Desktop Based Pure Storage FAAA_005 Practice Test Software
Posted at 1/12/2026 14:47:28
What's more, part of that Getcertkey FAAA_005 dumps now are free: https://drive.google.com/open?id=1-GzukK7C8yJGJDKf_UZZGiBI2LIe32nZ
Our FAAA_005 exam materials allows you to have a 98% to 100% pass rate; allows you takes only 20 to 30 hours to practice before you take the exam; provide you with 24 free online customer service; provide professional personnel remote assistance; give you full refund if you fail to pass the FAAA_005 Exam. Our FAAA_005 real test serve you with the greatest sincerity. Face to such an excellent product which has so much advantages, do you fall in love with our FAAA_005 study materials now? If your answer is yes, then come and buy our FAAA_005 exam questions now.
Getcertkey is obliged to give you three months of free update checks to ensure the validity and accuracy of the Pure Storage FlashArray Architect Associate (FAAA_005) exam dumps. We also offer you a 100% money-back guarantee, in the very rare case of failure or unsatisfactory results. This puts your mind at ease when you are Pure Storage FlashArray Architect Associate (FAAA_005) exam preparing with us.
Pass Guaranteed Quiz 2026 FAAA_005: Pure Storage FlashArray Architect Associate Useful Latest Test MaterialsPure Storage certification FAAA_005 exam has become a very popular test in the IT industry, but in order to pass the exam you need to spend a lot of time and effort to master relevant IT professional knowledge. In such a time is so precious society, time is money. Getcertkey provide a training scheme for Pure Storage Certification FAAA_005 Exam, which only needs 20 hours to complete and can help you well consolidate the related IT professional knowledge to let you have a good preparation for your first time to participate in Pure Storage certification FAAA_005 exam.
Pure Storage FlashArray Architect Associate Sample Questions (Q22-Q27):NEW QUESTION # 22
A customer is experiencing latency in the VMware environment connected to this array.
What should the SE recommend?
- A. Add network cards to alleviate network congestion
- B. Upgrade the controllers
- C. Add DirectFlash Modules as the system is disk bound
- D. Check the ESXi host
The exhibit shows latency in the VMware environment connected to the FlashArray. When troubleshooting latency issues in a VMware environment, the first step is to identify whether the issue originates from the storage array, the network, or the ESXi host. In this case, the SE should recommend checking the ESXi host, as it is often the source of latency problems in VMware environments.
Why This Matters:
ESXi Host Issues:
The ESXi host could be experiencing resource contention (e.g., CPU, memory, or network bottlenecks) or misconfigurations (e.g., improper queue depth settings or multipathing policies).
High latency on the ESXi host can impact the performance of virtual machines and appear as storage latency, even if the FlashArray itself is functioning optimally.
Why Not the Other Options?
A). Add DirectFlash Modules as the system is disk bound:
Pure Storage FlashArray uses DirectFlash Modules, which are NVMe-based and provide extremely low latency. If the array were disk-bound, it would indicate a hardware limitation, but this is unlikely with FlashArray's architecture. The issue is more likely related to the ESXi host or network.
B). Upgrade the controllers:
Controller upgrades are typically unnecessary unless the array is nearing its performance limits. Since the exhibit does not indicate any signs of controller saturation, this is not the correct recommendation.
C). Add network cards to alleviate network congestion:
While network congestion can cause latency, the issue is more likely related to the ESXi host configuration. Adding network cards should only be considered after confirming network bottlenecks through diagnostics.
Key Points:
ESXi Host Diagnostics: Start by checking the ESXi host for resource contention, misconfigurations, or improper settings.
Storage Array Health: Verify that the FlashArray is not experiencing any performance issues (e.g., high queue depths or latency).
Network Analysis: Only after ruling out the ESXi host and storage array should network-related issues be investigated.
Reference: Pure Storage FlashArray Documentation: "Troubleshooting Latency in VMware Environments" VMware Best Practices Guide: "Optimizing ESXi Host Performance" Pure Storage Knowledge Base: "Diagnosing and Resolving Latency Issues"
NEW QUESTION # 23
How does Pure Storage help customers increase storage density in their arrays, as new technology becomes available, without rebuying existing storage?
- A. Customers can attach third-party storage arrays to the Pure Storage array.
- B. Customers can mix HDDs and flash modules within the same array.
- C. Customers can add a shelf with a Evergreen//One subscription.
- D. Customers can leverage Pure Storage's Capacity Consolidation offering.
Pure Storage helps customers increase storage density in their arrays as new technology becomes available through its Evergreen//One subscription program. Here's an analysis of the options:
Analysis of Options:
A). Customers can attach third-party storage arrays to the Pure Storage array:
Pure Storage does not support attaching third-party storage arrays directly to its arrays. This is not a valid option.
