New Topic
rkflashkit non-functional
77
Posted at 6/22/2017 06:53:29      View11210 | Replies14        Print      Only Author   [Copy Link] 1#
I am attempting to flash the rk 3399 board using this guide: http://wiki.t-firefly.com/index.php/Firefly-RK3399/Flash_image/en
When atempting to use firefly's forked rkflashkit(0.1.4) the rk3399 is not even identified by the flashkit. Link:
https://github.com/TeeFirefly/rkflashkit
Using linuxerwang's flaskit(0.1.5) it identifies the rk3399 board but all the options are greyed out.
any ideas on why this is happening?
super moderator
Rank: 8Rank: 8
Posted at 6/22/2017 09:31:56        Only Author  2#
1 ,did you useing the firefly-rk3399 board? or another board?
2 did you pressed the recovery button before power up?
3 have you try the maskrom mode?
Posted at 6/23/2017 11:10:54        Only Author  3#
1. I am using the RK 3399
2. i have pressed recovery key before power up
3. i have not tried masked rom mode
I am able to use android tool on windows to flash. however i still want to flash from linux(ubuntu 16)
when i try to reboot the device from command line i get :
  1. :~$ sudo rkflashkit reboot
  2. Found devices:
  3. 0x2207:0x330c
  4. libusb: error [submit_bulk_transfer] submiturb failed error -1 errno=2
  5. Traceback (most recent call last):
  6.   File "/usr/bin/rkflashkit", line 17, in <module>
  7.     sys.exit(app.main(sys.argv[1:]))
  8.   File "/usr/share/rkflashkit/lib/rkflashkit/climain.py", line 99, in main
  9.     self.parse_and_execute(args)
  10.   File "/usr/share/rkflashkit/lib/rkflashkit/climain.py", line 130, in parse_and_execute
  11.     self.reboot()
  12.   File "/usr/share/rkflashkit/lib/rkflashkit/climain.py", line 205, in reboot
  13.     op.reboot()
  14.   File "/usr/share/rkflashkit/lib/rkflashkit/rktalk.py", line 361, in reboot
  15.     self.__init_device()
  16.   File "/usr/share/rkflashkit/lib/rkflashkit/rktalk.py", line 130, in __init_device
  17.     2, ''.join(prepare_cmd(0x80, 0x00060000, 0x00000000, 0x00000000)))
  18.   File "/usr/share/rkflashkit/lib/rkflashkit/usb1.py", line 1145, in bulkWrite
  19.     return self._bulkTransfer(endpoint, data, sizeof(data), timeout)
  20.   File "/usr/share/rkflashkit/lib/rkflashkit/usb1.py", line 1129, in _bulkTransfer
  21.     raise libusb1.USBError(result)
  22. rkflashkit.libusb1.USBError: LIBUSB_ERROR_IO [-1]
Copy the code
Posted at 6/23/2017 20:50:35        Only Author  4#
Hi cmi,
rkflashkit did not work for me either.
So I used rkdeveloptool.
  1. #!/bin/sh
  2. ../rkdeveloptool/rkdeveloptool db ../rkbin/rk33/rk3399_loader_v1.08.106.bin
  3. sleep 2
  4. ../rkdeveloptool/rkdeveloptool wl 64 idbspl.img
  5. ../rkdeveloptool/rkdeveloptool wl 512 bl3.itb
  6. ../rkdeveloptool/rkdeveloptool rd
Copy the code
super moderator
Rank: 8Rank: 8
Posted at 6/24/2017 09:54:26        Only Author  5#
please use upgrade_tool for instead.
Posted at 6/30/2017 11:51:08        Only Author  6#
fivetechno Posted at 6/23/2017 20:50
Hi cmi,
Can the rkdeveloptool flash the entire packaged update image?
I am having issues with the linux_upgrade_tool as well : https://drive.google.com/file/d/0B7HO8lbGgAqAendKNTZMQlBXS2c/view
when i try to run it gives me permission denied
  1. bash: ./upgrade_tool: Permission denied
Copy the code
sudo gives me
  1. sudo: upgrade_tool: command not found
Copy the code
sudo bash gives me :
  1. upgrade_tool: upgrade_tool: cannot execute binary file
Copy the code
from what i can tell this is a 32 bit application. Is it possible that its having problems with my 64bit Ubuntu 16?
Posted at 7/2/2017 05:44:16        Only Author  7#
Found a solution using Linux_upgrade_tool 1.2 instead of 1.24 seems to work fine. Ver 1.2
Posted at 8/4/2017 03:58:53        Only Author  8#
yes works for me as well on the RK3399, how ever the upgrade_tool is somewhat tricky, i did not use the command line as described.
Instead here is what i did ...
sudo ./upgrade_tool
then you get the tools cryptic interface promting you to choose either rescan/quit or the number of the device it detected. there i just typed 1
after that you get a list of commands you can execute among them UF (or lf to low format first)
you choose (by typing) uf update.img
Now here is the tricky bit!! (i am not sure why it does not work by giving a path to the .img file)
I downloaded the ubuntu image from the firefly website (after download, extract, the result is a cryptic name starting with Firefly_RK3399...bla.img)
rename this file to update.img and move it into the directoy where the upgrade_tool is located. then restart the upgrade tool and choose 1 then when the list appears choos uf update.img ... then it starts to test and upload, when its done the firefly will restart automatically and it worked ...
fine :-)
Posted at 10/10/2017 20:27:03        Only Author  9#
I have the same problem and I have used the recommendations here to install Linux upgrade_tool 1.2.
Everything looks right but my Ubuntu host downt recognize the RK3399 device. I have a message
List of rockusb connected  no found rockusb........ and I quit.
I have downloaded Ubuntu 1604 2017 0511 1112.img from firefly website.
I have renamed and installed everything according to the information here.
I have Ubuntu 16.10 64 bit on my host.
I have tried both recommended methods with the C-connection and Recovery and Reset keys.
Nothing I do makes the my Ubuntu Host to recognize the device!?
Please advise
stentmartin
Posted at 10/11/2017 16:38:05        Only Author  10#
I found a third method to set the device in Loader Mode. The method whats totally different from the other instructions on Internet. However this time it worked and I can start the upgrade_tool and chose my device.
However when I try to low format and flash the device I get an error: creating comm object failed!
It seems as the memory in the device can not be formatted or flashed for some reason. Maybe the memory is protected?
There is also many different Ubuntu.img on the website. Which one is the correct to use?
The messages I have is as follows when I do upgrade_tool uf update.img.
1. Loading firmware
2. Support type: RK330C?? FW Ver: 6.0.01
3. Loader Version: 1.05
4. Creating comm object failed
When I try to do low format upgrade_tool lf, I have the following messages:
1. Lower format quit, Creating comm object failed.
Anyone else with this problem!
stentmartin
Return to List
12
