[Hardware] C_ARCIG_2508 Real Question - New C_ARCIG_2508 Test Objectives
16
Hardware C_ARCIG_2508 Real Question - New C_ARCIG_2508 Test Objectives
Posted at 1/20/2026 11:27:27      View207 | Replies2        Print      Only Author   [Copy Link] 1#
We consider the actual situation of the test-takers and provide them with high-quality C_ARCIG_2508 learning materials at a reasonable price. Choose the C_ARCIG_2508 test guide absolutely excellent quality and reasonable price, because the more times the user buys the C_ARCIG_2508 test guide, the more discounts he gets. In order to make the user's whole experience smoother, we also provide a thoughtful package of services. Once users have any problems related to the C_ARCIG_2508 learning questions, our staff will help solve them as soon as possible.
SAP C_ARCIG_2508 Exam Syllabus Topics:
  • Managing Clean Core: This section of the exam measures the skills of Implementation Consultants and focuses on applying clean core principles within SAP environments. It highlights practices that maintain standard processes, minimize customizations, and ensure long-term system stability.
  • Master Data: This section of the exam measures skills of Solution Architects and ensures knowledge of handling master data within SAP Ariba integrations. It focuses on consistent and accurate synchronization across connected systems.
  • Supplier Lifecycle Performance: This section of the exam measures the skills of Implementation Consultants and includes the setup and management of supplier lifecycle performance processes. It validates understanding of integration elements supporting supplier evaluation and collaboration.
  • SAP Business Network Integration Configuration: This section of the exam measures the skills of Implementation Consultants and focuses on configuring integration with the SAP Business Network. It validates understanding of connectivity steps to enable business-to-business collaboration.
Topic 5
  • SAP Ariba Procurement Integration Configuration: This section of the exam measures the skills of Implementation Consultants and focuses on procurement-related integration tasks. It highlights knowledge of system setup that enables seamless procurement processes between SAP Ariba and SAP S
  • 4HANA.
C_ARCIG_2508 Real Question - Trustable SAP New C_ARCIG_2508 Test Objectives: SAP Certified Associate - Implementation Consultant - Managed gateway for spend management and SAP Business NetworkLead2PassExam's training product for SAP certification C_ARCIG_2508 exam includes simulation test and the current examination. On Internet you can also see a few websites to provide you the relevant training, but after compare them with us, you will find that Lead2PassExam's training about SAP Certification C_ARCIG_2508 Exam not only have more pertinence for the exam and higher quality, but also more comprehensive content.
SAP Certified Associate - Implementation Consultant - Managed gateway for spend management and SAP Business Network Sample Questions (Q61-Q66):NEW QUESTION # 61
What are the key features of the Transaction Tracker utility?Note: There are 3correctanswers to this question.
  • A. Reprocess options
  • B. Customization
  • C. Monitoring
  • D. Test connectivity
  • E. Varied search options
Answer: A,C,E
NEW QUESTION # 62
You are a consultant on an SAP S/4HANA Cloud greenfield project. As part of their clean core journey, the customer must analyze the current IT landscape to eliminate redundant systems and establish an efficient architectural design. Which of the following can you use to do the analysis?
  • A. SAP Cloud ALM
  • B. SAP Best Practices
  • C. Lean ix
  • D. SAP Solution Manager
From the "Managing Clean Core for SAP S/4HANA Cloud" learning journey on learning.sap.com, the recommended tool (among the options listed) for analyzing the current IT landscape-especially in a greenfield, clean-core journey-is:
*C. SAP Best Practices
These provide pre-configured, standard processes and a baseline understanding of SAP S/4HANA Cloud functionality, helping you assess what existing processes/systems you may retain, optimize, or eliminate. SAP Learning+1 Neither SAP Solution Manager, SAP Cloud ALM, nor Lean-IX is cited in the clean-core greenfield context on learning.sap.com for this analysis.
Therefore, the correct answer from that source is:
(It appears that only one of the given options is supported in the SAP learning content for this scenario.)
NEW QUESTION # 63
You are migrating from Ariba CI to the Managed Gateway for Spend & Network solution. If you choose to manually create the service names for Proxy/Web service transactions, which of the following documents should you consider?
  • A. Receipt in SAP Ariba Procurement Integration
  • B. Invoice in SAP Business Network Integration
  • C. Invoice in SAP Ariba Procurement Integration
  • D. Purchasing info record in SAP Ariba Sourcing Integration
  • E. Receipt in SAP Business Network Integration
Answer: A,B,C
NEW QUESTION # 64
Which of the following conditions are related to handling attachments in standard SAP documents as supported in integrations using the SAP Integration Suite, managed gateway for spend management and SAP Business Network? Note: There are 2correctanswers to this question.
  • A. Attachments are supported at the line level using the SAP Document Management System (DMS)
  • B. Attachments are supported at the line level using SAP Change Documents
  • C. Attachments are supported at the line level using SAP SmartForms
  • D. Attachments are supported at the header level using SAP Generic Object Services (GOS)
Answer: A,D
Solution:
From learning.sap.com (specifically the "Supporting Attachments and Comments" lesson), the two correct statements are:
*B. Attachments are supported at the line level using the SAP Document Management System (DMS) SAP Learning
*D. Attachments are supported at the header level using SAP Generic Object Services (GOS) SAP Learning So thecorrect answe rsare B and D.
NEW QUESTION # 65
Against which of the following fields in the CIF file created on the SAP ERP or SAP S/4HANA (on-premise) system must you manually maintain the SAP Ariba field names using the "Maintain Field Map for Master Data and Catalog Upload Request" activity when importing master data for catalogs? Note: There are 3 correct answers to this question.
  • A. MEINS: Base Unit of Measure
  • B. ESOKZ: Purchase Info Category
  • C. EKORG: Purchase Organization
  • D. LGORT: Storage Location
  • E. INFNR: Purchase Information Record
Answer: A,C,D
NEW QUESTION # 66
Nowadays in this information-based world the definition of the talents has changed a lot and the talents mean that the personnel boost both the knowledge in C_ARCIG_2508 area and the practical abilities now. So if you want to be the talent the society actually needs you must apply your knowledge into the practical working and passing the test C_ARCIG_2508 Certification can make you become the talent the society needs. If you buy our C_ARCIG_2508 study materials you will pass the C_ARCIG_2508 exam successfully and realize your goal to be the talent.
New C_ARCIG_2508 Test Objectives: https://www.lead2passexam.com/SAP/valid-C_ARCIG_2508-exam-dumps.html
restricted members
Posted at 2/5/2026 17:49:22        Only Author  2#
This is such a motivational piece, thank you for sharing! Improve your IT skills and get free C-ACDET-2506 new study notes access. Wishing you the best of luck!
Posted at 2/16/2026 12:22:50        Only Author  3#
The logic in the article is very clear, and it has helped me understand many complex concepts. Enhance your IT abilities and get free Valid braindumps CPHQ files. Best wishes for success!
