最新版的Fire-Inspector-II測試,由International Code Council權威專家撰寫
Posted at 2/1/2026 14:26:24
此外,這些PDFExamDumps Fire-Inspector-II考試題庫的部分內容現在是免費的:https://drive.google.com/open?id=1b18TuVi2TYKozHj_cz3fptNdtWL_zDZ4
當你嘗試了我們提供的關於International Code Council Fire-Inspector-II認證考試的部分考題及答案,你可以對我們PDFExamDumps做出選擇了,我們會100%為你提供方便以及保障。請記住能讓你100%通過International Code Council Fire-Inspector-II認證考試的就是我們的PDFExamDumps。
PDFExamDumps 對所有購買 International Code Council Fire-Inspector-II 題庫的客戶提供跟踪服務,確保 Fire-Inspector-II 考題的覆蓋率始終都在95%以上,並且提供2種 Fire-Inspector-II 考題大師版本供你選擇。在您購買考題後的一年內,享受免費升級考題服務,如果在這期間,認證考試中心對 Fire-Inspector-II 考題做出修改或變題,我們會發送考試變化的信息,並免費提供給您最新的 International Code Council Fire-Inspector-II 試題版本。
最新Fire-Inspector-II題庫資訊,Fire-Inspector-II認證指南PDFExamDumps提供給你最權威全面的Fire-Inspector-II考試考古題,命中率極高,考試中會出現的問題可能都包含在這些考古題裏了,我們也會隨著大綱的變化隨時更新考古題。它可以避免你為考試浪費過多的時間和精力,助你輕鬆高效的通過考試。即便您沒有通過考試,我們也將承諾全額退款!所以你將沒有任何損失。機會是留給有準備的人的,希望你不要錯失良機。
最新的 Fire Inspector Fire-Inspector-II 免費考試真題 (Q74-Q79):問題 #74
Fire inspectors receiving citizen complaints about a building should first:
- A. record all pertinent information.
- B. forward the complaint to the senior inspector.
- C. investigate the history of the building.
- D. inform the owner of the building that a complaint has been filed against him.
答案:A
解題說明:
Reference to Fire Inspection Procedures for Handling Complaints:
According to the International Fire Code (IFC 2021), Section 104.11, fire inspectors are responsible for investigating complaints regarding fire hazards or code violations.
The first step in responding to a citizen complaint is to record all pertinent information about the issue.
2. Steps in Handling a Fire Safety Complaint:
Step 1: Record detailed information about the complaint, including:
Complainant's name and contact information (if available).
Address and description of the building.
Nature of the alleged fire hazard or code violation.
Step 2: Verify the history of past violations (if necessary).
Step 3: Conduct an inspection to determine if a violation exists.
Step 4: Take appropriate enforcement action, if needed.
3. Clarification of Incorrect Answer Choices:
B: Investigate the history of the building # Incorrect
While past violations can provide context, the first step is to record the details of the current complaint before investigating further.
C: Forward the complaint to the senior inspector # Incorrect
Inspectors do not need to escalate every complaint immediately; instead, they should gather relevant information first.
D: Inform the owner of the building that a complaint has been filed against him # Incorrect Not all complaints result in violations, and notifying the owner prematurely may lead to unnecessary disputes or conflicts.
The inspector should first verify the validity of the complaint before notifying the owner.
4. Conclusion:
The correct and verified answer is A (record all pertinent information) as per IFC 104.11 and fire inspection best practices.
問題 #75
The interior finish of walls and a ceiling in an atrium may not be less than __ Class
- A. Class D - Not recognized as an acceptable interior finish classification for atriums.
- B. Class C - Provides even lower fire protection, making it unsuitable.
- C. Class B - Less fire-resistant than Class A, not permitted for atriums.
- D. Class A - Interior Finish Ratings (Per ASTM E84 and NFPA 286).
答案:D
解題說明:
The interior finish requirements for walls and ceilings in an atrium are regulated under the 2021 International Building Code (IBC), Section 404 - Atriums, and Table 803.11 - Interior Wall and Ceiling Finish Requirements.
IBC Section 404.8 - Interior Finish in Atriums:
"The interior finish of walls and ceilings in an atrium shall be not less than Class A." Class A interior finishes have the highest level of fire resistance and low flame spread to minimize fire hazards in large open spaces like atriums.
問題 #76
The maximum quantity of liquefied petroleum gas (LP-gas) in containers stored by a dealer awaiting resale, and are at one location in a building that is not accessible to the public, is __ lb. water capacity.
