[Hardware] USB Type C Display Issue
47
【Hardware】 USB Type C Display Issue
Posted at 6/3/2019 11:39:40      View:5225 | Replies:9        Print      Only Author   [Copy Link] 1#
Hi,
We tested ROC-RK3399-PC USB type C display performance and had two problems:
1. Connect to DP 4K Monitor with USB Type C to DP Dongle
-->Monitor works only on certain side of USB Type C connector.
2. Connect to USB Type C Monitor (Dell U3219Q)
-->No Function. Nothing displays on the monitor.
Does anyone have the similar issue and know how to fix it?
Thanks in advance!
vip
Rank: 6Rank: 6
Posted at 6/5/2019 14:16:37        Only Author  2#
Could you elaborate a bit about "on certain side of USB Type C connector"?
Posted at 6/6/2019 11:44:25        Only Author  3#
Thanks for asking. As far as we know, USB-C plug may be inserted either side (the connector is reversible so that it can be used in any orientation). But in our test, when using USB-C to DP Dongle, the USB-C on the ROC-RK3399-PC only displayed (have function) in one side. If we turned to the other side and stick in the USB-C connector, the monitor showed nothing.
How about the second issue? (connecting to USB Type C Monitor) What's the potential cause?
Posted at 6/17/2019 15:00:57        Only Author  4#
Any update on this?
vip
Rank: 6Rank: 6
Posted at 6/18/2019 16:59:53        Only Author  5#
This has been confirmed. It's the driver problem.
  1. 2. Connect to USB Type C Monitor (Dell U3219Q)
  2. -->No Function. Nothing displays on the monitor.
Copy the code
We haven't this monitor, so would you please attach a kernel log with monitor plug out and in.
Posted at 1/13/2026 12:09:31        Only Author  6#
This article is incredible, thank you for sharing such brilliance! Free Test AZ-204 registration resources are available here—good luck!
Posted at 1/23/2026 00:56:07        Only Author  7#
PRINCE2Foundation-Deutsch ist eine der PRINCE2 Zertifizierungsprüfungen. IT-Fachmann mit PRINCE2 Zertifikat sind sehr beliebt in der IT-Branche. Deshalb legen imme mehr Leute die PRINCE2Foundation-Deutsch Zertifizierungsprüfung. Jedoch ist es nicht so einfach, die PRINCE2 PRINCE2Foundation-Deutsch Zertifizierungsprüfung zu bestehen. Wenn Sie nicht an den entprechenden Kursen teilnehmen, brauchen Sie viel Zeit und Energie, sich auf die Prüfung vorzubereiten. Nun kann PrüfungFrage Ihnen viel Zeit und Energie ersparen.
Posted at 2/2/2026 01:49:48        Only Author  8#
Thank you for your article, it gave me such a fresh perspective. AWS-Developer new test camp materials is free and offers rich content to help you on your educational journey.
Posted at 2/8/2026 12:22:08        Only Author  9#
The article is written with great depth, and I have learned a lot of practical knowledge. With New 350-701 braindumps, you get access to valuable content at no cost, designed for your benefit.
Posted at 2/18/2026 19:51:40        Only Author  10#
VMwareの2V0-15.25認証試験はIT業界にとても重要な地位があることがみんなが、たやすくその証本をとることはではありません。いまの市場にとてもよい問題集が探すことは難しいです。PassTestは認定で優秀なIT資料のウエブサイトで、ここでVMware 2V0-15.25認定試験「VMware Cloud Foundation 9.0 Support」の先輩の経験と暦年の試験の材料を見つけることができるとともに部分の最新の試験の題目と詳しい回答を無料にダウンロードこともできますよ。
