[General] PrepPDF Huawei H12-891_V1.0 Real Exam Questions PDF Format
62
General PrepPDF Huawei H12-891_V1.0 Real Exam Questions PDF Format
Posted at 1/12/2026 06:15:27      View253 | Replies5        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PrepPDF H12-891_V1.0 dumps for free: https://drive.google.com/open?id=1byCV1GTRmVYkZvuvl4YbGS33NcEX7NeX
Our company can provide the anecdote for you--our H12-891_V1.0 study materials. Under the guidance of our H12-891_V1.0 exam practice, you can definitely pass the exam as well as getting the related certification with the minimum time and efforts. We would like to extend our sincere appreciation for you to browse our website, and we will never let you down. The advantages of our H12-891_V1.0 Guide materials are too many to count and you can free download the demos to have a check before purchase.
Huawei H12-891_V1.0 (HCIE-Datacom V1.0) Exam is a certification exam designed to test individuals' knowledge and skills in data communication technologies. H12-891_V1.0 exam is intended for professionals who are seeking to advance their careers in the field of data communication and networking. HCIE-Datacom V1.0 certification is offered by Huawei Technologies Co., Ltd, a leading global provider of information and communication technology (ICT) solutions.
Pass Guaranteed Quiz 2026 H12-891_V1.0: Valid HCIE-Datacom V1.0 Exam Brain DumpsWe are pleased to inform you that we have engaged in this business for over ten years with our H12-891_V1.0 exam questions. Because of our past years experience, we are well qualified to take care of your worried about the H12-891_V1.0 Preparation exam and smooth your process with successful passing results. Our pass rate of the H12-891_V1.0 study materials is high as 98% to 100% which is unique in the market.
The H12-891_V1.0 exam covers a wide range of topics, including network architecture, network protocols, network security, quality of service, and network troubleshooting. Candidates are expected to have a deep understanding of these topics and be able to apply their knowledge to real-world scenarios. H12-891_V1.0 Exam consists of both theoretical and practical components, ensuring that candidates have a well-rounded understanding of data communication.
Huawei HCIE-Datacom V1.0 Sample Questions (Q238-Q243):NEW QUESTION # 238
When you troubleshoot a local area network with Huawei equipment deployed, you find that there are a large number of unicast frames with unknown source AC addresses in the local area network . A large number of unknown source MAC addresses single-plug frames can cause the switch the biggest danger is ?
  • A. Memory that occupies the cache ton
  • B. Consume the MAC address table entry available in the system
  • C. Consume the available bandwidth
  • D. Increases the power consumption of the power supply
  • E. Consumes a TCAM table entry
NEW QUESTION # 239
In OSPF, an ABR translates all Type 7 LSAs in a Not-So-Stubby Area (NSSA) into Type 5 LSAs.
  • A. FALSE
  • B. TRUE
InOSPF, a Not-So-Stubby Area (NSSA) is a type of area that allows for the injection ofexternal routes(like a standard area) while maintaining some stub area characteristics.
Type 7 LSAs (NSSA External LSAs)are generated by ASBRs within an NSSA.
AnABRat the NSSA boundary translates theseType 7 LSAs into Type 5 LSAsto propagate them into the rest of the OSPF domain.
This translation is necessary becauseType 5 LSAsare the standard method for advertising external routes in OSPF.
Therefore, the statement isTRUE.
NEW QUESTION # 240
Refer to the following command output on the router R3. Which of the following statements are correct?
<R3> display interface Tunnel
Tunnel0/0/0 current state : UP
Line protocol current state : UP
Last line protocol up time : 15:21:26 UTC-08:00
Description: HUAWEI, AR Series, Tunnel0/0/0 Interface
Route Port, The Maximum Transmit Unit is 1500
Internet Address is 20.1.1.2/24
Encapsulation is TUNNEL, loopback not set
Tunnel source 10.0.3.3 (LoopBack0), destination 10.0.1.1
Tunnel protocol/transport GRE/IP, key disabled
keepalive disabled
Checksumming of packets disabled
  • A. The tunnel interface MTU is 1500 bytes.