- A. 1,000
- B. 2,500
- C. 0
- D. 2,000
答案:D
解題說明:
The storage of liquefied petroleum gas (LP-gas) in containers by dealers awaiting resale is regulated by the
2021 International Fire Code (IFC), Section 6109 - Storage of Portable LP-Gas Containers.
IFC 6109.11 - Storage Within Buildings Not Accessible to the Public:
"Storage of LP-gas containers in buildings that are not accessible to the public shall be limited to a maximum aggregate quantity of 2,000 pounds water capacity at one location." Why Other Options Are Incorrect?
A). 735 lb. - Too low; the maximum allowed is 2,000 lb.
B). 1,000 lb. - Incorrect; IFC allows up to 2,000 lb.
D). 2,500 lb. - Exceeds the 2,000 lb. maximum permitted storage quantity.
# Correct answer: C. 2,000 lb.
問題 #77
According to the fire code, when compliance is not immediate, inspection reports of code violations must always include a description of the violation and which of the following?
- A. Recommended corrective action
- B. The mandatory court date
- C. The potential fines for noncompliance
- D. The reinspection date
答案:A
解題說明:
When fire inspectors identify code violations, the inspection report must include a description of the violation along with a recommended corrective action. This ensures that the responsible party understands what steps need to be taken to bring the property into compliance.
Reference to Fire Inspector Documentation:
1. 2021 International Fire Code (IFC) - Section 109.3 (Notice of Violation) IFC 109.3 requires that any notice of violation must include a description of the violation and the necessary corrective action.
The intent is to provide clear guidance on how to remedy the issue to meet fire safety standards.
2. NFPA 1 - Fire Code (2021 Edition) - Section 1.7.6 (Enforcement and Documentation of Violations) NFPA 1, Section 1.7.6.1 states that violation reports must specify the corrective action required to comply with the fire code.
Detailed Explanation of Answer Choices:
Option A (Incorrect): While a reinspection date may be provided, it is not a mandatory component of an inspection report for code violations.
Option B (Incorrect): A mandatory court date is not always required; enforcement varies depending on jurisdiction and severity of the violation.
Option C (Correct): Recommended corrective action is required in all violation reports as per IFC 109.3 and NFPA 1.7.6.1.
Option D (Incorrect): Potential fines for noncompliance are determined separately and are not necessarily included in the initial violation report.
Thus, the correct and verified answer is: C. Recommended corrective action.
問題 #78
Quantities of flammable liquid storage in a control area of an S Occupancy may be doubled when:
- A. the control area exceeds 50,000 sq. ft.
- B. the control area is provided with exhaust ventilation in accordance with fire code requirements.
- C. permission is granted by the chief.
- D. the building is protected with automatic sprinklers.
答案:D
解題說明:
The storage of flammable liquids in control areas within an S Occupancy (Storage Occupancy) is governed by the 2021 International Fire Code (IFC), Section 5003 - Hazardous Materials, and Table 5003.1.1(1).
IFC Section 5003.1.1(1) - Maximum Allowable Quantity (MAQ) Adjustments:
The maximum allowable quantity (MAQ) of flammable liquids in a control area may be doubled if an approved automatic sprinkler system is installed throughout the building.
A: Permission is granted by the chief.
Fire officials can enforce code requirements but do not have the authority to override MAQ limits unless explicitly allowed in the code.
B: The control area exceeds 50,000 sq. ft.
The code does not specify an increase based solely on size; the sprinkler system is the determining factor.
D: The control area is provided with exhaust ventilation in accordance with fire code requirements.
While ventilation is important for hazardous material safety, it does not allow for an increase in the maximum storage quantity.
