizone failover by directly managing network routing, which load balancers do not inherently support.
} #33
An organization is planning to deploy two FortiGate VMs in two different regions.
Which two Google Cloud core components can span both FortiGate VMs in both regions? (Choose two.)
- A. Google Cloud subnet
- B. Google Cloud virtual private cloud
- C. Google Cloud zone
- D. Google Cloud project
𰸣B,D
}f
A Google Cloud VPC can span multiple regions, allowing FortiGate VMs in different regions to be part of the same network.
A Google Cloud project provides the administrative boundary that can include resources across multiple regions and VPCs, enabling centralized management of both FortiGate VMs.
} #34
An administrator is troubleshooting network connectivity issues between two VMs deployed in Google Cloud.
One VM is a FortiGate located in the subnet "wan" that is part of the VPC "e-commerce". The other VM is a Windows server located in subnet "servers", which is also in the "e-commerce" VPC.
What are two reasons you cannot pint the Windows server from FortiGate? (Choose two.)
- A. The Windows firewall is blocking the traffic.
- B. Add a Google Cloud firewall rule to allow ICMP traffic inbound to the Windows firewall VM.
- C. ICMP traffic is blocked between Google Cloud subnets by default.
- D. The default Google Cloud firewall policy does not allow this traffic.
𰸣A,B
}f
Google Cloud firewall rules are stateful and, by default, do not allow ICMP traffic; you must explicitly allow ICMP inbound traffic to the Windows VM.
The Windows VM's own firewall might block ICMP traffic, preventing ping responses.
} #35
ՄFCP_GCS_AD-7.6ԇJCyҕǿɿԣPDFExamDumpsFCP_GCS_AD-7.6ԇӖYeOӋȵĹЧʣվȫȈ@헿ԇͨ^
FCP_GCS_AD-7.6yԇ: https://www.pdfexamdumps.com/FCP_GCS_AD-7.6_valid-braindumps.html
҂ITFṩ挍Fortinet FCP_GCS_AD-7.6}솖}ʹ𰸣ُI҂FCP_GCS_AD-7.6}Ŀ͑@L_һM£_ĕrgWFortinet FCP_GCS_AD-7.6C 㽛^҂ڵӖԺܿITI֪RㅢӿԇÜʂ䣬PDFExamDumpsṩPublic Cloud SecurityFCP_GCS_AD-7.6ԇMԇ}}ͱݵھձMܠQFCP_GCS_AD-7.6ԇ},ͨ^FCP_GCS_AD-7.6ԇԇԇ҂M FCP_GCS_AD-7.6}Hwһ°ɣҲھWMd҂ṩIJP FCP_GCS_AD-7.6yԇ - FCP - Google Cloud Security 7.6 Administrator JCԇľ}ʹLԇt҂Ŀɿᣬ쌢҂ FCP_GCS_AD-7.6yԇ - FCP - Google Cloud Security 7.6 Administrator }ُ܇ɣFortinet FCP_GCS_AD-7.6C ֪ʲNÆ
