[Linux] SD card not readable after SW reset from Linux
24
【Linux】 SD card not readable after SW reset from Linux
Posted at 5/17/2019 16:01:20      View:4132 | Replies:0        Print      Only Author   [Copy Link] 1#
Hi all,
     after sw reset from Linux u-boot can't read SD card partition.
  1. root@linaro-alip:~# reboot
  2.          Stopping User Manager for UID 0...
  3. [  OK  ] Stopped target Alcoma RRL.
  4. [  OK  ] Stopped target Timers.
  5.          Stopping Session c1 of user root.
  6. [  OK  ] Stopped target Sound Card.
  7. [  OK  ] Stopped target Multi-User System.
  8.          Stopping Network Name Resolution...
  9.          Stopping LSB: Advanced IEEE 802.11 management daemon...
  10.          Stopping ACPI event daemon...
  11.          Stopping LSB: set CPUFreq kernel parameters...
  12. [  OK  ] Stopped target Login Prompts.
  13.          Stopping Getty on tty1...
  14.          Stopping Serial Getty on ttyFIQ0...
  15. [  OK  ] Stopped Daily apt upgrade and clean activities.
  16. [  OK  ] Stopped Trigger anacron every hour.
  17. [  OK  ] Stopped Daily Cleanup of Temporary Directories.
  18. [  OK  ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
  19.          Stopping Save/Restore Sound Card State...
  20. [  OK  ] Stopped Daily apt download activities.
  21. [  OK  ] Stopped target System Time Synchronized.
  22.          Stopping System Logging Service...
  23. [  OK  ] Stopped ACPI event daemon.
  24. [  OK  ] Stopped System Logging Service.
  25. [  OK  ] Stopped Network Name Resolution.
  26. [  OK  ] Stopped Getty on tty1.
  27. [  680.438935] tty_port_close_start: tty->count = 1 port count = 2.
  28. [  OK  ] Stopped Serial Getty on ttyFIQ0.
  29. [  OK  ] Stopped LSB: Advanced IEEE 802.11 management daemon.
  30. [  OK  ] Stopped Session c1 of user root.
  31. [  OK  ] Stopped User Manager for UID 0.
  32. [  OK  ] Stopped Save/Restore Sound Card State.
  33. [  OK  ] Stopped LSB: set CPUFreq kernel parameters.
  34.          Stopping LSB: Load kernel modules needed to enable cpufreq scaling...
  35. [  OK  ] Removed slice User Slice of root.
  36.          Stopping Login Service...
  37. [  OK  ] Removed slice system-serial\x2dgetty.slice.
  38. [  OK  ] Removed slice system-getty.slice.
  39.          Stopping Permit User Sessions...
  40. [  OK  ] Stopped /etc/rc.local Compatibility.
  41. [  OK  ] Stopped target Network is Online.
  42. [  OK  ] Stopped Login Service.
  43. [  OK  ] Stopped Permit User Sessions.
  44. [  OK  ] Stopped target Network.
  45.          Stopping WPA supplicant...
  46.          Stopping Network Service...
  47.          Stopping Raise network interfaces...
  48. [  OK  ] Stopped WPA supplicant.
  49. [  OK  ] Stopped LSB: Load kernel modules needed to enable cpufreq scaling.
  50. [  OK  ] Stopped target Remote File Systems.
  51.          Stopping D-Bus System Message Bus...
  52. [  OK  ] Stopped Network Service.
  53. [  OK  ] Stopped D-Bus System Message Bus.
  54. [  OK  ] Stopped target Basic System.
  55. [  OK  ] Stopped target Slices.
  56. [  OK  ] Removed slice User and Session Slice.
  57. [  OK  ] Stopped target Paths.
  58. [  OK  ] Stopped ACPI Events Check.
  59. [  OK  ] Stopped target Sockets.
  60. [  OK  ] Closed Syslog Socket.
  61. [  OK  ] Closed ACPID Listen Socket.
  62. [  OK  ] Closed OpenBSD Secure Shell server socket.
  63. [  OK  ] Closed D-Bus System Message Bus Socket.
  64. [  OK  ] Stopped target System Initialization.
  65.          Stopping Update UTMP about System Boot/Shutdown...
  66.          Stopping Load/Save Random Seed...
  67.          Stopping Network Time Synchronization...
  68. [  OK  ] Stopped target Swap.
  69. [  OK  ] Stopped target Encrypted Volumes.
  70. [  OK  ] Stopped Dispatch Password Requests to Console Directory Watch.
