[Linux] How to install Kernel development packages?
89
Linux How to install Kernel development packages?
Posted at 8/8/2019 15:08:27      View5093 | Replies5        Print      Only Author   [Copy Link] 1#
I am trying to install PCIe drivers which needs kernel development packages. Can anyone help me with in installing the kernel package for an Ubuntu RK3399-PC?
Posted at 8/12/2019 11:42:12        Only Author  2#
1.Put kernel source code under this directory/usr/src/kernel
2.Install kernel package tool on the board
apt-get install kernel-package
3.Make package deb on the board
For example with firefly-rk3288:
make firefly-rk3288-linux_defconfig
make-kpkg kernel_headers --config menuconfigExecute second command will display the dialog of menuconfig, pls load .config then save .config , exit for auto complie . finally create: /usr/src/kernel/debian/linux-headers-3.10.0/  and  /usr/src/linux-headers-3.10.0_3.10.0-10.00.Custom_armhf.deb
4.Install head-file:
dpkg -i /usr/src/linux-headers-3.10.0_3.10.0-10.00.Custom_armhf.deb
Will create file after install /usr/src/linux-headers-3.10.0
Then, if you want to complie kernel source code on the board , pls add patch below on Makefile
KERNELDR := /usr/src/linux-headers-3.10.0/
Posted at 1/10/2026 02:07:31        Only Author  3#
Im truly thankful for your article, it really stood out. Im sharing the Valid braindumps PL-400 pdf test that helped me achieve a promotion and raise. It's free for you todaybest of luck in reaching your career goals!
Posted at 1/19/2026 00:33:07        Only Author  4#
Truly a magnificent read, thank you for this wonderful share. Heres the CGEIT latest exam camp sheet test I took to earn my promotion and raise, now free for you today. Best of luck in your professional journey!
Posted at 1/19/2026 01:40:02        Only Author  5#
Your article is brilliant, thank you for sharing! The Valid dumps 010-160 free download questions are now free! Wishing you all the best for your exams!
Posted at 2/22/2026 09:51:02        Only Author  6#
Nun gibt es viele IT-Profis in der ganzen Welt und die Konkurrenz der IT-Branche ist sehr hart. So viele IT-Profis entscheiden sich dafr, an der IT-Zertifizierungsprfung teilzunehmen, um ihre Position in der IT-Branche zu verstärken. Die MSP-Foundation Prfung ist eine sehr wichtige Peoplecert-Zertifizierungsprfung. Aber wenn Sie eine Peoplecert-Zertifizierung erhalten wollen, mssen Sie die Prfung bestehen.
