SD card boot fail
11
SD card boot fail
Posted at 9/8/2017 15:48:36      View7070 | Replies5        Print      Only Author   [Copy Link] 1#
I am trying to boot a firefly rk3288 from sd card.  I downloaded the sd card image 201503021436 from your link and wrote it to an sd card using the sd firmware tool 1.45.  However, when booting, I got a lot of error messages which seemed the parameter file was incorrect and the kernel/image was bad.
  GetParam
    W: Invalid Parameter's tag (0x7BD32A6C)!
    Invalid parameter
    W: Invalid Parameter's tag (0xF07F8F7D)!
    Invalid parameter
    W: Invalid Parameter's tag (0xAE8ED94E)!
    Invalid parameter
    W: Invalid Parameter's tag (0x5EFFD968)!
    Invalid parameter
    W: Invalid Parameter's tag (0xEDDF0B28)!
    Invalid parameter
    W: Invalid Parameter's tag (0xE89DA830)!
    Invalid parameter
    W: Invalid Parameter's tag (0x00000802)!
    Invalid parameter
    W: Invalid Parameter's tag (0x00000000)!
    Invalid parameter
    failed to find part:boot
    failed to prepare fdt from boot!
    failed to find part:resource
    failed to prepare fdt from resource!
I found another thread saying which had the similar issue (http://bbs.t-firefly.com /forum.php?mod=viewthread&tid=1777&extra=&page=1) and tried that solution of cleaning the emmc of spl and uboot.  However, I still could not boot the board:
DDR Version 1.00 20160530
In
Channel a: DDR3 200MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel b: DDR3 200MHz
Memory OK
Memory OK
OUT
U-Boot 2014.10-RK3288-10 (Oct 13 2016 - 10:04:48)
CPU: rk3288
cpu version = 0
CPU's clock information:
    arm pll = 600000000HZ
    periph pll = 297000000HZ
    ddr pll = 200000000HZ
    codec pll = 384000000HZ
Board:  Rockchip platform Board
DRAM:  Found dram banks: 1
Adding bank:0000000000000000(0000000100000000)
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 0
SDCard Boot.
storage init OK!
Using default environment
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can't find dts node for pwm1
DCDC vdd_logic has been used, pwm regulator not init it.
Can't find dts node for fuel guage cw201x
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 0000-00-00#0.00
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
read logo on state from dts [0]
no fuel gauge found
Hit any key to stop autoboot:  0
boot or recovery image sha mismatch!
Unable to boot:boot
try to start recovery
'recovery' does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
ERROR: [rk_load_image_from_storage]: bootrk: bad boot or kernel image
Unable to boot:backup
try to start rockusb
I have successfully boot from sd card last year with previous boards.  But it seems to have stopped working with the new boards.
Also, for my application, I want to be able to boot from sd card without having to modify the emmc for each board.  Is it possible to provide a new sd card boot.
super moderator
Rank: 8Rank: 8
Posted at 9/11/2017 09:49:10        Only Author  2#
Yes ,the old firmware did not support our new device.
Posted at 1/10/2026 16:50:02        Only Author  3#
ڬF@˲ŝY߀кܶИIȱ˲ŵģITИIஔȱgԵ˲šCIPS L4M4 JCԇǂzITgJCԇ֮һFast2testһoӖCIPS L4M4 JCԇPg֪RľWվ
Posted at 1/13/2026 02:12:23        Only Author  4#
ISACA인증AAIA시험을 위하여 최고의 선택이 필요합니다. ExamPassdump 선택으로 좋은 성적도 얻고 하면서 저희 선택을 후회하지 않을것니다.돈은 적게 들고 효과는 아주 좋습니다.우리ExamPassdump여러분의 응시분비에 많은 도움이 될뿐만아니라ISACA인증AAIA시험은 또 일년무료 업데이트서비스를 제공합니다.작은 돈을 투자하고 이렇게 좋은 성과는 아주 바람직하다고 봅니다.
Posted at 1/16/2026 05:37:41        Only Author  5#
Im grateful to have come across such a fantastic article. The content in C-BCSPM-2502 real question on the exam is available for free, created to help you succeed.
Posted at 1/30/2026 19:15:46        Only Author  6#
That article was nothing short of a masterpiece in terms of knowledge. D-UN-OE-23 dumps free provides quality resources, and they're free for you to use.