  71. [  OK  ] Stopped Forward Password Requests to Wall Directory Watch.
  72.          Stopping Load/Save Screen Backlight…ightness of backlight:backlight...
  73. [  OK  ] Stopped Network Time Synchronization.
  74. [  OK  ] Stopped Load/Save Screen Backlight Brightness of backlight:backlight.
  75. [  OK  ] Stopped Update UTMP about System Boot/Shutdown.
  76. [  OK  ] Stopped Load/Save Random Seed.
  77. [  OK  ] Stopped Create Volatile Files and Directories.
  78. [  OK  ] Removed slice system-systemd\x2dbacklight.slice.
  79. [  OK  ] Stopped Raise network interfaces.
  80. [  OK  ] Stopped Apply Kernel Variables.
  81. [  OK  ] Stopped Load Kernel Modules.
  82. [  OK  ] Stopped target Local File Systems.
  83.          Unmounting /run/user/0...
  84.          Unmounting /var/ram...
  85.          Unmounting /boot...
  86. [  OK  ] Unmounted /var/ram.
  87. [  OK  ] Unmounted /run/user/0.
  88. [  OK  ] Unmounted /boot.
  89. [  OK  ] Reached target Unmount All Filesystems.
  90. [  OK  ] Stopped target Local File Systems (Pre).
  91. [  OK  ] Stopped Create Static Device Nodes in /dev.
  92. [  OK  ] Stopped Remount Root and Kernel File Systems.
  93. [  OK  ] Reached target Shutdown.
  94. [  680.819156] dw_wdt: unexpected close, system will reboot soon
  95. [  680.898628] systemd-journald[172]: Received SIGTERM from PID 1 (systemd-shutdow).
  96. [  680.951241] EXT4-fs (mmcblk0p5): re-mounted. Opts: data=ordered
  97. [  680.956409] EXT4-fs (mmcblk0p5): re-mounted. Opts: data=ordered
  98. Failed to read reboot parameter file: No such file or directory
  99. [  680.967925] cpu4 limit freq=816000 min=816000 max=816000
  100. [  680.971211] cpu0 limit freq=816000 min=816000 max=816000
  101. [  680.974836] I : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_config_rk.c; [Line] : 273; [Func] : kbase_platform_rk_shutdown(); to make vdd_gpu enabled for turning off pd_gpu in pm_framework.
  102. [  680.976614] rk-vcodec ff660000.rkvdec: shutdown
  103. [  680.977099] rk-vcodec ff650000.vpu_service: shutdown
  104. [  680.978071] reboot: Restarting system
  105. DDR Version 1.22 20190506
  106. In
  107. soft reset
  108. SRX
  109. channel 0
  110. CS = 0
  111. MR0=0x18
  112. MR4=0x1
  113. MR5=0x6
  114. MR8=0x8
  115. MR12=0x72
  116. MR14=0x72
  117. MR18=0x0
  118. MR19=0x0
  119. MR24=0x8
  120. MR25=0xFC
  121. CS = 1
  122. MR0=0x18
  123. MR4=0x2
  124. MR5=0x6
  125. MR8=0x8
  126. MR12=0x72
  127. MR14=0x72
  128. MR18=0x0
  129. MR19=0x0
  130. MR24=0x8
  131. MR25=0xFC
  132. channel 1
  133. CS = 0
  134. MR0=0x18
  135. MR4=0x2
  136. MR5=0x6
  137. MR8=0x8
  138. MR12=0x72
  139. MR14=0x72
  140. MR18=0x0
  141. MR19=0x0
  142. MR24=0x8
  143. MR25=0xFC
  144. CS = 1
  145. MR0=0x18
  146. MR4=0x2
  147. MR5=0x6
  148. MR8=0x8
  149. MR12=0x72
  150. MR14=0x72
  151. MR18=0x0
  152. MR19=0x0
  153. MR24=0x8
  154. MR25=0xFC
  155. channel 0 training pass!
  156. channel 1 training pass!
