[Hardware] Charging the ROC - RK3399 - MEZZ - M2 - POE
94
Hardware Charging the ROC - RK3399 - MEZZ - M2 - POE
Posted at 3/8/2019 21:27:49      View8559 | Replies5        Print      Only Author   [Copy Link] 1#
I dug out my old RC iMax b6 lipo charger to try and charge the battery.
It can balance charge a 2 cell lipo.
On the charger there is a 3 pin balance charging socket which measures and controls the charging.
On the   ROC - RK3399 - MEZZ - M2 - POE  there is a 3 pin port marked BAT2+ BAT1+ BAT1-.
Do I connect my chargers balance charging socket to the 3 pin port on the POE board?
This is the only document I can find on the battery:
3) Onboard battery (dual 7.4V lithium battery)
4) Onboard balanced charging circuit to charge the onboard battery
Thank You
vip
Rank: 6Rank: 6
Posted at 3/12/2019 09:20:41        Only Author  2#
Do you want to charge the battery or want to power the board?
vip
Rank: 6Rank: 6
Posted at 3/12/2019 09:45:02        Only Author  3#
The 3 pins socket (bat2+,bat1+,bat-) only be connected to the battery,not the charger
Posted at 3/24/2019 18:27:12        Only Author  4#
So as long as it is 7.4v battery it will work? Will C discharge 25c be OK?How long will 2200mah last?
vip
Rank: 6Rank: 6
Posted at 3/25/2019 16:36:18        Only Author  5#
Plz use the recommended battery for better stability.  The duration depends on the workload.
Posted at 2/11/2026 01:57:17        Only Author  6#
I appreciate your share, the article is simply brilliant! The NCP-MCA new test collection file exam questions are now available for free. Good luck to everyone!
