[General] RK3399 Maskrom cannot flash idbloader
11
General RK3399 Maskrom cannot flash idbloader
Posted at 6/25/2018 10:32:04      View7849 | Replies5        Print      Only Author   [Copy Link] 1#
Hi there,
I'm following the instructions http://www.t-firefly.com/doc/product/info/id/229.html get rk3399 into MaskROM mode for replacing idbloader image, the updated steps looks fine till it shows "prepare idb fail" the red characters in chinese.
Actually, I've checked two loader files, both has same prepare ide fail problem.
rk3399_loader_v1.08.109.bin (builf from firefly-rk3399 AOSP source)
rk3399_loader_v1.10.112.bin (rk3399 linux github source)
Alos, rkdevelop tools seems replace ideloader without any error messages output but reset device nothing came from debug port. So I think flash ideloaer image was not working.
Thanks in advance
Posted at 6/27/2018 10:49:21        Only Author  2#
Try to pack it up with other image for a whole update.img .
Try to switch PC usb port and reset the board again.
Posted at 7/3/2018 17:51:38        Only Author  3#
Hi,
Use whole image update has same IDB failure problem, change usb port reset the board are not help.
Did you have loader and uboot images for emmc on firefly rk3399 that can share with me?
Thanks,
Posted at 1/9/2026 14:54:41        Only Author  4#
Your article is absolutely awe-inspiring, thank you for sharing! Get ahead in your career with the free 156-315.81 test cost test questionsyour key to promotion!
Posted at 1/14/2026 06:55:43        Only Author  5#
Thank you for sharing this inspiring piece of writing! C-BCBTM-2509 valid practice questions ppt provides a lot of useful material, offered at no charge to help you.
restricted members
Posted at 2/3/2026 07:12:33        Only Author  6#
I am so grateful for the insights in this article, thank you! Free FCP_FAZ_AD-7.4 reliable exam objectives pdf to improve your IT knowledge. Wishing you all the best!