問題 #79
作為一位 Fire-Inspector-II 考生而言,作好充分的準備可以幫助您通過考試。PDFExamDumps 的 Fire-Inspector-II 題庫覆蓋了最新的 Fire-Inspector-II 考試指南及考試真題題型。Fire-Inspector-II 隸屬于 International Code Council 認證考試科目。我們的 Fire-Inspector-II 認證考題已經幫助很多考生通過考試,試題質量和考題的覆蓋率都有保證,保證考生權利不受任何損失。獲取 Fire-Inspector-II 考試認證證書可以用來實施一些複雜多變的工程。
最新Fire-Inspector-II題庫資訊: https://www.pdfexamdumps.com/Fire-Inspector-II_valid-braindumps.html
作為被 IT行業廣泛認可的考試,Fire-Inspector-II認證考試是International Code Council中最重要的考試之一,第一,PDFExamDumps 最新Fire-Inspector-II題庫資訊的考古題是IT專家們運用他們多年的經驗研究出來的資料,可以準確地劃出考試出題的範圍,International Code Council Fire-Inspector-II測試 線上測試引擎:支持Windows / Mac / Android / iOS, 等系統,也就是適用於任何電子產品,Fire-Inspector-II 考題資料和實際的認證考試一樣,不僅包含了實際考試中的所有問題,而且 Fire-Inspector-II 考古題的軟體版完全類比了真實考試的氛圍,Fire-Inspector-II認證是加快您作為IT行業專業人士的職業發展的最佳選擇,所有的IT人士都熟悉的International Code Council的Fire-Inspector-II考試認證,並且都夢想有那頂最苛刻的認證,這是由被普遍接受的International Code Council的Fire-Inspector-II考試認證的最高級別認證,你可以得到你的職業生涯。
我們將繼續為客戶學習我想要的產品,為我們的產品增加價值並難以復制,也就選花魁等壹些大事需要更多人手時,需要軍隊入城,作為被 IT行業廣泛認可的考試,Fire-Inspector-II認證考試是International Code Council中最重要的考試之一,第一,PDFExamDumps的考古題是IT專家們運用他們多年的經驗研究出來的資料,可以準確地劃出考試出題的範圍。
最實用的Fire-Inspector-II認證考試的題目與答案線上測試引擎:支持Windows / Mac / Android / iOS, 等系統,也就是適用於任何電子產品,Fire-Inspector-II 考題資料和實際的認證考試一樣,不僅包含了實際考試中的所有問題,而且 Fire-Inspector-II 考古題的軟體版完全類比了真實考試的氛圍。
Fire-Inspector-II認證是加快您作為IT行業專業人士的職業發展的最佳選擇。
- 新版Fire-Inspector-II考古題 🍍 Fire-Inspector-II考試大綱 👰 Fire-Inspector-II認證 🥬 透過【 [url]www.newdumpspdf.com 】輕鬆獲取➤ Fire-Inspector-II ⮘免費下載Fire-Inspector-II考古题推薦[/url]
- Fire-Inspector-II考試大綱 😃 新版Fire-Inspector-II考古題 🥊 Fire-Inspector-II考試大綱 👱 ⇛ [url]www.newdumpspdf.com ⇚提供免費“ Fire-Inspector-II ”問題收集Fire-Inspector-II資訊[/url]
- Fire-Inspector-II真題材料 🥫 Fire-Inspector-II證照 🔣 Fire-Inspector-II題庫資訊 💷 在[ [url]www.newdumpspdf.com ]網站下載免費{ Fire-Inspector-II }題庫收集Fire-Inspector-II題庫更新[/url]
- Fire-Inspector-II考試備考經驗 🛢 Fire-Inspector-II最新考題 🏖 Fire-Inspector-II最新考題 🕰 到《 [url]www.newdumpspdf.com 》搜索➤ Fire-Inspector-II ⮘輕鬆取得免費下載Fire-Inspector-II考試[/url]
- Fire-Inspector-II PDF考古題 🐢 透過“ [url]www.pdfexamdumps.com ”輕鬆獲取▛ Fire-Inspector-II ▟免費下載Fire-Inspector-II熱門考古題[/url]
- Fire-Inspector-II最新題庫 🐀 Fire-Inspector-II最新題庫 🔭 Fire-Inspector-II考試備考經驗 🍥 《 [url]www.newdumpspdf.com 》最新「 Fire-Inspector-II 」問題集合Fire-Inspector-II題庫下載[/url]
- Fire-Inspector-II認證考試資料庫 🧎 到“ [url]www.newdumpspdf.com ”搜尋[ Fire-Inspector-II ]以獲取免費下載考試資料Fire-Inspector-II最新考題[/url]
- Fire-Inspector-II資訊 🔇 Fire-Inspector-II證照考試 🏛 Fire-Inspector-II證照考試 🌕 到( [url]www.newdumpspdf.com )搜索☀ Fire-Inspector-II ️☀️輕鬆取得免費下載Fire-Inspector-II學習資料[/url]
- Fire-Inspector-II認證考試資料庫 🔉 在➤ tw.fast2test.com ⮘網站下載免費▶ Fire-Inspector-II ◀題庫收集Fire-Inspector-II認證
- Fire-Inspector-II測試&資格考試的領導者和International Code Council 67 - Fire Inspector II Exam 😸 打開網站➤ [url]www.newdumpspdf.com ⮘搜索▷ Fire-Inspector-II ◁免費下載Fire-Inspector-II真題材料[/url]
- Fire-Inspector-II測試 |在[url]www.pdfexamdumps.com | 100%通過快速下載 ☘ ▛ www.pdfexamdumps.com ▟是獲取➥ Fire-Inspector-II 🡄免費下載的最佳網站Fire-Inspector-II題庫資訊[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
順便提一下,可以從雲存儲中下載PDFExamDumps Fire-Inspector-II考試題庫的完整版:https://drive.google.com/open?id=1b18TuVi2TYKozHj_cz3fptNdtWL_zDZ4