  157. change freq to 416MHz 0,1
  158. Channel 0: LPDDR4,416MHz
  159. Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
  160. Channel 1: LPDDR4,416MHz
  161. Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
  162. 256B stride
  163. channel 0
  164. CS = 0
  165. MR0=0x18
  166. MR4=0x1
  167. MR5=0x6
  168. MR8=0x8
  169. MR12=0x72
  170. MR14=0x72
  171. MR18=0x0
  172. MR19=0x0
  173. MR24=0x8
  174. MR25=0xFC
  175. CS = 1
  176. MR0=0x18
  177. MR4=0x2
  178. MR5=0x6
  179. MR8=0x8
  180. MR12=0x72
  181. MR14=0x72
  182. MR18=0x0
  183. MR19=0x0
  184. MR24=0x8
  185. MR25=0xFC
  186. channel 1
  187. CS = 0
  188. MR0=0x18
  189. MR4=0x2
  190. MR5=0x6
  191. MR8=0x8
  192. MR12=0x72
  193. MR14=0x72
  194. MR18=0x0
  195. MR19=0x0
  196. MR24=0x8
  197. MR25=0xFC
  198. CS = 1
  199. MR0=0x18
  200. MR4=0x2
  201. MR5=0x6
  202. MR8=0x8
  203. MR12=0x72
  204. MR14=0x72
  205. MR18=0x0
  206. MR19=0x0
  207. MR24=0x8
  208. MR25=0xFC
  209. channel 0 training pass!
  210. channel 1 training pass!
  211. channel 0, cs 0, advanced training done
  212. channel 0, cs 1, advanced training done
  213. channel 1, cs 0, advanced training done
  214. channel 1, cs 1, advanced training done
  215. change freq to 856MHz 1,0
  216. ch 0 ddrconfig = 0x101, ddrsize = 0x2020
  217. ch 1 ddrconfig = 0x101, ddrsize = 0x2020
  218. pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
  219. OUT
  220. Boot1: 2019-03-14, version: 1.19
  221. CPUId = 0x0
  222. ChipType = 0x10, 325
  223. mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
  224. mmc: ERROR: Card did not respond to voltage select!
  225. emmc reinit
  226. mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
  227. mmc: ERROR: Card did not respond to voltage select!
  228. emmc reinit
  229. mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
  230. mmc: ERROR: Card did not respond to voltage select!
  231. SdmmcInit=2 1
  232. mmc0:cmd5,20
  233. SdmmcInit=0 0
  234. BootCapSize=0
  235. UserCapSize=15193MB
  236. FwPartOffset=2000 , 0
  237. StorageInit ok = 58566
  238. SecureMode = 0
  239. SecureInit read PBA: 0x4
  240. SecureInit read PBA: 0x404
  241. SecureInit read PBA: 0x804
  242. SecureInit read PBA: 0xc04
  243. SecureInit read PBA: 0x1004
  244. SecureInit read PBA: 0x1404
  245. SecureInit read PBA: 0x1804
  246. SecureInit read PBA: 0x1c04
  247. SecureInit ret = 0, SecureMode = 0
  248. atags_set_bootdev: ret:(0)
  249. GPT part:  0, name:          loader1, start:0x40, size:0x1f40
  250. GPT part:  1, name:          loader2, start:0x4000, size:0x2000
  251. GPT part:  2, name:            trust, start:0x6000, size:0x2000
  252. GPT part:  3, name:             boot, start:0x8000, size:0x38000
  253. GPT part:  4, name:           rootfs, start:0x40000, size:0x4e9fdf
  254. no find partition:uboot.
  255. LoadTrust Addr:0x4000
  256. No find bl30.bin
  257. Load uboot, ReadLba = 2000
  258. hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  259. Load OK, addr=0x200000, size=0x9c558
