My Firefly is dead
2
My Firefly is dead
Posted at 12/23/2014 15:25:28      View6382 | Replies9        Print      Only Author   [Copy Link] 1#
Went to switch it on this morning and it is completely dead.
Hooked it up to my PC but it isn't being recognised there either.
Checked the status of the ac unit and that is fine.
Posted at 12/23/2014 17:57:21        Only Author  2#
What had you done to it?
Try attach a serial adapter to it and see if anything comes out.
Posted at 12/23/2014 20:22:12        Only Author  3#
I just started it up as usual.
Tried a serial adapter but getting?absolutely nothing.
Posted at 12/23/2014 22:05:32        Only Author  4#
If the on board flash is trashed connect a micro usb cable from the otg port to a PC as the device may be in MaskRom Mode.?Then use something like RKAndroidTool, RKBatchTool?to see if the device is detected.
Posted at 12/24/2014 01:04:36        Only Author  5#
I tried to see if it was in maskrom mode and used all of the available tools but none see the firefly in any way, shape or form.
Posted at 12/24/2014 15:18:20        Only Author  6#
Please use a?multimeter to measure the voltages described in the attached picture, and post the result.
(The full?component reference file is at
http://www.t-firefly.com/download/firef ... 30_pos.pdf
Posted at 12/31/2014 02:46:31        Only Author  7#
Took it to a local sparky, who ran the multimeter tests over it and found no life whatsoever.
vip
Rank: 6Rank: 6
Posted at 2/26/2015 16:50:57        Only Author  8#
Re: My Firefly is dead
if no power and no log, you should check you hardware.
Posted at 1/15/2026 06:32:39        Only Author  9#
It was a truly rewarding and enlightening piece of writing. Ready to take on the AZ-204 updated demo exam! Fingers crossed!
Posted at 2/24/2026 17:52:16        Only Author  10#
Your article is brilliant, thank you for providing this amazing share! Elevate your IT skills and grab free Valid study questions Ind-Dev-201 free download. Good luck with everything!
