[Linux] Unable to Compile Ubuntu Firmware into ROC-RK3399-PC
89
Linux Unable to Compile Ubuntu Firmware into ROC-RK3399-PC
Posted at 8/2/2019 14:42:54      View5283 | Replies6        Print      Only Author   [Copy Link] 1#
I have recently bought RK3399-PC and tring to boot ubuntu. But after flashing the ubuntu into the SD card, I am not able to follow the steps given in the link http://wiki.t-firefly.com/en/ROC-RK3399-PC/linux_sdk.html#. When I try to compile Environment from the following link http://wiki.t-firefly.com/en/ROC ... compile-environment it diplays error "aarch64 file is obsoelte or command not found".
I have included Expansion board to the development board and has flashed ubuntu from the following link https://drive.google.com/drive/f ... LY0DG_BLx94eAeArvwI Are there any additional libraries that I need to install before compiling ubuntu firmware? Could you guide me in completing the bootup?
vip
Rank: 6Rank: 6
Posted at 8/3/2019 10:31:31        Only Author  2#
Hi, welcome to the forum.
The "sudo apt-get ..." command is meant to run as a big long line.
But copy and paste will result in multiple lines.
We'll fix the doc.
vip
Rank: 6Rank: 6
Posted at 8/3/2019 12:03:10        Only Author  3#
Doc fixed at http://wiki.t-firefly.com/en/ROC ... compile-environment
Thanks for reporting this to us.
Posted at 1/9/2026 14:25:05        Only Author  4#
This is a truly exceptional piece of writing, thank you for sharing. Exam NetSec-Pro fees contains comprehensive material, available at no cost to support your learning.
Posted at 1/12/2026 21:09:01        Only Author  5#
I was really impressed by the depth of the article. Free Exam C_TS4FI_2023 exercise exam questions to help you prepare. Best wishes for success!
Posted at 1/24/2026 20:56:38        Only Author  6#
Your article was a breath of fresh air, thank you for sharing it. Free New C-P2WAB-2507 study plan test papers for everyonegood luck!
Posted at 2/1/2026 18:34:48        Only Author  7#
Thank you for sharing this motivational and inspiring article! The New exam Project-Management guide files exam helped me climb the career ladder and increase my salary, and today, Im offering it to you for free!