  260. RunBL31 0x10000
  261. NOTICE:  BL31: v1.3(debug):d98d16e
  262. NOTICE:  BL31: Built : 15:03:07, May 10 2018
  263. NOTICE:  BL31: Rockchip release version: v1.1
  264. INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
  265. INFO:    Using opteed sec cpu_context!
  266. INFO:    boot cpu mask: 0
  267. INFO:    plat_rockchip_pmu_init(1151): pd status 3e
  268. INFO:    BL31: Initializing runtime services
  269. INFO:    BL31: Initializing BL32
  270. INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-96-g3fbe315-dev #4 Fri Jun 30 00:35:17 UTC 2017 aarch64)
  271. INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.1
  272. INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
  273. INFO:    BL31: Preparing for EL3 exit to normal world
  274. INFO:    Entry point address = 0x200000
  275. INFO:    SPSR = 0x3c9
  276. U-Boot 2017.09-gc58a8168bd-dirty (May 15 2019 - 10:28:42 +0200)
  277. Model: Firefly-RK3399 Board
  278. DRAM:  3.9 GiB
  279. MMC:   dwmmc@fe320000: 1, sdhci@fe330000: 0
  280. Card did not respond to voltage select!
  281. mmc_init: -95, time 20
  282. *** Warning - No block device, using default environment
  283. In:    serial@ff1a0000
  284. Out:   serial@ff1a0000
  285. Err:   serial@ff1a0000
  286. Model: Firefly-RK3399 Board
  287. normal boot
  288. Net:   eth0: ethernet@fe300000
  289. Hit any key to stop autoboot:  0
  290. Card did not respond to voltage select!
  291. mmc_init: -95, time 19
  292. switch to partitions #0, OK
  293. mmc1 is current device
  294. *** ERROR: Can't read GPT Entries ***
  295. GPT: Failed to allocate memory for PTE
  296. part_get_info_efi: *** ERROR: Invalid GPT ***
  297. *** ERROR: Can't read GPT header ***
  298. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  299. *** ERROR: Can't read GPT header ***
  300. part_get_info_efi: *** ERROR: Invalid GPT ***
  301. *** ERROR: Can't read GPT header ***
  302. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  303. *** ERROR: Can't read GPT header ***
  304. part_get_info_efi: *** ERROR: Invalid GPT ***
  305. *** ERROR: Can't read GPT header ***
  306. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  307. *** ERROR: Can't read GPT header ***
  308. part_get_info_efi: *** ERROR: Invalid GPT ***
  309. *** ERROR: Can't read GPT header ***
  310. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  311. *** ERROR: Can't read GPT header ***
  312. part_get_info_efi: *** ERROR: Invalid GPT ***
  313. *** ERROR: Can't read GPT header ***
  314. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  315. *** ERROR: Can't read GPT header ***
  316. part_get_info_efi: *** ERROR: Invalid GPT ***
  317. *** ERROR: Can't read GPT header ***
  318. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  319. *** ERROR: Can't read GPT header ***
  320. part_get_info_efi: *** ERROR: Invalid GPT ***
  321. *** ERROR: Can't read GPT header ***
  322. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  323. *** ERROR: Can't read GPT header ***
  324. part_get_info_efi: *** ERROR: Invalid GPT ***
  325. *** ERROR: Can't read GPT header ***
  326. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  327. *** ERROR: Can't read GPT header ***
  328. part_get_info_efi: *** ERROR: Invalid GPT ***
  329. *** ERROR: Can't read GPT header ***
  330. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  331. *** ERROR: Can't read GPT header ***
  332. part_get_info_efi: *** ERROR: Invalid GPT ***
  333. *** ERROR: Can't read GPT header ***
  334. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  335. *** ERROR: Can't read GPT header ***
  336. part_get_info_efi: *** ERROR: Invalid GPT ***
  337. *** ERROR: Can't read GPT header ***
  338. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  339. *** ERROR: Can't read GPT header ***
  340. part_get_info_efi: *** ERROR: Invalid GPT ***
  341. *** ERROR: Can't read GPT header ***
  342. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  343. *** ERROR: Can't read GPT header ***
  344. part_get_info_efi: *** ERROR: Invalid GPT ***
  345. *** ERROR: Can't read GPT header ***
  346. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  347. *** ERROR: Can't read GPT header ***
  348. part_get_info_efi: *** ERROR: Invalid GPT ***
  349. *** ERROR: Can't read GPT header ***
  350. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  351. *** ERROR: Can't read GPT header ***
  352. part_get_info_efi: *** ERROR: Invalid GPT ***
  353. *** ERROR: Can't read GPT header ***