B). Customers can leverage Pure Storage's Capacity Consolidation offering:
While capacity consolidation is a benefit of Pure Storage arrays, it does not specifically address increasing storage density with new technology.
C). Customers can mix HDDs and flash modules within the same array:
Pure Storage arrays are all-flash and do not support mixing HDDs and flash modules. This is not a valid option.
D). Customers can add a shelf with an Evergreen//One subscription:
With Evergreen//One, customers can non-disruptively add new shelves or upgrade their arrays to take advantage of newer, denser storage technologies without rebuying existing storage. This is the correct answer.
Recommendation:
The correct answer is
D). Customers can add a shelf with an Evergreen//One subscription.
Reference: Evergreen//One Program Overview:
Evergreen//One
Explains the benefits of Evergreen//One, including non-disruptive upgrades and capacity expansion.
FlashArray Expansion Shelves:
Details the process of adding shelves to increase storage capacity.
NEW QUESTION # 24
A customer has presented two workloads that need to be replicated. One is a highly transactional database workload and the other is a VM datastore with tier one applications.
The customer has the following requirements:
* The database workload is highly reliant on storage performance The VM datastore requires zero downtime.
* The customer has advised the two FlashArrays will be 20 miles apart and they are worried that this could impact their internal SLAs.
What replication strategies should be advised for these workloads?
- A. ActiveCluster should be used for the VM workloads and ActiveDR for the database workload.
- B. ActiveCluster should be used for both workloads.
- C. ActiveDR should be used for the VM workloads and ActiveCluster for the database workload.
- D. ActiveDR should be used for both workloads.
To address the customer's requirements, we need to evaluate the replication strategies offered by Pure Storage FlashArray: ActiveCluster and ActiveDR, and how they align with the specific needs of the two workloads.
Workload Analysis:
Transactional Database Workload:
This workload is highly reliant on storage performance. Any replication strategy must ensure minimal latency and high availability to avoid impacting transactional throughput and response times.
The database workload typically benefits from synchronous replication to maintain consistency and performance across sites.
VM Datastore (Tier 1 Applications):
This workload requires zero downtime, meaning it must remain accessible even in the event of a site failure. High availability and seamless failover are critical.
The VM datastore can tolerate some level of asynchronous replication as long as it does not compromise availability or recovery objectives.
Replication Strategies:
ActiveCluster:
ActiveCluster is a synchronous replication solution that provides active-active high availability across two FlashArrays. It ensures zero RPO (Recovery Point Objective) and zero RTO (Recovery Time Objective), making it ideal for workloads requiring continuous availability and zero downtime.
ActiveCluster is well-suited for the VM datastore workload because it guarantees seamless failover and high availability, meeting the zero-downtime requirement.
ActiveDR:
ActiveDR is an asynchronous replication solution designed for disaster recovery scenarios. It provides near-zero RPO (typically seconds to minutes) and allows for non-disruptive testing of failover scenarios.
ActiveDR is better suited for the transactional database workload because it minimizes the impact of latency over the 20-mile distance while still maintaining high performance and consistency.
Distance Consideration:
The 20-mile distance between the two FlashArrays introduces latency concerns. Synchronous replication (ActiveCluster) can handle this distance effectively for the VM datastore workload due to its tolerance for slightly higher latency. However, for the transactional database workload, the latency could degrade performance, making ActiveDR a better choice.
Final Recommendation:
Use ActiveCluster for the VM datastore workload to achieve zero downtime and high availability.
Use ActiveDR for the transactional database workload to balance performance and disaster recovery needs over the 20-mile distance.
Reference: Pure Storage ActiveCluster Documentation:
Explains the synchronous replication capabilities and use cases for ActiveCluster.
Pure Storage ActiveDR Documentation:
Details the asynchronous replication features and disaster recovery use cases for ActiveDR.
Pure Storage Best Practices for Replication:
Provides guidance on selecting the appropriate replication strategy based on workload requirements and distance considerations.
Pure Storage Replication Best Practices
Pure Storage Architectural Guides:
Covers architectural considerations for deploying ActiveCluster and ActiveDR in multi-site environments.
This approach ensures that both workloads meet their respective SLAs while addressing the customer's concerns about distance and performance.
NEW QUESTION # 25
Which FlashArray controller(s) does the exhibit show?
- A. Top: CTO, Bottom: CT1
- B. Top: Primary, Bottom: Secondary
- C. Top: CT1, Bottom: CT2
Exhibit controllers of a Pure Storage FlashArray, specifically labeled as CT1 (top) and CT2 (bottom).
