[General] Valid Salesforce PDII Test Papers & Exam PDII Fees
51
General Valid Salesforce PDII Test Papers & Exam PDII Fees
Posted at 2/8/2026 09:49:04      View143 | Replies1        Print      Only Author   [Copy Link] 1#
What's more, part of that Actual4Dumps PDII dumps now are free: https://drive.google.com/open?id=1PcgvKMPNr_vCAcVhPfqK5o5RZUcEaSas
Each of the formats is unique in its own way and helps every Salesforce certification exam applicant prepare according to his style. All of these formats are user-friendly and very helpful to clear the Salesforce PDII Exam exam on the first try. Salesforce PDII dumps are packed with multiple benefits that will help you prepare Salesforce PDII Exam successfully in a short time. In case of new updates, Salesforce PDII dumps will immediately provide you with up to 1 year of free questions updates. These free updates will save your time in case of Salesforce PDII Exam real exam changes.
You may be also one of them, you may still struggling to find a high quality and high pass rate PDII study question to prepare for your exam. Our product is elaborately composed with major questions and answers. Our study materials are choosing the key from past materials to finish our PDII Torrent prep. It only takes you 20 hours to 30 hours to do the practice. After your effective practice, you can master the examination point from the PDII exam torrent. Then, you will have enough confidence to pass it. So start with our PDII torrent prep from now on.
Exam PDII Fees | PDII Exam ForumOur Salesforce PDII practice exam software will record all the attempts you have made in the past and display any modifications or improvements made in each attempt. This Platform Developer II (PDII) exam simulation software enables you to track your progress and quantify how much you have improved.
For developers who pass the PDII Exam, there are many benefits. They will have demonstrated their expertise in Salesforce development, which can lead to better job opportunities and higher salaries. They will also be well-equipped to design and implement complex solutions on the Salesforce platform, which can help organizations grow and succeed.
Salesforce Platform Developer II Sample Questions (Q42-Q47):NEW QUESTION # 42
A developer needs test data for Apex test classes. What can the developer use to provide test data to the test methods? Choose 2 answers
  • A. List ls = Test. loadData (Lead.sObjectType, 'myTestLeads');
  • B. Database . createTestRecords (10)
  • C. MyDataFactory. createTestRecords (10)
NEW QUESTION # 43
REST uses___________.
  • A. The HTTP class
  • B. The HTTPRequest class
  • C. All of the above
  • D. The HTTPResponse class
NEW QUESTION # 44
A company has code to update a Request and Request Lines and make a callout to their external ERP system's REST endpoint with the updated records.
The CalloutUtil. makeRestCallout fails with a 'You have uncommitted work pending. Please commit or rollback before calling out' error. What should be done to address the problem?
  • A. Change the CalloutUtil.makeRestCallout to an @InvocableMethod method.
  • B. Move the CalloutUtil.makeRestCallout method call below the catch block.
  • C. Change the CalloutUtil.makeRestCallout to an @future method
  • D. Remove the Database.setSavepoint and Database.rollback.
NEW QUESTION # 45
What is the transaction limit on the number of "sendEmail" method calls?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
  • E. There is no limit
The reserveEmailCapacity methods let you declare how many emails you want to send prior to actually sending, allowing you to handle limit errors prematurely
NEW QUESTION # 46
A developer created and tested a Visualforce page in their developer sandbox, but now receives reports that users are encountering ViewState errors when using it in Production. What should the developer ensure to correct these errors?
  • A. Ensure properties are marked as private.
  • B. Ensure queries do not exceed governor limits.
  • C. Ensure variables are marked as Transient.
  • D. Ensure profiles have access to the Visualforce page.
NEW QUESTION # 47
You can also be part of successful PDII exam candidates. To do this you just need to enroll in PDII exam and strive hard to get success in the Salesforce PDII certification exam. In this journey, the PDII Dumps can help you perfectly. The Platform Developer II PDII Exam Questions are the real, updated Platform Developer II PDII exam practice Test that will assist you in Salesforce PDII exam preparation and enable you to pass the final Salesforce PDII exam easily.
Exam PDII Fees: https://www.actual4dumps.com/PDII-study-material.html
2026 Latest Actual4Dumps PDII PDF Dumps and PDII Exam Engine Free Share: https://drive.google.com/open?id=1PcgvKMPNr_vCAcVhPfqK5o5RZUcEaSas
Posted at 2/19/2026 02:12:58        Only Author  2#
This article has given me new ideas and methods for my work. Improve your IT abilitiesfree AZ-140 latest test practice now available! Good luck!