  354. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  355. *** ERROR: Can't read GPT header ***
  356. part_get_info_efi: *** ERROR: Invalid GPT ***
  357. *** ERROR: Can't read GPT header ***
  358. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  359. *** ERROR: Can't read GPT header ***
  360. part_get_info_efi: *** ERROR: Invalid GPT ***
  361. *** ERROR: Can't read GPT header ***
  362. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  363. *** ERROR: Can't read GPT header ***
  364. part_get_info_efi: *** ERROR: Invalid GPT ***
  365. *** ERROR: Can't read GPT header ***
  366. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  367. *** ERROR: Can't read GPT header ***
  368. part_get_info_efi: *** ERROR: Invalid GPT ***
  369. *** ERROR: Can't read GPT header ***
  370. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  371. *** ERROR: Can't read GPT header ***
  372. part_get_info_efi: *** ERROR: Invalid GPT ***
  373. *** ERROR: Can't read GPT header ***
  374. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  375. *** ERROR: Can't read GPT header ***
  376. part_get_info_efi: *** ERROR: Invalid GPT ***
  377. *** ERROR: Can't read GPT header ***
  378. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  379. *** ERROR: Can't read GPT header ***
  380. part_get_info_efi: *** ERROR: Invalid GPT ***
  381. *** ERROR: Can't read GPT header ***
  382. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  383. *** ERROR: Can't read GPT header ***
  384. part_get_info_efi: *** ERROR: Invalid GPT ***
  385. *** ERROR: Can't read GPT header ***
  386. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  387. *** ERROR: Can't read GPT header ***
  388. part_get_info_efi: *** ERROR: Invalid GPT ***
  389. *** ERROR: Can't read GPT header ***
  390. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  391. *** ERROR: Can't read GPT header ***
  392. part_get_info_efi: *** ERROR: Invalid GPT ***
  393. *** ERROR: Can't read GPT header ***
  394. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  395. *** ERROR: Can't read GPT header ***
  396. part_get_info_efi: *** ERROR: Invalid GPT ***
  397. *** ERROR: Can't read GPT header ***
  398. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  399. *** ERROR: Can't read GPT header ***
  400. part_get_info_efi: *** ERROR: Invalid GPT ***
  401. *** ERROR: Can't read GPT header ***
  402. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  403. *** ERROR: Can't read GPT header ***
  404. part_get_info_efi: *** ERROR: Invalid GPT ***
  405. *** ERROR: Can't read GPT header ***
  406. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  407. *** ERROR: Can't read GPT header ***
  408. part_get_info_efi: *** ERROR: Invalid GPT ***
  409. *** ERROR: Can't read GPT header ***
  410. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  411. *** ERROR: Can't read GPT header ***
  412. part_get_info_efi: *** ERROR: Invalid GPT ***
  413. *** ERROR: Can't read GPT header ***
  414. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  415. *** ERROR: Can't read GPT header ***
  416. part_get_info_efi: *** ERROR: Invalid GPT ***
  417. *** ERROR: Can't read GPT header ***
  418. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  419. *** ERROR: Can't read GPT header ***
  420. part_get_info_efi: *** ERROR: Invalid GPT ***
  421. *** ERROR: Can't read GPT header ***
  422. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  423. *** ERROR: Can't read GPT header ***
  424. part_get_info_efi: *** ERROR: Invalid GPT ***
  425. *** ERROR: Can't read GPT header ***
  426. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  427. *** ERROR: Can't read GPT header ***
  428. part_get_info_efi: *** ERROR: Invalid GPT ***
  429. *** ERROR: Can't read GPT header ***
  430. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  431. *** ERROR: Can't read GPT header ***
  432. part_get_info_efi: *** ERROR: Invalid GPT ***
  433. *** ERROR: Can't read GPT header ***
  434. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  435. *** ERROR: Can't read GPT header ***
  436. part_get_info_efi: *** ERROR: Invalid GPT ***
  437. *** ERROR: Can't read GPT header ***
  438. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  439. *** ERROR: Can't read GPT header ***
  440. part_get_info_efi: *** ERROR: Invalid GPT ***
  441. *** ERROR: Can't read GPT header ***
  442. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  443. *** ERROR: Can't read GPT header ***
  444. part_get_info_efi: *** ERROR: Invalid GPT ***
  445. *** ERROR: Can't read GPT header ***