  • B. The tunnel destination IP address is 10.0.1.1.
  • C. The tunnel interface IP address is 20.1.1.2/24.
  • D. The tunnel source IP address is 10.0.1.1.
Answer: A,B,C
From the output:
Tunnel destination IP address: Clearly shown as destination 10.0.1.1 ## Tunnel interface MTU: Shown as The Maximum Transmit Unit is 1500 ## Tunnel interface IP: Shown as Internet Address is 20.1.1.2/24 ## Tunnel source: Tunnel source 10.0.3.3 (LoopBack0) # Not 10.0.1.1 ## Therefore:
A- Correct
B- Correct
C- Correct
D- Incorrect (confuses destination as source)
Correct answers: A, B, C
NEW QUESTION # 241
A home user has opened a 1Mb/s bandwidth, and in order to improve the user experience, the operator can stabilize 2Mb/s when measuring speed If we use the listening bucket technology to achieve this requirement, which of the following methods is optimal.
  • A. cir 8000 pir 12000
  • B. cir 10000 cbs 10000 pbs 12000
  • C. cir 10o00 cbs 12000 pbd 12000
  • D. cir 10000 pir 12000
NEW QUESTION # 242
BGP Link State (BGP-LS) introduces a new NLRI into BGP. The NLRI carries link, node, topology prefix, and other information, and is also referred to as the link state NLRI.
  • A. FALSE
  • B. TRUE
Understanding BGP Link State (BGP-LS)
# What is BGP-LS?
* BGP-LS (BGP Link-State) is an extension of BGP that allows routers to exchange network topology information via Link-State NLRI.
* Helps SDN controllers and path computation elements (PCEs) make intelligent routing decisions.
# What Does BGP-LS Advertise?# Node Information - Router IDs, Loopbacks# Link Information - Bandwidth, Delay, Cost# Prefix Information - Network Subnets# Topology Information - Full network graph Why is the Answer TRUE?
# BGP-LS introduces a new NLRI format for advertising link-state information.# NLRI (Network Layer Reachability Information) is used to distribute topology data to SDN controllers.# It improves path optimization by enabling centralized traffic engineering decisions.
Real-World Application:
* SDN-Based Traffic Engineering: Used in Segment Routing (SR) networks for centralized path selection.
* MPLS TE (Traffic Engineering): Optimizes network paths dynamically based on real-time link-state data.
# Reference: Huawei HCIE-Datacom Guide - BGP Link-State (BGP-LS) Fundamentals
NEW QUESTION # 243
H12-891_V1.0 Latest Test Cost: https://www.preppdf.com/Huawei/H12-891_V1.0-prepaway-exam-dumps.html
P.S. Free & New H12-891_V1.0 dumps are available on Google Drive shared by PrepPDF: https://drive.google.com/open?id=1byCV1GTRmVYkZvuvl4YbGS33NcEX7NeX
Posted at 1/13/2026 10:10:18        Only Author  2#
I deeply appreciate your article, it was truly memorable. The C_BCWME_2504 latest practice questions files test questions are free! Wishing you success in your exam preparations!
Posted at 1/13/2026 12:26:06        Only Author  3#
Thank you for your powerful article, it left a lasting impression. With this Valid ASVAB exam bootcamp system, I got promoted and received a salary raise. Now, its available for free to all. Wishing everyone a speedy promotion!
Posted at 1/17/2026 13:04:13        Only Author  4#
Thank you for sharing; the content of the article is truly impressive! Thanks to the C-TS462-2023 latest exam test, I earned a promotion and a pay raise. Now, Im sharing it for free. Wishing you all success in your career paths!
Posted at 1/31/2026 15:40:49        Only Author  5#
Your article is outstanding; thank you for sharing it! The content in Exam AE-Adult-Echocardiography course is rich and free, available to aid you in your learning journey.
Posted at 2/10/2026 16:59:09        Only Author  6#
This article is truly a work of art, Im grateful for your sharing. Best wishes to everyone! 212-82 test questions fee test questions are now available for free.
