[General] Most Probable Real Exam Questions in Fortinet FCP_FMG_AD-7.6 PDF Dumps Format
78
General Most Probable Real Exam Questions in Fortinet FCP_FMG_AD-7.6 PDF Dumps Format
Posted at 1/25/2026 12:45:46      View122 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Itexamguide FCP_FMG_AD-7.6 dumps for free: https://drive.google.com/open?id=1GK99JccMDQI-ol03EX9dPVYYGlDUSWB6
Our FCP_FMG_AD-7.6 learning questions have its own advantage. In order to make sure you have answered all questions, we have answer list to help you check. Then you can choose the end button to finish your exercises of the FCP_FMG_AD-7.6 study guide. The calculation system of our FCP_FMG_AD-7.6 Real Exam will start to work and finish grading your practices. Quickly, the scores will display on the screen. The results are accurate. You need to concentrate on memorizing the wrong questions.
If you want to get a higher salary or a promotion on your position, you need to work harder! Purchase our FCP_FMG_AD-7.6 learning materials and stick with it. Then your strength will protect you. For as long as you study with our FCP_FMG_AD-7.6 exam questions, then you will find that the content of our FCP_FMG_AD-7.6 praparation braindumps is all the hot hit of the newest knowledage and keypoints of the subject, you will learn so much to master the skills which will help you solve your problems in your work. And besides, you can achieve the certification for sure with our FCP_FMG_AD-7.6 study guide.
Valid Braindumps FCP_FMG_AD-7.6 Free | Fresh FCP_FMG_AD-7.6 DumpsTo get FCP_FMG_AD-7.6 exam certification, you will strive for a further improvement. When you choose Itexamguide, it will help you pass FCP_FMG_AD-7.6 certification exam. If you buy Itexamguide's FCP_FMG_AD-7.6 Exam Dumps, we guarantee you will pass FCP_FMG_AD-7.6 test with 100%. After you select our FCP_FMG_AD-7.6 exam training materials, we will also provide one year free renewal service.
Fortinet FCP_FMG_AD-7.6 Exam Syllabus Topics:
  • Device Manager: This section of the exam measures the skills of Network Security Engineers and focuses on registering devices within ADOMs and handling device configurations. Candidates also learn how to install changes through scripts and diagnose issues using the revision history.
  • This section of the exam measures the skills of System Administrators and focuses on resolving problems at different levels of FortiManager. Candidates must troubleshoot deployment scenarios, imports, installations, and both device-level and ADOM-level issues, as well as identify and resolve system problems effectively.
  • Policy and Objects: This section of the exam measures the skills of System Administrators and evaluates their ability to manage policies and objects within FortiManager. It involves ADOM revisions, workspace mode, and policy imports and installations, emphasizing consistent policy control across networks.
Topic 5
  • Advanced Configuration: This section of the exam measures the skills of Network Security Engineers and includes knowledge of high availability (HA), FortiGuard service configuration, and global database ADOM settings. These advanced functions help strengthen system reliability and streamline management at a larger scale.
Topic 6
  • Administration: This section of the exam measures the skills of System Administrators and covers the essential features of FortiManager. It includes the initial configuration process and the setup of administrative domains (ADOMs), ensuring smooth system management.
Topic 7
  • Troubleshooting
Fortinet FCP - FortiManager 7.6 Administrator Sample Questions (Q54-Q59):NEW QUESTION # 54
What must you consider before deciding to use FortiManager to manage a FortiAnalyzer device?
  • A. Check whether FortiManager is part of a high availability (HA) cluster.
  • B. Ensure that FortiAnalyzer features are installed in advance.
  • C. Confirm that FortiManager has enough storage capacity for the expected logs.
  • D. Determine whether the VDOMs of the same FortiGate will be assigned to different ADOMs.
When FMG is managing a FAZ, you cannot switch to advanced mode. And it s only in advanced mode Vdoms of the same Fortigate can be assigned to differents ADOM.
NEW QUESTION # 55
An administrator added a FortiGate device to FortiManager with the default object settings at the ADOM layer.
What can you conclude from the import policy package process of the HQ-NGFW- 1 device?
  • A. The administrator must select Per Platform for all interfaces to correctly detect all interfaces from HQ- NGFW-1.
  • B. The administrator must manually create the port4 interface on the ADOM layer to avoid import policy errors.
  • C. FortiGate may not work as expected when the administrator does not import all objects.
  • D. FortiManager will create LAN, port4, and port6 as normalized interfaces at the ADOM layer.
The import process shows that FortiManager will create normalized interfaces named LAN, port4, and port6 at the ADOM layer, mapping them to the corresponding device interfaces based on the import settings.
NEW QUESTION # 56
Refer to the exhibit. Which two statements about the output are true? (Choose two.)
  • A. The system template default will override device-level database configurations.
  • B. The latest revision history for the managed FortiGate does not match the device-level database.
  • C. Configuration changes have been installed on FortiGate, updating policy and device-level database.
  • D. The latest revision history for the managed FortiGate does match the FortiManager policy database.
- conf: in sync - This is the sync status which shows that the latest revision history is in sync with Fortigate's configuration.
There is a new modification on FortiManager device level DB (dev-db: modified) which wasn't installed to FortiGate (cond: pending).
NEW QUESTION # 57
If the monitored interface for the primary FortiManager device fails, what must you do to maintain high availability (HA)?
  • A. Reconfigure the primary device to remove the peer IP address of the failed device from its configuration.
  • B. Manually promote one of the working secondary devices to the primary role: and reboot the original primary device to remove the peer IP address of the failed device.
  • C. The FortiManager HAfailover is transparent to administrators and does not require any additional action.
  • D. Check the integrity database of the primary device to force a secondary device to become the new primary with all active interfaces.
In a FortiManager HA cluster configured with VRRP failover, the failover process is automatic and transparent to administrators. If the monitored interface on the primary device fails, the secondary device takes over without requiring manual intervention to maintain HA.
NEW QUESTION # 58
An administrator must create a policy and install it on a FortiGate device within an ADOM in backup mode.
How can the administrator perform this task?
  • A. Enable workflow mode to allow policy creation and approval.
  • B. Use the Install Wizard located on the device manager.
  • C. Use a FortiManager script to apply the configuration changes.
  • D. Make sure the ADOM and FortiGate firmware versions match and use the ADOM policy package.
To make configuration changes from FortiManager to managed devices while in backup mode, you must use the script feature..
NEW QUESTION # 59
Mercenary men lust for wealth, our company offer high quality FCP_FMG_AD-7.6 practice engine rather than focusing on mercenary motives. They are high quality and high effective FCP_FMG_AD-7.6 training materials and our efficiency is expressed clearly in many aspects for your reference. The first one is downloading efficiency. The second is expressed in content, which are the proficiency and efficiency of FCP_FMG_AD-7.6 Study Guide. You will love our FCP_FMG_AD-7.6 exam questions as long as you have a try!
Valid Braindumps FCP_FMG_AD-7.6 Free: https://www.itexamguide.com/FCP_FMG_AD-7.6_braindumps.html
P.S. Free 2026 Fortinet FCP_FMG_AD-7.6 dumps are available on Google Drive shared by Itexamguide: https://drive.google.com/open?id=1GK99JccMDQI-ol03EX9dPVYYGlDUSWB6