  446. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  447. *** ERROR: Can't read GPT header ***
  448. part_get_info_efi: *** ERROR: Invalid GPT ***
  449. *** ERROR: Can't read GPT header ***
  450. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  451. *** ERROR: Can't read GPT header ***
  452. part_get_info_efi: *** ERROR: Invalid GPT ***
  453. *** ERROR: Can't read GPT header ***
  454. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  455. *** ERROR: Can't read GPT header ***
  456. part_get_info_efi: *** ERROR: Invalid GPT ***
  457. *** ERROR: Can't read GPT header ***
  458. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  459. *** ERROR: Can't read GPT header ***
  460. part_get_info_efi: *** ERROR: Invalid GPT ***
  461. *** ERROR: Can't read GPT header ***
  462. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  463. *** ERROR: Can't read GPT header ***
  464. part_get_info_efi: *** ERROR: Invalid GPT ***
  465. *** ERROR: Can't read GPT header ***
  466. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  467. *** ERROR: Can't read GPT header ***
  468. part_get_info_efi: *** ERROR: Invalid GPT ***
  469. *** ERROR: Can't read GPT header ***
  470. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  471. *** ERROR: Can't read GPT header ***
  472. part_get_info_efi: *** ERROR: Invalid GPT ***
  473. *** ERROR: Can't read GPT header ***
  474. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  475. *** ERROR: Can't read GPT header ***
  476. part_get_info_efi: *** ERROR: Invalid GPT ***
  477. *** ERROR: Can't read GPT header ***
  478. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  479. *** ERROR: Can't read GPT header ***
  480. part_get_info_efi: *** ERROR: Invalid GPT ***
  481. *** ERROR: Can't read GPT header ***
  482. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  483. *** ERROR: Can't read GPT header ***
  484. part_get_info_efi: *** ERROR: Invalid GPT ***
  485. *** ERROR: Can't read GPT header ***
  486. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  487. *** ERROR: Can't read GPT header ***
  488. part_get_info_efi: *** ERROR: Invalid GPT ***
  489. *** ERROR: Can't read GPT header ***
  490. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  491. *** ERROR: Can't read GPT header ***
  492. part_get_info_efi: *** ERROR: Invalid GPT ***
  493. *** ERROR: Can't read GPT header ***
  494. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  495. *** ERROR: Can't read GPT header ***
  496. part_get_info_efi: *** ERROR: Invalid GPT ***
  497. *** ERROR: Can't read GPT header ***
  498. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  499. *** ERROR: Can't read GPT header ***
  500. part_get_info_efi: *** ERROR: Invalid GPT ***
  501. *** ERROR: Can't read GPT header ***
  502. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  503. *** ERROR: Can't read GPT header ***
  504. part_get_info_efi: *** ERROR: Invalid GPT ***
  505. *** ERROR: Can't read GPT header ***
  506. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  507. *** ERROR: Can't read GPT header ***
  508. part_get_info_efi: *** ERROR: Invalid GPT ***
  509. *** ERROR: Can't read GPT header ***
  510. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  511. *** ERROR: Can't read GPT header ***
  512. part_get_info_efi: *** ERROR: Invalid GPT ***
  513. *** ERROR: Can't read GPT header ***
  514. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  515. *** ERROR: Can't read GPT header ***
  516. part_get_info_efi: *** ERROR: Invalid GPT ***
  517. *** ERROR: Can't read GPT header ***
  518. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  519. *** ERROR: Can't read GPT header ***
  520. part_get_info_efi: *** ERROR: Invalid GPT ***
  521. *** ERROR: Can't read GPT header ***
  522. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  523. *** ERROR: Can't read GPT header ***
  524. part_get_info_efi: *** ERROR: Invalid GPT ***
  525. *** ERROR: Can't read GPT header ***
  526. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  527. *** ERROR: Can't read GPT header ***
  528. part_get_info_efi: *** ERROR: Invalid GPT ***
  529. *** ERROR: Can't read GPT header ***
  530. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  531. *** ERROR: Can't read GPT header ***
  532. part_get_info_efi: *** ERROR: Invalid GPT ***
  533. *** ERROR: Can't read GPT header ***
  534. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  535. *** ERROR: Can't read GPT header ***
  536. part_get_info_efi: *** ERROR: Invalid GPT ***