yԞČͽo ԭ@ҼжNJڰГvħӡsС˔ʮȻɢ҂ITFṩ挍Fortinet FCP_GCS_AD-7.6}}ʹ𰸣ُI҂FCP_GCS_AD-7.6}Ŀ͑@L_һM£_ĕrgW
100ϸFCP_GCS_AD-7.6CպYԇеIṩ̺̓|FCP_GCS_AD-7.6yԇ㽛^҂ڵӖԺܿITI֪RㅢӿԇÜʂ䣬PDFExamDumpsṩPublic Cloud SecurityFCP_GCS_AD-7.6ԇMԇ}}ͱݵھձMܠQFCP_GCS_AD-7.6ԇ},ͨ^FCP_GCS_AD-7.6ԇ
ԇԇ҂M FCP_GCS_AD-7.6}Hwһ°ɣҲھWMd҂ṩIJP FCP - Google Cloud Security 7.6 Administrator JCԇľ}ʹLԇt҂Ŀɿᣬ쌢҂ FCP - Google Cloud Security 7.6 Administrator }ُ܇ɣ
- µFCP_GCS_AD-7.6Cգͨ^FCP_GCS_AD-7.6ԇ 🌐 ▛ [url]www.vcesoft.com ▟➡ FCP_GCS_AD-7.6 ️⬅️ԫ@ȡMdFCP_GCS_AD-7.6ԇ}[/url]
- FCP_GCS_AD-7.6CգFCP - Google Cloud Security 7.6 AdministratorԇɿJCFortinet FCP_GCS_AD-7.6yԇ 🔰 ڣ [url]www.newdumpspdf.com WվdM➽ FCP_GCS_AD-7.6 🢪}ռFCP_GCS_AD-7.6}YӍ[/url]
- ܚgӭFCP_GCS_AD-7.6CգMdFCP_GCS_AD-7.6ԇYϵõҪFortinetC 🎹 Ո⇛ [url]www.vcesoft.com ⇚WվMd FCP_GCS_AD-7.6 }FCP_GCS_AD-7.6¿C[/url]
- FCP_GCS_AD-7.6}d 🐨 FCP_GCS_AD-7.6Wָ 🐶 FCP_GCS_AD-7.6} 🏦 ^➤ [url]www.newdumpspdf.com ⮘p@ȡ{ FCP_GCS_AD-7.6 }MdFCP_GCS_AD-7.6}[/url]
- °FCP_GCS_AD-7.6} 😓 FCP_GCS_AD-7.6yԇ} 🌂 FCP_GCS_AD-7.6ԇ} 🚑 _Wվ tw.fast2test.com FCP_GCS_AD-7.6 MdFCP_GCS_AD-7.6TJC
- FCP_GCS_AD-7.6°}Ͼ ➕ FCP_GCS_AD-7.6] 😺 °FCP_GCS_AD-7.6} 🔕 _Wվ➡ [url]www.newdumpspdf.com ️⬅️✔ FCP_GCS_AD-7.6 ️✔️MdFCP_GCS_AD-7.6yԇ}[/url]
- FCP_GCS_AD-7.6JCָ ☸ FCP_GCS_AD-7.6}YӍ ⚓ FCP_GCS_AD-7.6}YӍ 📋 Ո☀ [url]www.pdfexamdumps.com ️☀️WվMd⮆ FCP_GCS_AD-7.6 ⮄}FCP_GCS_AD-7.6Wָ[/url]
- 挍FCP_GCS_AD-7.6C |һ·Lԇ춌Wͨ^ԇ͙Fortinet FCP - Google Cloud Security 7.6 Administrator 🥁 Md▛ FCP_GCS_AD-7.6 ▟ֻM➥ [url]www.newdumpspdf.com 🡄WվFCP_GCS_AD-7.6¿C[/url]
- ЧFCP_GCS_AD-7.6CգFortinet 🌋 Md FCP_GCS_AD-7.6 ֻ➤ tw.fast2test.com ⮘FCP_GCS_AD-7.6TJC
- õFCP_GCS_AD-7.6C - ɿFCP_GCS_AD-7.6yԇ 🚛 ▷ [url]www.newdumpspdf.com ◁WվM➽ FCP_GCS_AD-7.6 🢪}FCP_GCS_AD-7.6JCָ[/url]
- ͨ^ʵFCP_GCS_AD-7.6C - Fortinet FCP_GCS_AD-7.6yԇ棺FCP - Google Cloud Security 7.6 Administrator°l 🔐 ➡ tw.fast2test.com ️⬅️✔ FCP_GCS_AD-7.6 ️✔️K@ȡMdFCP_GCS_AD-7.6JCָ
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.notebook.ai, Disposable vapes
P.S. PDFExamDumpsGoogle DriveϷM2026 Fortinet FCP_GCS_AD-7.6ԇ}죺https://drive.google.com/open?id=1aWeVxFrnk9ZnZ4orVn6oGwzEW4UDzTEu
