New Topic
LCD Backlight Error => Solved
198
Posted at 9/4/2018 13:45:08      View7659 | Replies10        Print      Only Author   [Copy Link] 1#
I am working with AIO-3399J and DM-M10R800
I compiled with rk3399-firefly-aio-linux-lvds.dts
and  I checked lcd_pwr_en is high , VDD-CORE is 1.2V , lcd_rst is high, 1.8V
and I checked LCD Board VGH =>5.59V ,  VGL=>-5.6V
AVDD=>11.2V ,VCC_LCD=>3.2V, LED+ => 4.97V, LED- =>0.0V
But LCD backlight is not working. tured off.
what position should I check?
I want to turn on LCD
Posted at 9/5/2018 18:52:45        Only Author  2#
<Solved>
1.edit rk3399-firefly-aio-linux-lvds.dts
        backlight: backlight {
                status = "okay";
                compatible = "pwm-backlight";
                pwms = <&pwm0 0 25000 1>;
                brightness-levels = </*
                          0   1   2   3   4   5   6   7
                           <SKIP>
                        248 249 250 251 252 253 254 255>;
                default-brightness-level = <200>;  => default-brightness-level = <100>;
2.check LED+ of LCD Board
LED+ voltalge should be higher than 11v
when  default-brightness-level is 200,  78% duty, LED+ voltage is 4.9v  => backlight turned off
but   if default-brightness-level is 100,  40% duty,LED+ voltage is 11.4v  => backlight turned on
Success!!!!!!!!
Posted at 2/12/2025 10:07:02        Only Author  3#
Have you fixed it yet? I was playing Chill Guy Clicker and my computer had the same problem as yours. Please help me.
Posted at 2/13/2025 11:08:13        Only Author  4#
Welcome to Quick Draw ! This is the perfect game for those who are passionate about art and love to challenge their intelligence. With each passing second, you will have to draw images for AI to guess. Can you complete them quickly and accurately to prove your talent?
Posted at 6/5/2025 11:18:34        Only Author  5#
LCD backlight error, solved! A common issue with a simple fix, often involving replacing the inverter or checking connections. Celebrate the win with a game of Wordle Unlimited to sharpen your deduction skills. Now, enjoy that perfectly illuminated display.
Posted at 6/17/2025 15:15:27        Only Author  6#
I appreciate your work. Your posts are very interesting and I must say you have done an amazing job. I think this is one of the most positive blogs I have come across. fireboy and watergirl
Posted at 9/8/2025 17:32:55        Only Author  7#
Make sure the data lines (MIPI, LVDS, etc.) that connect the AIO-3399J to the DM-M10R800 are not broken and are properly linked wordle hint. Look at the connecting pins to see if there are any loose connections or shorts.
Posted at 10/27/2025 03:05:59        Only Author  8#
Great technical breakdown youve clearly done thorough voltage checks on the AIO-3399J setup. It reminds me of how Remark Construction approaches troubleshooting: methodical and precise. Maybe double-check the backlight enable signal or PWM control line; thats often the missing piece when all the voltages look right but the LCD stays dark.
Posted at 1/11/2026 11:09:08        Only Author  9#
요즘같이 시간인즉 금이라는 시대에 시간도 절약하고 빠른 시일 내에 학습할 수 있는 PassTIP의 덤프를 추천합니다. 귀중한 시간절약은 물론이고 한번에SAP C_BCSSS_2502인증시험을 패스함으로 여러분의 발전공간을 넓혀줍니다.
Posted at 1/12/2026 05:24:26        Only Author  10#
This is an inspiring article, and Im grateful for your share! Taking the Certification Plat-Admn-201 exam dumps exam soon, hope Ill do well!
Return to List
12