This labeling is consistent with Pure Storage's naming convention for its controllers.
Why This Matters:
Controller Identification:
Pure Storage FlashArray controllers are typically labeled as CT1 and CT2 to distinguish between the two controllers in an active/active architecture.
Both controllers work together to provide high availability and redundancy, ensuring seamless operation even if one controller is offline for maintenance or upgrades.
Active/Active Architecture:
In an active/active design, both controllers share the workload equally. If one controller is taken offline, the other seamlessly handles all I/O operations without impacting performance or availability.
B). Top: Primary, Bottom: Secondary:
Pure Storage does not use "Primary" and "Secondary" labels for its controllers. Instead, it uses specific identifiers like CT1 and CT2 to refer to the controllers.
C). Top: CTO, Bottom: CT1:
The label "CTO" is not a valid designation for FlashArray controllers. Pure Storage consistently uses CT1 and CT2 to identify the controllers.
Key Points:
Controller Labels: Pure Storage FlashArray controllers are labeled as CT1 and CT2.
Active/Active Design: Both controllers operate simultaneously to ensure high availability and performance.
Redundancy: The dual-controller architecture provides fault tolerance and minimizes downtime during maintenance or failures.
Reference: Pure Storage FlashArray Documentation: "Understanding FlashArray Controller Architecture" Pure Storage Knowledge Base: "Identifying FlashArray Controllers" Pure Storage Whitepaper: "Active/Active Controller Design for High Availability"
NEW QUESTION # 26
A customer is assessing the health of their FlashArray.
What should the customer discuss with their SE based on this information?
- A. Adding a second shelf of NVMe DirectFlash modules
- B. Upgrading the controller to the //X90R3 model
- C. Adding more network ports
Based on the exhibit (referenced via the link), the customer should discuss adding a second shelf of NVMe DirectFlash modules with their SE. This recommendation is based on the assumption that the exhibit indicates the array is nearing its capacity limits or requires additional storage to accommodate future growth.
Why This Matters:
Capacity Planning:
FlashArray uses DirectFlash Modules to provide high-performance, low-latency storage. If the array is approaching its physical capacity, adding a second shelf of NVMe modules is the most effective way to expand storage without requiring a full hardware upgrade.
This approach ensures the array can continue to meet the customer's growing storage needs while maintaining performance and reliability.
Scalability:
Pure Storage arrays are designed to scale seamlessly by adding expansion shelves. This allows customers to increase capacity without disrupting operations or replacing existing hardware.
A). Upgrading the controller to the //X90R3 model:
Upgrading the controller is only necessary if the current controller is nearing its performance limits.
The exhibit does not indicate performance bottlenecks, so this step is likely unnecessary.
C). Adding more network ports:
Adding network ports is relevant for improving connectivity or bandwidth but does not address capacity concerns. If the array is running out of storage space, adding network ports will not resolve the issue.
Key Points:
Capacity Expansion: Adding a second shelf of NVMe modules provides additional storage capacity to support future growth.
Non-Disruptive Scaling: Expansion shelves can be added without downtime, ensuring continuous availability.
Cost Efficiency: Avoids unnecessary upgrades or replacements, optimizing costs while meeting capacity requirements.
Reference: Pure Storage FlashArray Documentation: "Expanding FlashArray Capacity with DirectFlash Modules" Pure Storage Whitepaper: "Scaling Storage with FlashArray Expansion Shelves" Pure Storage Knowledge Base: "Best Practices for Capacity Planning and Expansion"
NEW QUESTION # 27
Knowledge is a great impetus for the progress of human civilization. In the century today, we have to admit that unemployment is getting worse. Many jobs have been replaced by intelligent robots, so you have to learn practical knowledge, such as our Pure Storage FlashArray Architect Associate exam dumps, it can meet the needs of users. With the help of our FAAA_005 test material, users will learn the knowledge necessary to obtain the Pure Storage certificate and be competitive in the job market and gain a firm foothold in the workplace. Our FAAA_005 Quiz guide’ reputation for compiling has created a sound base for our beautiful future business. We are clearly concentrated on the international high-end market, thereby committing our resources to the specific product requirements of this key market sector, as long as cater to all the users who wants to get the test Pure Storage certification.
FAAA_005 Positive Feedback: https://www.getcertkey.com/FAAA_005_braindumps.html
To do this joust enroll in the Network Security Specialist FAAA_005 certification exam and start preparation with real and valid Pure Storage FlashArray Architect Associate (FAAA_005) exam practice test questions right now, Getcertkey has many Pure Storage FlashArray Architect Associate (FAAA_005) practice questions that reflect the pattern of the real Pure Storage FAAA_005 exam, Pure Storage Latest FAAA_005 Test Materials All these variants due to our customer-oriented tenets.