  537. *** ERROR: Can't read GPT header ***
  538. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  539. *** ERROR: Can't read GPT header ***
  540. part_get_info_efi: *** ERROR: Invalid GPT ***
  541. *** ERROR: Can't read GPT header ***
  542. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  543. *** ERROR: Can't read GPT header ***
  544. part_get_info_efi: *** ERROR: Invalid GPT ***
  545. *** ERROR: Can't read GPT header ***
  546. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  547. *** ERROR: Can't read GPT header ***
  548. part_get_info_efi: *** ERROR: Invalid GPT ***
  549. *** ERROR: Can't read GPT header ***
  550. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  551. *** ERROR: Can't read GPT header ***
  552. part_get_info_efi: *** ERROR: Invalid GPT ***
  553. *** ERROR: Can't read GPT header ***
  554. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  555. *** ERROR: Can't read GPT header ***
  556. part_get_info_efi: *** ERROR: Invalid GPT ***
  557. *** ERROR: Can't read GPT header ***
  558. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  559. *** ERROR: Can't read GPT header ***
  560. part_get_info_efi: *** ERROR: Invalid GPT ***
  561. *** ERROR: Can't read GPT header ***
  562. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  563. *** ERROR: Can't read GPT header ***
  564. part_get_info_efi: *** ERROR: Invalid GPT ***
  565. *** ERROR: Can't read GPT header ***
  566. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  567. *** ERROR: Can't read GPT header ***
  568. part_get_info_efi: *** ERROR: Invalid GPT ***
  569. *** ERROR: Can't read GPT header ***
  570. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  571. *** ERROR: Can't read GPT header ***
  572. part_get_info_efi: *** ERROR: Invalid GPT ***
  573. *** ERROR: Can't read GPT header ***
  574. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  575. *** ERROR: Can't read GPT header ***
  576. part_get_info_efi: *** ERROR: Invalid GPT ***
  577. *** ERROR: Can't read GPT header ***
  578. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  579. *** ERROR: Can't read GPT header ***
  580. part_get_info_efi: *** ERROR: Invalid GPT ***
  581. *** ERROR: Can't read GPT header ***
  582. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  583. *** ERROR: Can't read GPT header ***
  584. part_get_info_efi: *** ERROR: Invalid GPT ***
  585. *** ERROR: Can't read GPT header ***
  586. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  587. *** ERROR: Can't read GPT header ***
  588. part_get_info_efi: *** ERROR: Invalid GPT ***
  589. *** ERROR: Can't read GPT header ***
  590. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  591. *** ERROR: Can't read GPT header ***
  592. part_get_info_efi: *** ERROR: Invalid GPT ***
  593. *** ERROR: Can't read GPT header ***
  594. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  595. *** ERROR: Can't read GPT header ***
  596. part_get_info_efi: *** ERROR: Invalid GPT ***
  597. *** ERROR: Can't read GPT header ***
  598. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  599. *** ERROR: Can't read GPT header ***
  600. part_get_info_efi: *** ERROR: Invalid GPT ***
  601. *** ERROR: Can't read GPT header ***
  602. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  603. *** ERROR: Can't read GPT header ***
  604. part_get_info_efi: *** ERROR: Invalid GPT ***
  605. *** ERROR: Can't read GPT header ***
  606. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  607. *** ERROR: Can't read GPT header ***
  608. part_get_info_efi: *** ERROR: Invalid GPT ***
  609. *** ERROR: Can't read GPT header ***
  610. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  611. *** ERROR: Can't read GPT header ***
  612. part_get_info_efi: *** ERROR: Invalid GPT ***
  613. *** ERROR: Can't read GPT header ***
  614. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  615. *** ERROR: Can't read GPT header ***
  616. part_get_info_efi: *** ERROR: Invalid GPT ***
  617. *** ERROR: Can't read GPT header ***
  618. part_get_info_efi: *** ERROR: Invalid Backup GPT ***
  619. ** Invalid partition 4 **
  620. starting USB...
  621. USB0:   ERROR: failed to enable clock 0
  622. at drivers/usb/host/ehci-generic.c:54/ehci_usb_probe()
  623. probe failed, error -38
  624. USB1:   ERROR: failed to enable clock 0
  625. at drivers/usb/host/ehci-generic.c:54/ehci_usb_probe()
  626. probe failed, error -38
  627. USB error: all controllers failed lowlevel init
  628. USB is stopped. Please issue 'usb start' first.
  629. starting USB...
