[Linux] Boot Loop
26
Linux Boot Loop
Posted at 8/8/2019 04:41:10      View4770 | Replies4        Print      Only Author   [Copy Link] 1#
I just received the ROC-RK3399-PC, mounted the extension board and flashed the latest Ubuntu image (tried both already, with MEZZ and without) from https://drive.google.com/drive/f ... LY0DG_BLx94eAeArvwI and inserted the SD card into the device. Connected it via HDMI to my screen and plugged into a 2019 MBP 15" 85W USB-C Power Supply that does 20.2V@4.3A PD, 9V@3A PD or 5.2V@2.4A.
I see the Firefly logo on the screen for a second, then the device restarts. This happens over and over and over. Any idea what could be wrong?
Posted at 8/8/2019 04:51:34        Only Author  2#
Seem to have solved it myself. It was because of the power supply, apparently this device needs a very specific power input. It works using a Satechi 75W dual USB-C travel charger, on the upper most USB-C port that says PD.
Posted at 1/12/2026 18:48:35        Only Author  3#
Your article is absolutely brilliant, thank you for sharing! Sharing the free New CCDM exam topics test questionsyour key to career advancement and higher earnings!
Posted at 1/15/2026 07:34:24        Only Author  4#
Your article is really impressive, thank you for sharing! Free Latest C_THR85_2505 exam braindumps exam papers to help you prepare. Best of luck to all!
Posted at 2/1/2026 15:00:34        Only Author  5#
Your article is absolutely mind-blowing, thank you for sharing! Thanks to the AZ-140 Real Exams, I moved up in my career and got a raise. Now, its free for you all. Wishing you promotions ahead!