Even if you own multiple houses, you can only be in one FAAA_005 of them at a time, How can we use social networks to drive innovation, To do this joust enroll in the Network Security Specialist FAAA_005 certification exam and start preparation with real and valid Pure Storage FlashArray Architect Associate (FAAA_005) exam practice test questions right now.
Pass Guaranteed Quiz Pure Storage - High-quality Latest FAAA_005 Test MaterialsGetcertkey has many Pure Storage FlashArray Architect Associate (FAAA_005) practice questions that reflect the pattern of the real Pure Storage FAAA_005 exam, All these variants due to our customer-oriented tenets.
we will always put the interests of customers in the first place, so FAAA_005 test guide ensure that your information will not be leaked to any third party, After you have paid for the FlashBlade Architect Professional test training vce successfully, our online workers will quickly send you the FAAA_005 : Pure Storage FlashArray Architect Associate valid test simulator installation package.
- New FAAA_005 Dumps Ebook 🦳 FAAA_005 Exam Test 🎢 Book FAAA_005 Free 🏀 Search for [ FAAA_005 ] and easily obtain a free download on ⮆ [url]www.dumpsmaterials.com ⮄ 🏏FAAA_005 Reliable Test Tutorial[/url]
- Latest FAAA_005 Exam Discount 🤾 FAAA_005 Test Discount 🔂 Book FAAA_005 Free 🤮 Easily obtain free download of 【 FAAA_005 】 by searching on 【 [url]www.pdfvce.com 】 🧵FAAA_005 Latest Exam Registration[/url]
- FAAA_005 Reliable Test Tutorial 🆑 FAAA_005 Exam Test 📃 Interactive FAAA_005 EBook 🔯 Easily obtain ☀ FAAA_005 ️☀️ for free download through ⏩ [url]www.vceengine.com ⏪ 🔜Dumps FAAA_005 Discount[/url]
- Pass Guaranteed Quiz FAAA_005 - Pure Storage FlashArray Architect Associate –Efficient Latest Test Materials 🔷 Search for [ FAAA_005 ] and download it for free on ➠ [url]www.pdfvce.com 🠰 website 🧣Latest FAAA_005 Test Pdf[/url]
- 100% Pass Quiz 2026 Perfect Pure Storage Latest FAAA_005 Test Materials 🧤 The page for free download of [ FAAA_005 ] on ⏩ [url]www.troytecdumps.com ⏪ will open immediately 💅Test FAAA_005 Simulator[/url]
- Test FAAA_005 Objectives Pdf 😃 FAAA_005 PDF Cram Exam 📯 Valid Test FAAA_005 Braindumps ☝ Copy URL ⏩ [url]www.pdfvce.com ⏪ open and search for ▶ FAAA_005 ◀ to download for free 🐬Valid FAAA_005 Real Test[/url]
- FAAA_005 pdf braindumps, Pure Storage FAAA_005 real braindumps, FAAA_005 valid dumps ➰ Go to website ▷ [url]www.easy4engine.com ◁ open and search for 「 FAAA_005 」 to download for free 💡FAAA_005 Valid Exam Format[/url]
- Valid FAAA_005 Real Test 🌾 Latest FAAA_005 Test Pdf 🚪 Valid Braindumps FAAA_005 Pdf 🦩 Open ⇛ [url]www.pdfvce.com ⇚ and search for ➠ FAAA_005 🠰 to download exam materials for free 🎧FAAA_005 Learning Engine[/url]
- 100% Pass Quiz 2026 Perfect Pure Storage Latest FAAA_005 Test Materials 🧍 Download ➠ FAAA_005 🠰 for free by simply entering ⇛ [url]www.examcollectionpass.com ⇚ website 😼Dumps FAAA_005 Discount[/url]
- FAAA_005 pdf braindumps, Pure Storage FAAA_005 real braindumps, FAAA_005 valid dumps 💞 Open website ⮆ [url]www.pdfvce.com ⮄ and search for ⏩ FAAA_005 ⏪ for free download 🦢Valid FAAA_005 Real Test[/url]
- Latest FAAA_005 Test Pdf 🕍 Valid Braindumps FAAA_005 Pdf ⏰ FAAA_005 Test Discount 🐓 Download ▶ FAAA_005 ◀ for free by simply searching on ▷ [url]www.pass4test.com ◁ 🔓Valid Test FAAA_005 Braindumps[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, capacitacion.axiomamexico.com.mx, www.slideshare.net, bbs.t-firefly.com, www.888moli.com, www.stes.tyc.edu.tw, hashnode.com, Disposable vapes