  630. USB0:   ERROR: failed to enable clock 0
  631. at drivers/usb/host/ehci-generic.c:54/ehci_usb_probe()
  632. probe failed, error -38
  633. USB1:   ERROR: failed to enable clock 0
  634. at drivers/usb/host/ehci-generic.c:54/ehci_usb_probe()
  635. probe failed, error -38
  636. USB error: all controllers failed lowlevel init
  637. ethernet@fe300000 Waiting for PHY auto negotiation to complete... done
  638. Speed: 1000, full duplex
  639. BOOTP broadcast 1
  640. BOOTP broadcast 2
  641. BOOTP broadcast 3
  642. BOOTP broadcast 4
  643. BOOTP broadcast 5
  644. BOOTP broadcast 6
  645. BOOTP broadcast 7
  646. BOOTP broadcast 8
  647. BOOTP broadcast 9
  648. BOOTP broadcast 10
  649. BOOTP broadcast 11
  650. BOOTP broadcast 12
  651. BOOTP broadcast 13
  652. BOOTP broadcast 14
  653. BOOTP broadcast 15
  654. BOOTP broadcast 16
  655. BOOTP broadcast 17
  656. Retry time exceeded; starting again
  657. missing environment variable: pxeuuid
  658. missing environment variable: bootfile
  659. Retrieving file: pxelinux.cfg/01-92-10-db-6a-67-ee
  660. Speed: 1000, full duplex
  661. *** ERROR: `serverip' not set
  662. missing environment variable: bootfile
  663. Retrieving file: pxelinux.cfg/00000000
  664. Speed: 1000, full duplex
  665. *** ERROR: `serverip' not set
  666. missing environment variable: bootfile
  667. Retrieving file: pxelinux.cfg/0000000
  668. Speed: 1000, full duplex
  669. *** ERROR: `serverip' not set
  670. missing environment variable: bootfile
  671. Retrieving file: pxelinux.cfg/000000
  672. Speed: 1000, full duplex
  673. *** ERROR: `serverip' not set
  674. missing environment variable: bootfile
  675. Retrieving file: pxelinux.cfg/00000
  676. Speed: 1000, full duplex
  677. *** ERROR: `serverip' not set
  678. missing environment variable: bootfile
  679. Retrieving file: pxelinux.cfg/0000
  680. Speed: 1000, full duplex
  681. *** ERROR: `serverip' not set
  682. missing environment variable: bootfile
  683. Retrieving file: pxelinux.cfg/000
  684. Speed: 1000, full duplex
  685. *** ERROR: `serverip' not set
  686. missing environment variable: bootfile
  687. Retrieving file: pxelinux.cfg/00
  688. Speed: 1000, full duplex
  689. *** ERROR: `serverip' not set
  690. missing environment variable: bootfile
  691. Retrieving file: pxelinux.cfg/0
  692. Speed: 1000, full duplex
  693. *** ERROR: `serverip' not set
  694. missing environment variable: bootfile
  695. Retrieving file: pxelinux.cfg/default-arm-rockchip
  696. Speed: 1000, full duplex
  697. *** ERROR: `serverip' not set
  698. missing environment variable: bootfile
  699. Retrieving file: pxelinux.cfg/default-arm
  700. Speed: 1000, full duplex
  701. *** ERROR: `serverip' not set
  702. missing environment variable: bootfile
  703. Retrieving file: pxelinux.cfg/default
  704. Speed: 1000, full duplex
  705. *** ERROR: `serverip' not set
  706. Config file not found
  707. starting USB...
  708. USB0:   ERROR: failed to enable clock 0
  709. at drivers/usb/host/ehci-generic.c:54/ehci_usb_probe()
  710. probe failed, error -38
  711. USB1:   ERROR: failed to enable clock 0
  712. at drivers/usb/host/ehci-generic.c:54/ehci_usb_probe()
  713. probe failed, error -38
  714. USB error: all controllers failed lowlevel init
  715. Speed: 1000, full duplex
  716. BOOTP broadcast 1
  717. BOOTP broadcast 2
  718. BOOTP broadcast 3
  719. BOOTP broadcast 4
  720. BOOTP broadcast 5
  721. BOOTP broadcast 6
  722. BOOTP broadcast 7
  723. BOOTP broadcast 8
  724. BOOTP broadcast 9
  725. BOOTP broadcast 10
  726. BOOTP broadcast 11
  727. BOOTP broadcast 12
  728. BOOTP broadcast 13
  729. BOOTP broadcast 14
  730. BOOTP broadcast 15
  731. BOOTP broadcast 16
  732. BOOTP broadcast 17
  733. Retry time exceeded; starting again
  734. Speed: 1000, full duplex
  735. BOOTP broadcast 1
  736. BOOTP broadcast 2
  737. BOOTP broadcast 3
  738. BOOTP broadcast 4
  739. BOOTP broadcast 5
  740. BOOTP broadcast 6
  741. BOOTP broadcast 7
  742. BOOTP broadcast 8
  743. BOOTP broadcast 9
  744. BOOTP broadcast 10
  745. BOOTP broadcast 11
  746. BOOTP broadcast 12
  747. BOOTP broadcast 13
  748. BOOTP broadcast 14
  749. BOOTP broadcast 15
  750. BOOTP broadcast 16
  751. BOOTP broadcast 17
  752. Retry time exceeded; starting again
  753. => mmc part
  754. Partition Map for MMC device 1  --   Partition Type: EFI
  755. *** ERROR: Can't read GPT header ***
  756. part_print_efi: *** ERROR: Invalid GPT ***
  757. *** ERROR: Can't read GPT header ***
  758. part_print_efi: *** ERROR: Invalid Backup GPT ***
  759. =>
Copy the code
Any idea?
                      Thanks.
